Question about Lenovo ThinkCentre M57 Desktop - Intel Pentium Dual-Core E2160 1.8GHz - 1GB DDR2 SDRAM - 80GB - DVD-...
I have a Lenovo Thinkcentre m57 6072-CTO. Every time I start a video from google news my computer beeps, my display freezes then goes black saying no connection check signal cable. The computer is still running with a green light. Sometimes this will happen without running video. HELP!!
  • 1,179 Answers
Your computer system is getting too hot.
When you don't run videos your computer is running in 2D mode, very little rendering is taking place therefore less heat output.
Then when you want to watch a video the graphics unit has to work hard and therefore produces heat. That heat needs to be effectively removed from the chassis in order for the computer system perform well.
Your computer may need a clean, remove all dust blocking air intake/exhaust areas.
Also go through my guide entitled How to install Graphics Drivers, Nvidia and AMD Radeon!!! as you may need better more efficient drivers for your graphics card.
Consult the manual in this regard for the graphics card model number or name!
The beeping either indicates overheating or low/unstable power to the computer system from the power supply!
Thanking you
damnor01
Posted on Mar 15, 2011
I have lenovo thinkcentre A57, i can't access in bios setup while pressing F1, F8 or F12, when i'm pressing any of them the computer continue to boot in a black screen. Sincerely: Juls
To start the Setup Utility program, do the following:
1.
If your computer is already on when you start this procedure, turn off the
computer.
2.
Repeatedly press and release the F1 key when turning on the computer. When
you hear multiple beeps or see a logo screen, release the F1 key.
Note:
If a Power-On Password or an Administrator Password has been set, the
Setup Utility program menu is not displayed until you type the correct
password.
Jun 25, 2015 | Lenovo ThinkCentre A57 Desktop - Intel...
Ive tried to install a new graphics card in my lenovo thinkcentre pc but nothing shows on the display
Make sure your power supply is big enough and you have plugged everything in. Some video cards require power directly from the power supply with a special 4 plug cable. You can get adapters if your power supply doesn't have the right plug.
Sep 19, 2012 | Lenovo ThinkCentre A30 PC Desktop
I have installed 2GB of memory and my coputer freezes, when i turn it on
Try removing the old ones and it should work. The old ram would just slow you new ram down anyways.
Jun 20, 2012 | Lenovo ThinkCentre A60 PC Desktop
Need sound lenovo 8932-CTO laptop
Download and install the audio drivers.
Make sure the volume control is up and that mute is not checked.
Get onlineand got to www.google.com In the google search box type: "LenovoSupport" or "IBM Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the drivers.
Apr 15, 2012 | Lenovo ThinkCentre A55 PC Desktop
Can i intall a nvidea or other graphic card in my lenovo m55 8804-cto
This system's mainboard appears to only support a PCI style video card. You amy find one you like on www.newegg.com
Aug 27, 2011 | Lenovo ThinkCentre® M55-8811 PC Desktop
I have a Lenovo A61 Thinkcentre that is about one year old. I am now hearing a fairly loud noise that comes and goes. When the system starts, the noise appears and lasts 10 - 20 minutes, then disappears....
Ok it still sounds like an fan. look for fans, one in power supply, one on cpu, one in case(frount or back), one on video card. before you start from cold unplug the fans that you can. and stop the one in power supply. then if there is no nosie you have to start pluging them back in till you hear the noise. **NOTE!!** don't run it long without fans!!( 40 secs) is long enough..
Feb 26, 2010 | Personal COMPUTER - LENOVO THINKCENTRE A61...
I have a Lenovo Thinkcentre A61e that has a display problem. The display is red and I have tried 3 different monitors with all the same results. Any idea why??
This is either a bad video card or the wrong or damaged Video drivers. If the display is red even when the computer first boots up before Windows even starts then it is the video card. If it turns red only after Windows actually starts then it may be the drivers.
1. Check for bent pins inside the video connector on the computer.
2. Check for bad video cable.
3. Remove and reseat the video card (if you have a separate video Card)
4. If the video is built into the system board, you could try to install a new separate video card to get around the problem.
Oct 14, 2009 | Lenovo ThinkCentre® A61E PC Desktop
Beep code 4 2 3 3
4-2-3-3 Extended Block Move.
read this. It may help you
http://www.cybertechhelp.com/forums/showthread.php?t=161582
Jun 18, 2009 | Lenovo ThinkCentre M52 PC Desktop
Pc won't finish booting, can't read disks
without knowing the model I am going to refer you to the IBM website to find your specific model and the info needed to change the boot order and try booting from CD or try thr recovery feature I thnk it's F11?
http://www.ibm.com/search/?en=utf&v=14&lang=en&cc=us&lv=c&q=IBM+thinkcentre+users+manual&x=10&y=11
Mar 21, 2009 | Lenovo ThinkCentre A50 PC Desktop
Lenovo ThinkCentre M57 Desktop - Intel Pentium Dual-Core E2160 1.8GHz - 1GB DDR2 SDRAM - 80GB - DVD-... Logo
796 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
rey francis basa
rey francis basa
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
