This is sabee again. thank you for the post. I tried what you told, but it only repeatedly asks the same thing. i suppose i have made an error in the format i typed. please help. this is my previous post http://www.fixya.com/ThreadAsker.aspx?thid=8667931&msgid=15641006
  • sabeethan_k Mar 15, 2011
    I a m sorry about that. I dont know how to reply. that's why i did this. I am sorry.
    @islandmyth: thanks alot. i will try that.
  • 120 Answers
Do you have a ThinkVantage Rescue and Recovery. This link might be helpful.
http://www-307.ibm.com/pc/support/site.wss/MIGR-70803.html
Posted on Mar 15, 2011
  • 1,381 Answers
Hello Sabee ,
Please post your question as a reply or comment in your previous post . We can't help you here .
Thanks ,
fanaudi .
  • fanaudi
    fanaudi Mar 15, 2011
    Sabee , no problem but if you want to contact noveegiangod again , you' ll need to go back tohttp://www.fixya.com/ThreadAsker.aspx?th... unless islandmyth has the best solution . Best regards . fanaudi .
    hmm yea, I commented on that post too. but he did not post yet, thanks alot.
Connetion error 80130128
1. on pc, run -> cmd
2. ipconfig
3. Read the "gateway" ip. Put that into browser to go to router's admin page
4. Find the DHCP settings for router to see what range of IPs it hands out; pick one outside that range
5. Set up the ps3 with that IP, the router IP as primary dns, and an opendns server as secondary This made the connection test happy. But when he tried to go to the playstation store, it gave a DNS error. If he repeated the connection test again, it failed too. "Well," I told him, "It's supposed to try both DNS servers. But we can try setting the primary DNS server to opendns as well." Once he did that, everything worked. (In case you don't know, Run is on the Start menu, usually on the right-hand panel.)If you try that, it might well be possible that your problem is solved. If this doesn't work for you, please call our Network Call Center
Nov 05, 2013 | Sony Video Game Consoles & Games
The TV was working great yesterday, but today, when you press the power button, th TV clicks on, then within 5 seconds clicks off, picture never appears but green light comes on until TV clicks off. ...
When the power light comes on and then goes out, on the front of the set press both the MENU and INPUT buttons at the same time and hold them both in for at least 5 seconds and then release both buttons.
The power light will blink a 2 digit error code and repeat it at least 5 times.
The most common error will be 2 blinks, 2 blinks- a pause and then it will repeat it for a total of at least 5 times.
To get it to repeat this--you have to unplug the set, try to turn it on again and repeat the process.
The error codes are to try to narrow down where the problem is.
Let me know what error code you find and I will tell you what it means.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
Post comment here if I can assist you further.
SD TECH
Sep 28, 2010 | Mitsubishi WT-46809 46" Rear Projection...
Tv goes right off as soon as i turn it on
IF this told you something you did not know rate this solution as very helpful as I do this here for free.
SD TECH
Sep 20, 2010 | Mitsubishi WT-42315 42" TV
I try to switch the TV on (either using Power button on the remote control unit on TV itself), but the TV switches itself off immediately. I tried it many times, quickly in succession, as well as after...
Let me know what you find and I will tell you what it means.
MAKE A COMMENT HERE and I will help.
SD TECH
Sep 18, 2010 | Mitsubishi WS-65807 65" Rear Projection...
When you try to turn on green light comes on goes off everytime you try to turn it on.
Comment here and let me know what error code you find and I will tell you what it means.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Sep 18, 2010 | Mitsubishi WS-65413 65" Rear Projection...
My ipod does not restore
try this: when it says error after trying the restore,press ctrl+alt+delete and select itunes and then end task....restart itunes and try the restore again....works quite often...
Sep 01, 2009 | Audio Players & Recorders
Cant open text messages on Altel Phone
I got my problem solved. I called ALLTEL and they walked me through MIN and MDN changes. Apparently, when I got my phone, it was supposed to be a new phone but it was a refurbished one. Things they dont tell you. Anyway, Im all set and now I can send and receive texts. Call your carrier and explain the issue, they should be able to solve your problem. I have already posted this but thanks for asking. I hope this helps someone else.
Mar 27, 2009 | Motorola Mobility MOTORIZR Z3 Cellular...
Hello sir
Hi again,
Appreciate the direct "Ask Me". Let's try do a re-format:
  • attach iPod to USB port of PC;
  • riight click on My Computer;
  • left mouse click on Manage / Storage / Disk Management / Action / Rescan disks;
  • follow on-screen instructions.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 28, 2008 | Apple iPod nano 3rd Generation
Oven door won't unlock
I posted a message on 12/27 and since then I have contacted Jenn-Air again and as I mentioned above the two things they told me to do didn't work, so I looked at the schematic of the unit and there appears to be a motor that locks and unlocks the door. I have a service repair coming this Saturday and seems to believe the motor is bad. Trenatru are you getting an error message? I was told by Jenn-Air that there is a 6 yr. warranty on electrical parts so will try to keep you posted if that is the cause. If you havn't tried shutting off the power try that first. They said keep it off for a couple minutes before turning back on. If that try pushing on the door and hitting cancel twice. If those two things don't work, will let you know what I find out next weekend.
Dec 24, 2007 | Jenn-Air W30400P Stainless Steel Electric...
HDD error
I got the same HDD error on mine also. I removed the zif drive from the camcorder and checked it with an external zif hd adapter and the hard drive was good. I emailed JVC and asked them what is wrong with it they said to just mail it in for repair. I think it has to do with deleting the original hidden files and folders that were factory installed because when I checked the hard drive for folders it didn't have any in it(mistakenly deleted or moved). From what I have read from the manual you are not suppose to change folder names or delete hidden files. Hope this post helps you out a little. If you figure any thing else out post more info. Thanks.
Aug 26, 2007 | JVC Everio GZ-MG21 Camcorder
Computers & Internet Logo
David Payne
David Payne
