Question about Acer P1100 - DLP Projector 3D
My new projector, Acer p1100, gets overheated very fast. In just half an hour after I turn it on, gets overheated in front, on the right side of the lens.
    Brigadier General:
  • 8,909 Answers
Are the filters clean and I came across one with the exhaust fan the wrong way around. Make sure there is lots of air blowing out of the exhaust.
Posted on Mar 15, 2011
When turning the unit on, powere button changes from red to blue for around 3 seconds, then goes to red off again. Anyone help?
Its due to the complaint of its Power Ballast unit ( Power Control Board). So please contact any one of the service centre in your area.
Sep 29, 2015 | Acer P1100 - DLP Projector 3D
3M SCP712 projector shuts down after an hour--can't turn back till it cools
Hello
the problem is with overheating. Look whether the cooling fan doesn't work or air filter is cloggy with dust. OK.
Nov 08, 2011 | 3M SCP712 Projector
Sanyo PLC XT11 Device turns on, counts down from 30, and then turns off and uses fan on high in what appears to be a cool down cycle. The lights verify that the device thinks it is overheating. Lamp...
The air filters on projectors are very important.
You need to take them out and clean them regularly, if not projector can overheat.
Also check all the grill are not blocked, using a vacuum cleaner with a brush attachment on a gentle **** is the way to clean them off.
Please dont forget to vote this answer was helpful
Many thanks
Feb 18, 2011 | Sanyo PLC-XT11 Multimedia Projector
On power up, it seems to start but shuts down in three seconds after starting. The sequence can be repeated with the same results.
i would imagine it is having a capacitor overheating... i just had one with dry joints on the capacitor and it took 4 hours to start up...... hope this helps i would recommend taking it in to get it looked at if you want the projector...... also the capacitor which will be most likely causing this will be located on the main power board which is located in the front right hand side of the projector under the main display board which is held in place b y three screws... cheers hope this helps
Feb 08, 2011 | Sony VPL CS5 Multimedia Projector
Lamp lights red
1. setting the color balace, red on normal condition
2. clean the lens
Jan 21, 2011 | Acer P1100 - DLP Projector 3D
I have recently bought a second hand 3M projector, and when turned on the screen shows half Blue (i think) and half Red and when used via the laptop the red shows through on the right hand side, can anyone...
first reset the settings to factory default. you may have to realign the lcd panels and make sure the panel ribbon cables are properly seated. otherwise, you have a main board issue.
Jun 22, 2009 | 3M MP 8765 Multimedia Projector
Right half of screen is Black with a White vertical stripe
Yeah, I have this exact same problem, except my mom slammed my laptop shut in frustration around half an hour ago, so that's why it's like this. The right half of my screen is black with two colorful stripes (mostly white), but the left half is visible. I've researched a bit and found out that this is because the LCD in your monitor has burnt out, and since you don't have a monitor to attach, the only thing you can do is to go to where you bought the laptop and either get it fixed for free or return it for a brand new one (if your warranty still stands). If not, you might as well get a new laptop. I think my warranty has expired, so I'll get a new laptop, hopefully.
Hope this helps!
~Sam.
Jun 08, 2009 | HP Compaq FP 7317 17" Flat Panel LCD...
HD72I WORKS FOR 30SECONDS AND THEN SWITCHES OFF
I had the same problem with very few hours on the lamp. Sent it back to the factory and they said the fan was overheating causing the bulb to shut down. They replaced the fan and the bulb for free under warranty. I noticed before I sent it the projector was putting out an incredible amount of heat. MUCH better after fan replacement.
Aug 27, 2008 | Optoma HD72 Multimedia Projector
Acer PD100 overheating
I found that by resetting the factory defaults the problem goes away. I have experienced this issue a few times after attempting to correct colors.
this projector does not have the best picture or color quality.
May 07, 2008 | Acer PD100 Multimedia Projector
Projector overheating and turns off after 20 mins
I have a HP VP6111 projector that works fine on a table top but overheats ( overheating ) when turned upside down and hung from my ceiling. My solution...I went to Circuit City and bought two 80mm computer fans. I also purchased a 12V power supply from Radio Shack. I put one fan on front of my projector and the other on the back of the projector and wired them into the 12V power supply. I mounted both fans with velcro. The front fan pushes air and the rear fan pulls air. The projector now runs fine without shutting off. The fans are 12V and push 34 cubic feet per minute of air. I am very happy with this solution.
Oct 25, 2006 | Compaq Microportable 2810 Multimedia...
Acer P1100 - DLP Projector 3D Logo
254 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
