Just purchased a 2TB iomega eGo ext drive. Took it out of the box, connected it to me MAC and started backing up the data on my computer. AFter a few minutes it disappeared from my desktop - now it won't mount again no matter what I do. I tried different UBS ports, cables, rebooting, turning the drive off & on - all the solutions on the Iomega site. The light on the eGo either flickers constantly or it stays on without blinking on computer start up. I can't get it recognized my any of my PC or Mac computers. It must be defective but I can't send it back with partial data on it and I can't get it mounted to erase the data that transferred. What should I do to get it to mount?
  • geri_mancini Mar 15, 2011
    I suppose that's a solution but if I open the drive, I won't be able to return it to Amazon....but it may be the only way out of this.
  • 72 Answers
If problem is with drive, this may not work. If problem is with enclosure, you have to open the enclosure, extract the drive and get a HDD dock (usually around $15-$30) and access the drive that way.
Posted on Mar 15, 2011
  • 1 more comment
  • jusquitsmokn Mar 15, 2011
    If the data you did manage to transfer over is not security sensitive, you should just just have Amazon replace it. If it is sensitive, you may have to extract the drive and wipe it. Or maybe find somewhere/something with big magnet and pass it over a few times.
    Thanks - the data is security sensitive so I do have to erase it. I'll take the drive out and put into a housing, wiping it clean and place it back before I return it to Amazon. Now I'm just confused as to what manufacturer to try next. My faith in Iomega has been shot!. Thanks for helping.
    It if turns out to be the drive itself, I would highly recommend that you get a Samsung internal 3.5" HDD and purchase a separate enclosure for it. Samsung spinpoint drives are usually very highly rated.
    You can check out newegg.com for some cheap external enclosures.
Iomega eGo Helium 1TB has a damaged PCB. Local 1TB Casing do detects the HDD and its Drives. BUT asks for Formating the Drives. Which case can be purchased. how to recover the data. ?
It might be tricky, but you can remove the hdd from its casing, and install into a pc with compatible connections as a slave drive. Make sure to handle the drive carefully, and try to copy any data you want to another drive on the pc, then run chkdsk X: /f /r on the affected drive.
Another possible solution is to rightclick on My Computer, Manage, go to the drive mangement menu, and rightclick on the drive, and import it into your system so that windows can recognize it.
Mar 07, 2015 | Iomega Corp iomega eGo Helium 1TB 2.5"...
I have two Iomega 1TB 2.0 USB eGo harddrives with the encyption utility. I have the Windows 7 O/S. Initially, I plugged both harddrives (eGo) into my laptop, and created the password for each of the...
Iomega Utility are not Specific to the current device.
My iomega ego external hard disk was working properly but when i connected it today the encryption utility show that-Iomega Utility are not Specific to the current device and no any area shown to type password. My drive contains lots of valuable data. How can I acess into my drive. But the virtual drive is shown.
Aug 25, 2011 | Iomega eGo 1TB USB 3.0 Portable - Ruby Red...
How do you get the Iomega eGo Hellium 350GB hard drive to be recognized and initialized by Microsoft Vista Operating system? Have tried the instructions from Iomega and they do not work. The system...
one thing that is possible, is that you may have another drive letter assigned to the letter the iomega is trying to use.
Try this....Click on your start orb and type in Disk Management.
open the Disk Management utility in Windows and see if you see the iomega drive listed in the list of disks on the bottom.
If you DO see the iomega drive there, make sure it shows a healthy partition (It should say something like Fat 32 or NTFS as the file system type...if it shows "RAW" or "damaged" or something like that, you may need to erase and format the drive)
Then, try right clicking on the drive and choosing "Change Drive Letter and Paths..."
from there try a new drive letter in case you already have another peripheral using the drive letter the iomega drive is trying to grab. This could cause Windows to recognize the drive but still be unable to see it in your explorer.
Good Luck
May 09, 2011 | Iomega eGo Helium 1TB USB 2.0 Portable,...
I have iomega eGo portable hard drive with encryption... how do I create new folders on the drive to backup my data to?.....
click start all programs accessories open windows explorer right click on your Iomega then usually you would just right click an array of options will open up select new folder you can name the folder to anything you want as long as its not the same as the ones you already have on your computer
hope this helps
Apr 12, 2011 | Iomega eGo 1TB USB 3.0 Portable - Ruby Red...
Iomega eGo 1TB USB 3.0 Portable portable harddisk 500GB. while connected to PC show an error on desktop "insufficient power on USB hub port" . pls suggest
Few different things are possibilities.
1. Are you connecting the device via USB 3.0 to the USB 3.0 adapter on the computer? 2. Try switching out your USB 3.0 cable for a different one. 3. If you are using the USB 2.0 instead. Make sure you are using the USB Y cable for the device and not just a standard USB 2.0 straight cable. Using the USB Y cable. Plug the cable into the device first, then make sure to plug both USB's into the computer starting with the short side USB then the longer side USB second. Also try using the USB's on the back side of the computer as they will supply more power than the USB's on the front of the computer.
Dec 20, 2010 | Iomega eGo 1TB USB 3.0 Portable - Ruby Red...
How to connect iomega ego blackbelt 3.0 to mack and change the partition
Mac decided not to go with USB 3.0 so you will have to use the USB 2.0 Y cable.
Using the USB Y cable. Plug the cable into the device first, then make sure to plug both USB's in to the computer starting with the short side USB then the longer side USB second. Also try using the USB's on the back side of the computer.
Formatting with Mac OS X, version 10.5 or above. 1. Make sure you have copied any needed files to another location. 2. Select Applications > Utilities > Disk Utility 3. In the left hand column, click on the drive icon for the Iomega Hard Drive. Make sure you click on the high level icon, not the second level volume icon. 4. Select the Partition tab. 5. Change Volume Scheme from Current to 1 Partition. 6. Select the format type from the Format drop-down menu. Select Mac OS Extended (Journaled) (recommended) or Mac OS Extended. 7. Click on the Options button. 8. Select the type of partition you want to use: GUID Partition Table - for boot ability on Intel-based Macs Apple Partition Map - for boot ability on PowerPC-based Macs Master Boot Record - if you will use the drive on a PC as well as your Mac. Use this option ONLY if you selected PC-DOS as the format type. CAUTION! In most cases, the computer will fail to format the drive as a Mac OS Extended (HFS+) partition using Master Boot Record. For best results, always choose GUID Partition Table (Intel) or Apple Partition Map (PowerPC). 9. Click OK. 10. Click Apply (10.5-10.6) or Partition (10.4). The drive is ready to use when the format completes.
Nov 28, 2010 | Iomega 500GB eGo BlackBelt Portable 34621...
Iomga eGo drive data back-up for Vista need transfer to Windows 7
try to connect it to another computer that runs vista, reformatting is never a good thing. the portable hould be read on any other computer, but if you connect to another computer that have vista take it off and keep it on the other computer for a little (like someone elses computer) and put it back on to the computer with windows 7, reformat it and try to put our stuff back on then try again.
Jun 19, 2010 | Iomega 250GB Ego Portable HD Red 250 GB...
IOMEGA eGo portable hard drive won't copy files from mac
Format your hardrive for Mac OS:
Go to Disk Utilities under the go menu in your finder. Select the external drive and click on the erase tab. Clikc erase again and it formats the drive. You can now copy files onto the drive.
Oct 29, 2008 | Iomega (33090) 250 GB Hard Drive
Computers & Internet Logo
104 people viewed this question
David Payne
David Payne
