I have a clock that will only come up as pacific time zone time. I am in central time zone in the usa. How can I correct this as it does not allow me to input any time changes manually? I have tried resetting it 3 to 4 times now. Do I have to let it go for 24 hours or something in order for it to correct itself or will it always stay. It also did not change after daylight savings time and was wrong for 3 days after until I reset it. Now like I stated it only comes up with Pacifi standard time. Skyscan Model: 38229-1
  • 72 Answers
1. press "MODE" (it will show the alarm time)
2. press "ADJUST" (this will switch the time zones)
3. when it is on the desired time zone, press "MODE" to return to the clock.
Posted on Mar 15, 2011
  • Charojay Mar 19, 2011
    I am having the same problem since our time went to DST. My zone is eastern and my clock is on saying that it is on Mountain. Time Zone. Model is 31320. I see no word or area called "adjust". Where would I find "Adjust"?
  • abstutheit Jun 29, 2011
    I have +/- buttons on the front of my clock that I used instead of adjust and it worked using these directions.
    Guru:
  • 276 Answers
Press mode key at any time to exit.
Press mode, then press adjust to change time zones.
TO SET TIME AND DATE:
Press and hold alarm on/off for about 5 seconds until hour flashes.
Press adjust to change hour.
Press alarm on/off to move to minutes. Press adjust to change minutes
Press alarm on/off to move to seconds. Press adjust to change seconds
Press alarm on/off to move to month. Press adjust to change month
Press alarm on/off to move to date. Press adjust to change date
Press alarm on/off to move to day of week. Press adjust to change day of week
Press mode key to save to exit.
TO SET ALARM:
Press mode to go to alarm screen (AL shows above temp)
Hold the alarm on/off button for about 5 seconds and the hour will flash.
Press the adjust button to change the hour.
Press the alarm on/off button again to move to minute
Press the adjust button to change the minutes
Press the mode key to save and exit
MODEL:WT-8005 CLOCK IS 1 HOUR AHEAD HOW DO I TURN IT BACK?
Check both of these
  • Daylight Saving Time Automatically Updates (DST) (On/Off Option) applies to both USA and UK
  • U.S. Time Zone Selection: Eastern, Central, Mountain, Pacific (applies to USA only)
  • Mar 15, 2011 | La Crosse Radio Controlled Atomic Clock
    Tip
    Procedure For Setting Time Zones For Emerson Clock Radios
    Setting The Time, The First Time
    IMPORTANT: The first time you connect your new SmartSet® clock radio to
    the AC outlet the internal computer will automatically set the time correctly for
    the Eastern Time Zone, which is the initial default setting. The display will
    scan for a few seconds and then show the correct Day and Time in the Eastern
    zone. If you live in the Eastern Time zone, there’s nothing else to do. Your
    clock is set correctly and running.
    If you do not live in the Eastern Time zone you must change the default zone
    display to your own zone. You only do this one time and the SmartSet® will remember
    the new default zone setting and will always return to that setting after a power
    interruption.
    There are 7 time zones programmed into your SmartSet® clock radio as follows:
    ZONE 1 — Atlantic Time
    ZONE 2 — Eastern Time (Default Setting)
    ZONE 3 — Central Time
    ZONE 4 — Mountain Time
    ZONE 5 — Pacific Time
    ZONE 6 — Yukon Time
    ZONE 7 — Hawaiian Time
    To change the default time zone display, depress the Time Zone button.
    The number “02” will appear on the display
    indicating that the default zone is ZONE 2,
    Eastern Time
    on Jun 12, 2009 | Emerson Smartset Clock Radio
    Can not set time zone
    Press the triangle shaped button to set the correct time
    zone. It will toggle the clock mode through the four available time zones in the Continental U.S. Above the seconds digits, the LCD display will indicate "P" for Pacific, "M" for Mountain, "C" for Central and "E" for Eastern.
    Mar 01, 2011 | La Crosse Technology WT8005UB Atomic...
    Sentry self setting atomic clock lost the instructions
    Select The Time Zone - For Sentry Self-setting Atomic Clock (ATC - 10)
    The default time zone is Pacific zone.
