Question about Whirlpool MH7130XE Microwave Oven
How many cu feet is the Whirlpool MH7130XE - Whirlpool MH7130XE Microwave Oven
    Brigadier General:
  • 8,909 Answers
The volume is written on the front page of your manual. There is no imediate record on line as it is not a current model anymore.
Posted on Mar 15, 2011
Microwave has power but does not work?
Well, you probably need a new microwave, or you need to replace the heating element or source.
Apr 27, 2014 | Whirlpool MH7130XE Microwave Oven
Stirrer motor
I would recommend a technician for the job. It can be a tricky repair.
Apr 07, 2012 | Whirlpool MH7130XE Microwave Oven
Microwave oven door distorted
I would recommend that the door be checked for radiation leakage and if replacement is required.
Mar 17, 2012 | Whirlpool MH7130XE Microwave Oven
Microwave MH7130XEB-2 stopped working while cooking. Is now dead. Check plug and breaker box, they are ok. Is it an internal fuse? If so what part # do I need?
Hello :
Problem with the power transformer or the power PCB . Or it could be just a fuse . You need to check first . If it's the fuse , then that will be easy to solve , you need only to replace it with new one . But if the problem is with the transformer or with the PCB , you need to take your microwave to the service .
You could check for manual here :
Whirlpool MH7130XE Microwave Oven manual .
good luck .
rate please !
Mar 19, 2010 | Whirlpool MH7130XE Microwave Oven
Oven lights won't come on, bulb good, no volt. to socket, is there a fuse
Well here is the delima...Customer changes one of the light bulbs without unplugging unit.....this allows a cap. to discharge on the main computer PCB and zaps the on/off light function.
Contact whirlpool customer service they may may help you out.
This is a known issue.
Hope this helps
Mike
Jan 09, 2010 | Whirlpool MH7130XE Microwave Oven
I have a 10 year old MH7130XE Whirlpool microwave oven. The oven and key pad both work, and the oven heats just fine. The problem is the oven begins running as soon as you open the door...without pushing...
I'm assuming you mis-typed and meant the oven begins running when you SHUT the door and stops when you OPEN the door. Please tell me this is what you meant! If the microwave oven runs with the door open, UPLUG IT IMMEDIATELY AND DO NOT USE IT!!!
If the oven begins running without pushing the start button then the controller is bad or the Start button is worn out and making contact without pushing it. (Most likely it is your controller.) Generally, it is not worth the cost to replace the controller on a 10 year old microwave. Probably time for a new one.
But if you want, you can call Whirlpool and see what they suggest at 800-253-1301.
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Oct 18, 2009 | Whirlpool MH7130XE Microwave Oven
Cooktop bulb broke off inside receptical. Removed all, no work.
Try another bulb. Sometimes even new bulbs are defective.
Mar 20, 2009 | Whirlpool MH7130XE Microwave Oven
Cooktop/Countertop lights will not turn off
Whirlpool told you wrong. Part number is #4158940 is a door switch, but that's not the problem.
They'll sell you parts or refer you to a local servicer, but they won't help you repair your unit.
On this particular model, the solid state relay PH1 near the bottom right corner of the board will be the culprit.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feb 09, 2009 | Whirlpool MH7130XE Microwave Oven
Whirlpool MH7130XE Microwave Oven Logo
287 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
