Question about Pinnacle Studio Ultimate 12 for PC
Cannot create disc because the selected menu has no links pinnacle 14
3 Suggested Answers
SOURCE: Creating a Disc project
Loaded a patch Studio 11.1.2 solution is valid for Pinnacle ultimate Ver 11
Posted on Jul 10, 2008
hawkform
  • 217 Answers
SOURCE: when i go to make movie mode a panel comes up
Studio error: Cannot create disc because the selected menu has no links
This error will occur if a menu has been added to the project, but links to chapters have not been properly set. It is not enough to just add a menu to a project; it is also required to have at least one point in the project associated with the menu.
When adding a menu to a project, you will be prompted to let Studio create chapters automatically or you can choose to create chapters manually. If you choose to have Studio create the chapters automatically it will always add at least one chapter and this error should never occur. If you choose to add chapters manually, it is then required to add at least one chapter. Here are basic instructions to accomplish this.
  1. Double-click on the menu in the timeline to bring up the Menu Properties.
  2. Select that video clip in the timeline that you would like to link to the menu.
  3. Right-click on the video clip in the timeline and select "Set Disc Chapter."
  4. Alternately you can drag the clip to the button in the menu displayed in the Menu Properties window.
For additional information on creating menus, please see the Disc Menus section of the Help file by going to Help -> Help Topics in Studio.
Posted on Dec 08, 2009
Transitions not working Some 2D Transitions and all alpha magic transitions missing
Pinnacle 16 came with all the transitions. I used them for a few years. Now the tab and folder are gone.
Dec 10, 2013 | Pinnacle Studio Ultimate 14 for PC
Cannot get unlock code for dolby 2 ch encoding,decoding for pinnacle studio 14
You can get encoding unlock code for Dolby 2 ch from thisweb-link: http://www.serialportal.com/serial.php?im=57153. You candownload pinnacle studio 14 decoder from "http://www.giveawayoftheday.com/pinnacle+studio+14+decoder/".,if you face any problem then you canvisit http://www.pinnaclesys.com/PublicSite/us/Products/Consumer+Products/Home+Video/Studio+Family/Studio+Plus+12+Ultimate+Support/Download+Area/Drivers+-+Updates/Studio12_1_3.htm?mode=documents&Display=1. Good Luck.Hope this will help you.
Jul 01, 2011 | Pinnacle Studio Ultimate 14 for PC
Pinnacle Studio Ultimate 14 - I can't get video projects to burn. Photo projects work well. I use Dazzle to load video from a vhs into Pinnacle. Seems to work well and I create a project. When I go to...
A general workaround would be to let your software create an ISO image instead of burning a disc. Then burn the ISO with a known-good burning software (many user here - me included - recommend ImgBurn).
Feb 17, 2011 | Pinnacle Studio Ultimate 14 for PC
Export:error:real time c:\users\owner\appdata\local\microsfolder\render\my movie 848e009f\alternate\render\my movie 848e009f\dvd\studiosequence\temp' Help - what does this mean? What should I do?
Hi and Welcome,
If you are experiencing Export Errors using Studio, the following FAQ should help:
1. UPDATE TO THE LATEST PATCH:
Click here for the latest Studio 12 patch
There is no patch available at this time for Studio 14
2. ENSURE BACKGROUND RENDERING COMPLETES:
Allow the green bars that appear over clips that have had filters, transitions or other effects added to complete before going to the Make Movie stage.
3. ALWAYS REINCODE ENTIRE MOVIE
If after installing the latest version of Studio, the Export Error persists and you are attempting to create a DVD, then in Studio click on the Setup pull-down menu and select Make Disc. On the top portion of the Make Disc tab make sure there is a check in the box for the setting "Always re-encode entire movie", then click the OK button. Create the DVD again.
4. DELETE AUXILIARY FILES
Delete the auxiliary files before rendering. To do this, go to File >> Delete Auxiliary Files. This will bring up a window to chose which auxiliary files will be deleted. Select the option to delete the files for the current project. Once this is done, try to output the project.
Oct 12, 2010 | Pinnacle Studio Ultimate 12 for PC
I get an error message to use a blank or erasable DVD
I would try simply copying one of the already completed discs using a stable and well known burning program like Nero. Programs like Pinnacle can be very temperamental when exporting their projects to disc.
Jul 19, 2010 | Gear Head 8XDVDEXT DVD External Slim...
Pinnacle 14 crashes at the same point when making movie.
Hi
My pinacle 14 crashes when I try to make a disc, if I make a disc from other movies i have edited it works just the current project we are working on , I have deleted the Aux files
Cant move
Peter
Apr 28, 2010 | Pinnacle Studio Ultimate 12 for PC
Pinnacle studio 12 .stx fil
Hi and welcome to Fix yah,
I would suggest to you to finished edit your project and after that click on make movie tab or the number 3 tab of your Studio then do this procedure.
Disc Type : DVD
Audio Compression : PCM
Video Quality : Automatic
Use Progressive Encoding : NOT checked
Always Re-encode Entire Movie: Checked
Burn Options: Create Disc Content and then burn.
Current Media : Should show what DVD Disc should be used.
Target Media: DVD 4.7 GB
Copies : 1
Write Speed: lowest possible
Let me know what happen.
Feb 14, 2010 | Pinnacle Studio Plus Version 11
When making / creating a DVD, how do you make the "Play" button work, so that the result of your movie you will select the "Play" button and your movie will play. Also how do you create chapters, but allow...
hi there,
you can find the manual here :
Pinnacle Pinnacle Studio Ultimate Version 11
and in other languages please look here :
ftp://ftp.pinnaclesys.de/Manual/Studio%2011/
I suggest to look under the word :
Scene detection ...............26
The Video Scenes section ....... 40
CHAPTER 9: DISC MENUS.... 175
Output to disc media ... 243
Have a nice computing
Hope that helps
IF NOT then try to return here
Please rate my answer
Dec 09, 2009 | Pinnacle Studio Ultimate Version 11
When i go to make movie mode a panel comes up which readsas follows "cannot create disc because the selected menu has no links"
Aug 13, 2009 | Pinnacle Studio Ultimate 12 for PC
Jul 09, 2008 | Pinnacle Studio Version 9 for PC
Pinnacle Studio Ultimate 12 for PC Logo
284 people viewed this question
Top Pinnacle Computers & Internet Experts
Alun Cox
 Ian Kayhan
Ian Kayhan
Josh Levin
Josh Levin
Are you a Pinnacle Computer and Internet Expert? Answer questions, earn points and help others