    1. In the normal time mode, press the MODE key to enter the alarm time mode.
    2. Press the SET key to change the time zone.
    each press of the SET key will move the time zone back one hour
    P= Pacific M=Mountain C=Central E=Eastern
    3. Press MODE key when correct Time Zone is highlighted.
    I think the Instructions may tell you to use the ADJUST key instead of the SET key.
    ADJUST key does not work for TIME ZONE change, SET key works.
    This will set your clock to your chosen Time Zone for normal time.
    Instructions for the ATC20 are located at the following url
    http://www.sentryindustries.com/pdf/instructions/ATC20_instructions.pdf
    Sep 28, 2010 | Office Equipment & Supplies
    Mt atomic clock is always 2 hours slow no matter
    How to Change the Time Zone
    Press and hold the “-“ button for 3 seconds the letter P will appear where the seconds are than press and release the “-“ button until the correct letter for your time zone appears. The four time zones are P is Pacific, M is Mountain, C is Central and E is Eastern Time zone. Press the SET button to confirm or leave the setting to confirm and exit automatically.
    Sep 26, 2009 | Acu-Rite Adagio Clock Radio
    How do you set the alarm for pacific standard time on the emerson
    Here is the procedure for setting the time zones for your Clock/Radio. Setting The Time, The First Time IMPORTANT: The first time you connect your new SmartSet® clock radio to the AC outlet the internal computer will automatically set the time correctly for the Eastern Time Zone, which is the initial default setting. The display will scan for a few seconds and then show the correct Day and Time in the Eastern zone. If you live in the Eastern Time zone, there?s nothing else to do. Your clock is set correctly and running. If you do not live in the Eastern Time zone you must change the default zone display to your own zone. You only do this one time and the SmartSet® will remember the new default zone setting and will always return to that setting after a power interruption. There are 7 time zones programmed into your SmartSet® clock radio as follows: ZONE 1 ? Atlantic Time ZONE 2 ? Eastern Time (Default Setting) ZONE 3 ? Central Time ZONE 4 ? Mountain Time ZONE 5 ? Pacific Time ZONE 6 ? Yukon Time ZONE 7 ? Hawaiian Time To change the default time zone display, depress the Time Zone button. The number ?02? will appear on the display indicating that the default zone is ZONE 2, Eastern Time I will give you the web link for the owners manual so you can find any other information you might need for your Clock/Radio. (http://www.emersonradio.com/owners/iPod%20Series/iC200_042007.pdf) copy this web address and paste it in the address bard of your browser and it will take you to a pdf copy of the owners manual. I hope this information help you with your problem.
    Apr 27, 2009 | Emerson Smartset Clock Radio
    Can not change the Brookstone Projector clock from Pacific time. We live in eastern time zone. where do I get a manual
    Choosing a time zone. To select Pacific, Eastern, Mountain or Central time zone, press ZONE button inside battery compartment of clock unit.
    Nov 11, 2008 | Audio Players & Recorders
    Sharp Atomic Clock spc 373 won't display correct time/zone
    To change the time zone press the "time" button, on the front the space that shows the date will change to show the time zone. With the time zone showing press the "up" or "down" button to get to the correct time zone.
    Sep 23, 2008 | Zapf Chou Chou 716212
    Honeywell RC182WB Atomic Alarm Clock with Temperature--stuck on pacific time!!!
    I KNOW HOW TO FIX IT!
    Take off the battery cover, and take the batts out, leaving the outside thermometer working...
    You will have to reset everything but it automatically detects your time zone!
    I just did it literally 2 minutes ago!
    Nov 23, 2007 | Honeywell RC182WR Atomic Alarm Clock - Red
    Time Zone Help
    zone-1 atlantic time
    zone-3 central time
    zone-4 mountain time
    zone-5 pacific time
    zone-6 yukon (alaska)
    zone-7 hawaii
    Oct 28, 2007 | Emerson CKS3029 Clock Radio
    2,587 people viewed this question
     Grubhead
    Grubhead
