Question about Samsung DLP HL-P5663W 56" TV
I have a Samsung 56 in DLP that took a power bump and now will shut off after being on for only about two minutes. What can I try? It is protected by a surge protector so I don't think the surge went to the TV.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • Samsung Expert
  • 177 Answers
Did you hear friction sound from behind unit?, if you hear it, change the color wheel.
Did lamp light before switched off?
and which indicator led in front side are blingking (Lamp ,Temp or fan).
If Lamp, chech the lamp.
If Temp, its mean hight temperature detected . check fan on engine, is it rotate smoothly or not, change that fan if necessary.
If Fan, its mean fan not working.
Thanks
Posted on Mar 16, 2011
My samsung dlp turns on for a few minutes then shuts off with the lights blinking at the front. I've already replaced the lamp. I checked to make sure the door was reinstalled correctly. What could be the...
OK CHECK YOUR VOLTAGE ON THE POWER SUPPLY AND IF YOU HAVE GOOD VOLTAGE ON YOUR POWER SUPPLY YOUR NEXT STEP WILL BE YOUR BALLAST GOOD LUCK AND IF YOU NEED MORE HELP JUST LET ME KNOW HAVE A GOOD DAY
Mar 04, 2011 | Samsung DLP HL-P5663W 56" TV
Samsung DLP making noise and is picture out
Lamp probably went out. Refer to your manual regarding lamp replacement.
May 16, 2010 | Samsung DLP HL-P5663W 56" TV
Why is my 42" dlp tv turns itself off after awhile?
the power supply is not working fine. your tv needs preventive service so that semiconductor, diodes and capacitors are changed on the power supply before it switches off completely on its own.
do it fast
okay
Jan 05, 2010 | Samsung DLP HL-P5663W 56" TV
Samsung DLP
Yup definitely sounds like the ballast, if not then you have a problem in the power supply. Probably some bad capacitors. Call a local tv repair shop.
Nov 28, 2009 | Samsung DLP HL-P5663W 56" TV
My Samsung 61" DLP TV just keeps shutting off within 30 minutes. What is the problem and can it be fixed?
yes is easy to fix you need to replace the color wheel. some sensor in the color wheel cause this problem
Nov 06, 2009 | Samsung DLP HL-P5663W 56" TV
My tv will shut off all by itself while watching
Has the sleep timer been set for a certain time ? If not is it the weather affecting your areas power supply ? I'm not 100% certain but a surge protection socket in the mains outlet might solve your poblem
Oct 15, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung ldp 46 " replaced lamp humming sound fans cleaned and working set continues to turn off every 20 min or so
Humming problem with a Samsung DLP HL-P5063W
picture displays good
Humming randomly starts, but once it starts it hums
May 31, 2009 | Samsung DLP HL-P5663W 56" TV
TV will not power up. No tones, no control with
Possible solution (had it happen to me twice): disconnect the unit from power for aproximately  20 minutes (you must pool the power plug out). Plug it back and try again. Repeat with longer disconnect time if still does not work
Apr 21, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung DLP
First try a "hard rest" , unplug tv for 5 minutes then plug it back in when you go to turn it on hold the power button in for a minute or until you hear a beep , if that doesn't work , could several things , let me know if the hard reset works first.
Robby
Apr 17, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HL-P4663W
could be the lamp, and is about time for a new one
http://fixyourdlp.com/blog/?cat=4
Jan 15, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HL-P5663W 56" TV Logo
99 people viewed this question
Henry  Thomas
Henry Thomas
