Question about Campbell Hausfeld WL6502 5-Hp 20-gallon Oiless Air Compressor
My oiless compressor will not discharge air when the hose is attached. air comes out in a burst then slows down to like breathing. simultaneously the pressure gauge goes to 0 until i disconnect the hose, then the gauge registers the normal pressure in the tank. I am lost as to what causes that, so i bought another hose and it did the same thing. Please help!!!
  • spiderhigh21 Mar 16, 2011
    i have yet to try this but i will. I then will be commenting back.
    thanks so very much.
  • 2,510 Answers
Your problem does not seem to lie with the compressor or the tank. You say you replaced the hose. Did you replace both the fittings, the male and the female, because that is where I would put your problem. The male and female connectors must be compatible and sometimes you get a male connector that is a bit shorter and does not quite open the discharge valve in the female coupling. On some couplings, if you push the hose connector into the female connector it will open the valve a bit more and should then give you a normal discharge. But check that the two parts of the coupling are the same type and preferably the same make.
Posted on Mar 15, 2011
What level does the coolant need to be in the sight glass?
About 31,000 results (0.83 seconds) Search Results
    [PDF]IRM-G-8780 2-25hp US - Ingersoll Rand Air Compressor
    www.ingersollrandproducts.com/...
    Ingersoll Rand Industrial TechnologiesIngersoll Rand compressors are not designed, intended or approved for breathing ...does not approve specialized equipment for breathing air applications and ... unmatched service to meet your needs. ... drain, and low-oil-level .... Oil Sight Glass ... Value Package (5, 7.5, 10 & 15hp) An economical choice in a dependable ...
    [PDF]Owner's Manual - Air Compressors Direct
    www.aircompressorsdirect.com/.../irmanual2340_2475_2545_7100_15t...
    installation, operation and maintenance of your Ingersoll-Rand air ... An air-cooled aftercooler, low oil level ... for Models 2340, 2475, 2545, 7100, 15T & 3000 ... Ifcooling of the discharge air is required, .... motor does not have this button and the unit does not have a ..... l Drain compressor oil and clean oil sight glass.
    [PDF]XF 7.5 - 15 EP 7.5 - 15 HP 7.5 - 15 XP 7.5 - 15
    diagramasde.com/.../Manual%20comp%20ingersollrand%20SSR-15.pdf
    EP 7.5 - 15. HP 7.5 - 15. XP 7.5 - 15 ... The Ingersoll-Rand Company Rotary Screw Air Compressor that has been filled prior to its ... after shall have its AIREND warranted for twenty four (24) months from the ... comes first, when using ULTRA COOLANT.Coolant ...... check coolant level in the sight glass on the separator tank.
    Ingersoll Rand Air Compressors - About Air Compressors
    www.about-air-compressors.com/Ingersoll-Rand-air-compressors.html
Feb 08, 2016 | Ingersoll Rand 15 Horsepower Rotary Screw...
Refigerator runs but does not cool
Hello, Make sure that the area around the compressor is clean. Remove all dirt dust and debris from compressor area as well and under the front of the fridge using a vacuum cleaner hose and brush attachment. If the fridge cannot "breathe", it will not blow cold air. Hope this helps.
Nov 20, 2014 | Frigidaire Refrigerators
Air compressor slow to build pressure, and noisy.
All large air compressors are very noisy.
How long it takes to come up to pressure depends on the size of the compressor piston(s), how fast they are running and the size of the air tank attached to it. (and if the tank or hoses have leaks)
A 20 gallon tank could easily take 10 minutes to get all the way up to 120 psi. 120 is very high, and probably the limit for the compressor. Depending on what you're using it for, try dropping the setting to say 80-90psi.
Sep 25, 2012 | Air Tools & Compressors
I have a craftsman oiless air compressor. All tools that I attach have low pressure to start. After I hold the attachment wide open for about 10 seconds, it will eventually break loose and the air flows...
check your hose or couplers for restiction --------- try exchaging with know good ones------- the rubber seal in the female coupler may be the culprit ------------torn// deteriated// comming apart & blocking off air flow....
May 25, 2011 | Craftsman Air Tools & Compressors
My ssl5l compressor builds pressure real slow now. Rings or Valves? it did get a little warm while sandblasting lately....
Very rare to have problems with rings. Blow-by would produce high pulsating pressure in the crankcase causing oil to blow out the oil filler plug/ dipstick. If normal crank pressure, suspect problem with valves or gaskets. Remove air filter cover and check for air blowing out of intake or very hot head or air discharge tube. Leaking valves or blown gasket will cause low volume/ low pressure and hot discharge air. Remove the in-tank checkvalve and look for carbon deposits /debris build-up. If the checkvalve and the interior or discharge hose are coated with oil deposits /carbon, most likely problem is valve plate/ gaskets /head. Good luck with your repair.
May 03, 2011 | Ingersoll Rand SS5L5 Ir Electric...
I have a Hitachi EC12 Portable Electric 2hp Air Compressor. It builds air pressure fine and shuts off normial. But if I attach a blow nozzle or another attachment to the hose and try and use it, the...
This is a stab in the dark.....but have you emptied the condensation out of the tank? It may reach max pressure....but have little air compressed inside the tanks. Just a guess.
Dec 13, 2009 | Hitachi EC12 Portable Electric 2hp Air...
My central Pheumatic air compressor oiless
Sound like the fly wheel is loose or belt is the same
Mar 13, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air conditioning
The system refrigerant charge was most likely low but not empty, so you would get a burst of pressure and oil, the oil that lubricates the AC compressor circulates with the refrigerant. Does this make sense?
Jul 30, 2008 | 2001 Honda Accord
How do you fix a serpentine belt of air condtioning that is grinding even when air or defrost option is not on?
replace compressor ;remove refrigerant ;accessory belt ;electrical connectors ;suction /discharge refrigerant hose from back of compressor ;bolts from compressor and engine block ;leave bracket attached to compressor
Jun 06, 2008 | Oldsmobile Aurora Cars & Trucks
Campbell Hausfeld WL6502 5-Hp 20-gallon Oiless Air Compressor Logo
63 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
