Question about Asheek Khan Footy Star
I installed footy star 1.3 on my computer but it does not work as i have windows 7. I tried changing the compatibility mode but this did not work either. It mentions that the program can't start because MSVBVM50.DLL is missing from my computer.
    Problem Solver:
  • 10 Answers
When you installed your game there must be a problem installing the game . try installing it again . and paste the exe files of this game
Posted on Mar 16, 2011
Windows 7 will not recognise vdr-m70 dvd camcorder
Panasonic supplied software for the VDR-M70 for Windows 98 through XP on the CD. Due to changes in the OS over time, the installer can't run under Windows 7. Panasonic has not updated the drivers for Windows 7 and Microsoft indicates that it is not compatible with any version of Windows 7.
There are work-arounds depending on your version of Windows 7. If you have the 32-bit OS, try using the compatibility mode. To find out which version of Win7 that you have, click Start > Control Panel > System and Security > System. If the name of the OS ends with x64, then you have the 64-bit version of the software. Otherwise, you have the 32-bit version.
For the compatibility mode, right click on the installer on the CD (browse Computer). Choose Properties and then click on the Compatibility tab. Select Always Run this program as and an older version of Windows (XP). Apply and Save your changes. Then right click again on the installer and choose Run as Administrator.
This may not work (and won't work for the 64-bit Windows 7). If it doesn't work, you need a machine with an older version of Windows. This can be a second computer, a dual boot computer or a virtual computer (if your hardware supports virtual computing). For most options, you will need a licensed copy of the older version of Windows.
If you have Windows 7 Pro or Ultimate or upgrade to one of them, you can have a virtual version of XP for free. Download and install Virtual PC and XP mode from Microsoft in order. Then install the software for the camcorder in XP mode as if it were your only computer. (Of course this doesn't help if your hardware doesn't support the Virtual PC.) Other virtual computer programs are VMWare and Parallels.
Note: you can not directly share files or hardware between the Win7 and the virtual computer. You have to put files on an external drive (optical, flash drive or other external hardware) to share them.
I hope this helps.
Nov 12, 2011 | Panasonic Palmcorder VDR-M70 DVD Camcorder
How to connect samsung gt-s5230 to windows 7 i tried to install new pc samsung from cd which was originally with my phone but could not do it.This program does not work on my computer i have no memory card...
I don't know why the software wouldn't work on your computer.. If it is NOT compatible with windows 7, right click on the installer (usually setup.exe or installer.exe) then choose properties and then choose "compatibility mode" and choose the compatible OS for it.
You can also transfer the files from your mobile phone by using bluetooth connection.
Sep 27, 2011 | Samsung Star GT-S5233 Cell Phone
I can't install my Creepnight 3D Pinball game on my Windows 7 Computer.. says can't support 64 Bit
The Windows 7 should automatically convert compatibility for software, but to force compatibility manually:
1. Right-click the installer, and go it's properties (this is the last option in the drop-down list).
2. Click the compatibility tab
3. Check the compatibility mode box and select the option from the list that matches the operating system you know the game last worked on.
4. Apply the changes, press OK, and re-run the installer.
Jul 19, 2011 | Sierra Online, Inc. 3D Ultra Pinball Creep...
The installation says that is not compatible with my windows 7
The software is very old, so old that it doesn't run any compatibility modes for windows 7. You need to either run it on windows xp, or use something like virtual box to run it through xp.
Jul 02, 2011 | Global Star Software Army Men: Sarge's War...
I will start the game, but the game says "you do not meet the minimum system requirements". But my computer meets the minimum requirements. I have played this game also in the past, but removed...
try running the game in compatibility mode. To change compatibility settings manually for a program, right-click the icon for the program, click Properties, and then click the Compatibility tab.
For more information check out http://www.sevenforums.com/tutorials/316-compatibility-mode.html
Jun 20, 2011 | Global Star Software Airport Tycoon 2 for...
Can I install Star wars episode 1 The gungan frontier on a windows 7 machine? I can't get it to work, is it even possible?
Gungan Frontier is a 32-bit Win9x game from 1999. It should run fine on modern Windows under compatibility mode for Win 95/98.
On 64-bit machines however, the QuickTime 3.0 installer will fail because its installer is a 16-bit application.
