Question about Symbol PDT 8100
I have a pdt8100 pocket computer that just stopped communicating with my computer. we have replaced the 8100, the cradle it rests in, the serial cable, and have even tried using a serial to usb adapter, all with no success. the 8100 will not comm with the 2 computers it had been used with, but we have our server on the cash register,and it will comm with that one. all 3 computers have the latest version of ms active sync installed, and are running xp.
2 Suggested Answers
thesuperdude
  • 97 Answers
SOURCE: Can I upgrade a Symbol PDT8100 from Pocket PC 3.0
PDT8100 can be upgreded to pocket pc 2003, however you will need to purchase a license to do this. Once you have the license, you will get the required files to update it.
You will need a cradle , cable and power supply to do this.
Posted on Mar 26, 2009
Can the Matsunichi Pocket PC sync with Windows Vista?
Yes it can. Plug it into the cradle and Vista will bring up Activesync. The rest is easy to follow.
Feb 25, 2010 | Matsunichi i-mat IP3230 Pocket PC
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Aug 25, 2017 | HP iPAQ H1945 Pocket PC
Can I upgrade a Symbol PDT8100 from Pocket PC 3.0 to Pocket PC 2003 or maybe MC50? I would like to do it myself. Thx.
Feb 26, 2009 | Symbol MC50 Pocket PC
Help me please
HI
Download mmty.exe from http://www.4shared.com/file/44565543/32026ae8/mtty.html.
Now do the following:
1. Stop ActiveSync, by Task Manager (press Ctrl + Alt + Delete)
kill two processes rapimgr.exe and wcescomm.exe
2. put your device into the cradle
3. Run mtty and Choose WCEUSBSH001 in 'PORT' (if it doesn't show then you didn't stop all active sync processes above!)
4. type "set 16 0" without the quotes to tell bootloader to boot the OS after reset. (for some devices it can also be "set 14 0")
5. type "task 8" to get your device formatted
6. type "task 0" to ask your device reboot
7. take the device out of the cradle, and manually reset it if it does not do that already.
Good luck
Oct 29, 2008 | Orange SPV M2000 Pocket PC
Problem serial connection e400 using cradle
I am not 100% sure if I am correct in this, but I am quite sure that the e400 does not support a serial connection. Only the e800 does.
Sep 11, 2005 | Toshiba e400 Pocket PC
"Communications Error 608"
If you put the Toshiba Pocket PC e740 in your USB Cradle you may receive a "Communication Error 608". This is not a serious error, it is just a false setting in the ActiveSync Program. Please follow these steps below to correct this problem: "Tap" on start and choose the ActiveSync program Then "tap" on "Tools" and choose "Options" in the ActiveSync Program Check under "Enable synchronization when cradled using" to see if the setting is on "USB" If it is set on "Bluetooth", please change it to "USB". Now you can close the application window Important: Please remove the Pocket PC from the cradle and then return it to the cradle. This activates the new setting Important to note: This above described issue occurs if you "tap" accidently on the Bluetooth Icon in the Program Group or activate Bluetooth of any other reason, the ActiveSync Option will be set to "Bluetooth" instead of "USB". This setting will cause the "error 608" if you put in the Pocket PC e740 in the Cradle and start to synchronize over USB.
Sep 07, 2005 | Toshiba e310 Pocket PC
Cassiopia EM500 sync issue
First of all ensure that the port selected on the EM-500 for PC connection is the same as your actusl connection - i.e. USB or serial. There were some problems with the EM-500 cradle which would not allow communication to be established between the PDA & the PC/Laptop. Contact Casio for rectification. It is done free of charge.
Sep 06, 2005 | Casio Cassiopeia EM-500 Pocket PC
Symbol PDT 8100 Logo
88 people viewed this question
Top Symbol Computers & Internet Experts
Michael
Oloyede Monsuru
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
