Question about Vacuums
Can not remove blades i open door push up on tabs the blades will not move. i just bought it 2 weeks ago
    Master:
  • 403 Answers
I dont know that a vacuum has blades, but I would try and return it, before I cut up my carpet.
Posted on Mar 15, 2011
Can the suction be adjusted manually as it is too powerful on my carpets
returns are up to the place of purchase. we can not answer that for them. contact the place of purchase.
the suction can not be adjusted.
Jun 25, 2016 | Dyson DC40 Multi-floor Vacuum DC40
Need to open the electrolux vacum
The locking key on the side of the vac has a tightening wedge on it so it doesn't slide easily. Spray the entire key top and bottom with WD40 or similar. Grasp at the bag door area with vise grips and pull the key straight forward.
If the key will not slide, you will need to take a large flat bladed screwdriver and lay the blade flat at 90 degrees against the back end of the key. then strike the side driving the key forward toward the bag chamber door. Do not twist.
Aug 22, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Hoover Handle Release Pedal Replacement--How is it possible?
Remove the brush roll, then there 3 screws to remove from the bottom. Then on each side there is a slot, use a flat blade and push on them, then the top rill come loose. That idler arm lock is # 4 in the picture and the knob holds it in place, unless it came off, you don't need to replace it. The handle release #6, there 2 tabs that fit into a holder on each side, stick your screw driver in there and try to twisp and pry it out from the holders, then pop in the new one.
Jul 03, 2008 | Vacuums
HEPA FILTER REPLACEMENT
Looks like there are is an 2 indentations on the back, these are tabs, push them in and push the cover up, it should come off.
Jan 29, 2008 | Kenmore 25512/ 25513 Progressive Canister...
Need to open motor compartment
Use a flat blade screwdriver, The dusy compartemnt door will come off by pushing it back, it just pops out. Then the rear top cover is held on by a tab, one in each corner. Put the flat blat in the slot at the bottom of the cover and work it until it pops loose. Then there are 2 screws to tak out to remove the cover over the motor and cord reel asm. But now you can get to the motor.
Jan 24, 2008 | Panasonic MC-V9620 Canister Vacuum
Hoover belt replacement
Turn vac. over, remove the buttom plate over the brush roll, then at the bottom edge of the top cover, using a flat blade screwdriver, insert into the slots and pry up to unlock the tabs, then the top cover will come off. Put the belt on the brush roll and feed the belt thru the opening and put stretch it over the motor shaft. Put the top cover back on and push to lock the tabs.
Dec 19, 2007 | Vacuums
Belt
The top light cover comes off, on each side and on the back edge, push in to release it and take it off, then remove the 2 screws and the light bulb. Then with a flat blade, from the bottom edge, there is a slot on each side, stick the flat blade screwdriver into the slot and pry up to release the locking tabs, cover will now come off and you can get to the belt to replace it.
Nov 05, 2007 | Panasonic MC-V9635 Canister Vacuum
Can't open rear compartment
To seperate the two body halves: 1-Set the vacuum on it's wheels & open the front door. 2-Place a wide screwdriver blade just between the reaer cover and the rubber bumper and tap the screwdriver on the side to push the bumper forward towards the door a little bit. 3-Grasp the bumper and pull it straight out. 4-Leave the vacuum halves together...flip the vac over on it's top. 5-Put your palms against each wheel with your fingers in between the body halves..pull each side out just a little and snap the lower body upwards. It will then come apart. 6-You can then mark the wires on the cordwinder for corresct replacement afer the repair. Make sure you put the bumpers back on each I-Beam before you put it back together. (they don't need to be removed). And the FLAT end of the rubber bumper is against the front door. Good Luck !
Aug 30, 2007 | Electrolux Epic 6500 Vacuum
Dirtlifter Powerbrush does not turn
Make the machine safe from the power source first
When you remove the belt access door you are looking at the pump belt,
To gain access to the brush belt you must turn the machine over and remove the brush at the bottom of the machine.
there are two screw in the red retainers at each side of the brush, remove the screws and the retainers and the pivot arms ,you should see the brush belt and the pump
Jun 07, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Motor overheating
There is a filter on top of the motor as well. You will need to remove the plastic cover on top of the motor with a small screwdriver or other flat blade. On the front, you push in the clip and pull up ont he cover. On each side of the cover there is another clip - to pop those you put your flat blade into the angled tab and slide it around to the clip until it pops. Gently or you'll break the tab. Once the cover is off there is a purple tab in the center pull up and you will pull the HEPA motor filter out - similar in shape and size to the side, washable, filters. Clean or replace that.
May 27, 2007 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacuums Logo
20 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