The game will still install, but it will detect that QuickTime 3.0 is not installed and refuse to start. You can trick the game into thinking it's installed by obtaining a valid QuickTime.qts, and placing it into System32 (or the game folder), and adding the following registry key:
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Apple Computer, Inc.\QuickTime\3.0]
Jun 16, 2011 | Lucas Star Wars Episode 1 The Gungan...
Pls. provide me link for panasonic kx-mb772 drivers for win 7
Hello, a windows 7 driver doesn't exist, sorry. The good news is, you should be able to run it in compatibility mode. Instructions can be found here: http://www.sevenforums.com/tutorials/316-compatibility-mode.html
May 10, 2011 | Computers & Internet
My lexmark printer is not printing from the computer. i have windows 7 on my computer . could it be that it is not compatible with windows 7?
You are correct this printer is not supported under Windows 7. There are workarounds that may work if you want to try them.
First option is the compatibility mode. To try this, download the driver for an older OS version from the Lexmark site, http://support.lexmark.com/index?locale=EN&page=product&userlocale=EN_US&productCode=LEXMARK_X125&focusedTab=DOWNLOADS#1 , and right click on the installer. Then choose Properties and then the Compatibility tab. Turn on Run program as Compatible with the appropriate OS. Then right click again on the installer and choose Run as Administrator. Then check if the program itself is running in the compatibility mode by right clicking again and choosing Properties. This is more likely to work if you have Windows 7 32-bit. I do not know if this will work for your specific printer.
A method that will work is to use a computer (virtual, dual-boot, or true second machine) with an older version of Windows installed. If you have Win7 Pro or Ultimate, you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install the XP software from the above site in the virtual computer and it will work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS. Please note that the virtual computer can't share files directly with the main computer. You'll need to save files to external or removable media (optical media or flash drive, for example) to share them.
I hope this helps.
Apr 23, 2011 | Lexmark X125 All-In-One InkJet Printer
I bought keyboardworks v1.1 it worked fine for my old xp computer. Now I switched to windows 7 and it does not work. Any fixes?
Since this software was designed to work with Windows XP or earlier. It may not run in windows 7 normally, but you can run this application in Compatibility mode.
Windows 7 comes with Program Compatibility troubleshooter, using which you can run older programs in compatibility mode.
To run the Program Compatibility troubleshooter
1. Open the Program Compatibility troubleshooter by clicking the Start button and then clicking Control Panel.
2. In the search box, type troubleshooter, and then click Troubleshooting.
3. Under Programs, click Run programs made for previous versions of Windows.
4. This would scan the computer for incompatible applications and list them, keyboardworks .
5. Click next. this will try running in Windows XP mode.
6. If sucessful save the setting and u should be good to go, else try installing this application in Compatibility mode.
7. right-click choose properties on setup.exe
8. click on compatibility tab. put a check on run this program compatibility mode for and choose windows XP
9. put a check on run this program has administrator. cluick apply and ok and install this application.
10. run the application, if it does not work repeat the steps 1-6.
May 18, 2010 | Computers & Internet
Hi Name is Joe.
Resolution
Installing on a Windows Vista computer
Creator 2010 requires a minimum of Windows Vista Service Pack 1 for installation. You can either perform a Windows Update (recommended) or install Service Pack 1 for Vista here.
Installing on a Windows 7 computer
The issue might be caused by the Creator 2010 setup package running in Windows Vista compatibility mode on Windows 7. Please use the following steps to turn off Vista compatibility mode for the Creator 2010 setup package:
  1. Right-click on the setup package and choose Properties.
  2. Click on the Compatibility tab in the Properties window.
  3. In the Compatibility mode section, uncheck the box that is labeled Run the program in compatibility mode for Windows Vista.
  4. Click OK to save the changes.
  5. Re-run Creator 2010 the setup package.
May 04, 2010 | Roxio Creator 2010 Full Version for PC...
Video Game Consoles & Games Logo
193 people viewed this question
Top Asheek Khan Video Game Consoles & Games Experts
James Wishart
Josh Whitehead
Josh Whitehead
Are you an Asheek Khan Video Game Console and Game Expert? Answer questions, earn points and help others
