My att 2wire modem resets itself when i connect to the network. All the lights are fine and everything is normal until i connect to the network through wifi or ethernet. Once i do that, the system lights go off and it pretty much shuts down. A couple min later they come back on. If there is no activity they stay on like normal. How can i resolve this problem?
    Guru:
  • 370 Answers
Welcome to FixYa! You maybe experiencing problem with the modem itself. The only way you can fix the problem is by resetting the modem. Once done, and the modem is is still acting the same way, you will need to replaced the modem. Please follow the steps below to reset the modem.
Note: Once you reset the modem, all the username and password that you or your ISP configured will automatically be deleted and goes back to default settings.
1. While the modem is on, press and hold the reset button at the back of the modem for at least 30 seconds. The reset button is like a red hole near the DC port. you can try to use a pen or a pin to press the reset button.
2. You can verify if the modem is already resetting if all the light are turning yellow or amber.
3. After 30 seconds, power down or turn off the modem for 30 seconds again then turn it back on.
4. If your ISP configure the modem with a username and password, you will need to contact them for reconfiguration.
5. Once the configuration is already done, monitor the modem if it will do the same thing.
I hope this information will help. Thank you for using FixYa.
Posted on Mar 15, 2011
Att dsl internet on deskop and want wireless for my laptop
Yes you can buy a different DSL modem and that should not be a problem , then once you have the new DSL you just contact ATT and they will set up the settings on it...
Oct 09, 2009 | 2wire 2700HG-B Router (2700HGB)
How do I connect to XBox live w/ ATT 2Wire?
to connect your xbox live wireless to 2wire gateway router you need to go to your xbox menu and click on settings then click A on joystick.Go to network settings then select ip address configure automatic ip. DNS should also be automatic. Under advance tab you'll see wireless you need to click connect.if you are prompt to wype encryption its the 10 digit number enclosed in a bracket on the buttom of 2wire router go to
Aug 19, 2009 | 2wire 2700HG-B Router (2700HGB)
2wire 2701HG-B gateway can't connect locally
Have you got MS CLient loaded in the network settings. If not run network wizward on each machine and then try again. hope this helps Mark
Aug 18, 2009 | Computers & Internet
ATT 2wire-2701HGB modem not working properly
Please loot at his post, i replyed to his question.
Jul 16, 2009 | 2wire 2700HG-B Router (2700HGB)
Problem getting to internet through 2wire 2701hg-b router
how can I connect a 2wire 2701HG-B router to a motorola SB5101modem?
Apr 22, 2009 | 2wire Computers & Internet
No network access to Internet due to modem password change by ATT
So you are saying you cannot login to the router itself due to a changed password. The default login is admin and password (or 1234).
If none of these work then you will have to reset the router back to the factory defaults. There is a reset button on the back of the router. Find a paper clip and press the button for approx 10 seconds or until the test light on the front starts blinking. If all goes well the default login should now work. Remember, anything set before as far as static IP's, Ports, Security will be cleared out.
Good luck and thanks for using FixYa
Mar 18, 2009 | NetGear RP114 Router
2701HGB modem - dsl light flashes red
if all the lights on the modem are Green then it means there's no prob with the hardware. just make sure that you're going to use the right WEP key or wireless password. the network name is 2wirexxx, the X is the the last 3 numbers of the SN which can be found on the bottom of your 2wire 2701HG-B.make sure that your wireless switch is also turned on of course. the wireless light on the modem will lit if it is connected
May 07, 2008 | 2wire (1000-000057-000) Modem
2wire Wireless router not working w/Comcast cable modem
Its almost impossible to connect a 2wire DSL router with a Cable modem. They dont go hand in hand.
Although you can connect the outgoing ethernet wire from the modem in the last ethernet plug on the back of the router and then have the ethernet connections coming from the router. But not wireless. and if you find a way, contact me at jneal2k9@hotmail.com
Feb 03, 2008 | 2wire (1000-400108-001) Router
Wireless not working
Check for the wireless security settings in your modem.. and check if your airport is connected properly, if it is connected properly, then you would get a valid ipaddress, try resetting the modem and reconfigure your wired and wireless settings, if possible , try to upgrade the latest firmware for your modem and then reconfig it..
Jan 21, 2008 | 2wire (1000-000057-000) Modem
Computers & Internet Logo
258 people viewed this question
David Payne
David Payne
