Question about Vacuums
Where can a fan blade be purchased for a 2006e series dehumidifier
  • 4,348 Answers
This can come from the manufacturer, or perhaps an appliance store.
Posted on Mar 15, 2011
I just purchased a used portable air conditioner, a danby dpac120068. It is not producing any water when in dehumidify mode. Also, it seems as though the air conditioner is on even when in dehumidify...
The A/C will be on when dehumidifying... that's how it does that...
If it is not collecting water, it is probably because the humidity is too low in the house already...
I would give it more time....
heatman101
May 25, 2011 | Vacuums
Tip
How To Change The Fan or Impeller Blade On a Kirby Generation Vacuum
Greetings,
Below we have shot a video on how to replace the fan blade (also known as the Impeller Blade) on a Kirby Generation 4 Upright Vacuum Cleaner step by step in an easy to understand format. If you'd like to see a repair done by video, please contact us. Also be sure to stop by our website for all of your Kirby Vacuuming needs;
Part 1
Part 2:
If you found this repair video helpful, please be sure to rate the repair as helpful by clicking the Thumb Up Icon at the bottom of the repair page. Feel free to contact me if you have questions on how to do it, or how to purchase the part.
Thank you,
Chris J.
GoVacuum
on Mar 20, 2010 | Kirby G4 Bagged Upright Vacuum
Dehumidifier fan appears to be working, but no water is being collected in the vessel. 'Clicking' noise when in operation
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Feb 12, 2011 | Vacuums
Change direction of rotation?
Some fans have switch on the side or on the top by the ceiling.Steve
Jun 06, 2010 | Vacuums
My Hoover upright vacuum has gotten very loud. I have checked the roller, belts and hoses but I haven't found anything. What could the problem be? thanks
Most Hoover uprights are a "fan first" design, meaning that all dirt enters the motor , hits an impeller fan and is blown from there into the bag. You will need to open the vac, remove the belt and two C shaped clamps holding the motor in place and remove the 4 screws holding the fan cover. Look for a broken or damaged blade on the fan. It is a threaded fan and can be purchased at most vac shops. Reassemble in opposite order.
Post back to advise what you find
Dec 13, 2009 | Vacuums
How to change the fan blade that is used for the suction on the vacuum cleaner?
You will need to get a genuine fan kit form a service center, then elevate the vac and remove the carpet head. From the back of the housing there will be a series of screws facing forward into the front housing, several are counter sunk. Removing them will replace the front face of the housing. You should not have to pry.Look for partly hidden screws
The belt shaft is threaded, once removed pay attention to washer and spacer location in front and back of fan.
Grip the old fan by hand and the shaft with a set of vice grips or slid a long nail through the fan shaft hole to unscrew the shaft.
Installation is reverse order with the shaft and screws hand tight... Post back to say how you make out
Oct 10, 2009 | Kirby G4 Bagged Upright Vacuum
Poor suction
This vaccuum has a Fan Blade inside connected to the motor that spins to create the suction you feel. After a few years of use (and misuse) the blades on this (plastic) fan will be broken off, thus damaging the unit. These Fans are replaceable if you can find where you can purchase a new one. Now, if you have any knowledge of repairs at all, it's not that hard to replace to fix. If you don't feel capable of this though, I suggest you refer to someone more qualified to do this repair.
Oct 10, 2009 | Vacuums
Replace Kirby legend II fan (impeller blade)
In order to replace the fan you will buy a 2 or three piece lexan fan kit containing the fan a spacer and shaft.
You must remove the carpet head and then looking from the back of the machine you will find a series of philips screws on the outer edge of the fan housing facing towards the front, several of which may be partly covered by the motor housing. You will remove the forward facing screws to allow the housing to separate and reveal the fan.
If you are lucky there will be a sideways hole through the impeller shaft allowing you to slip a nail through to help twist the saft to unscrew it while holding the fan .
The shaft will turn off revealing a threaded motor shaft with spacers which the broken fan will slide off revealing a second spacer at the back . Be sure to replace these spacers in the same order when re-assembling the unit. Secure the shaft hand tight. Post back to advise if you need further help
Oct 07, 2009 | Kirby G4 Bagged Upright Vacuum
Vacuums Logo
13 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
