Question about Air Tools & Compressors
What does CH 09 error code mean? Mine is LG Inverter.
  • 54 Answers
What is the model and brand?
Posted on Mar 15, 2011
What does the code on the screen mean flashes between ch and 05 ?
CH 5 on these units indicates a communications error between the indoor and outdoor units. Generally, it will require a replacement outdoor board assembly to repair it. Lookup LG parts on the internet or ring them for your nearest Agent or parts. 800 243-0000
Oct 15, 2016 | LG Art Cool LA181CNW Split System Air...
Tip
Error code CH-04
In LG multi split/cassette type units, error code ch-04 means Float switch Open circuit (High level water alarm). Dis assemble the indoor and clean drain pan.
on Jan 11, 2011 | Heating & Cooling
LG model no LBNC602RSA4. Error code (ch 09)
What is the make / model of your air conditioner. With out that information i cant help you with your ac repair problem. Air Conditioning Tamarac
Apr 14, 2016 | LG Heating & Cooling
What does Fault code ch 26 on lg inverter split system mean?
Get the model number from under the indoor unit and I'll try help you out
Sep 02, 2014 | Heating & Cooling
Lg dehumidifier ch 67 error
Thanks for the post by Posted by Bill L on Jul 14, 2012.
I decided to take a chance and order the new Sensor assembly $20.50 and install it in my LG LD651EBL Dehumidifier which was giving me ch 67 errors. Wala, it worked, the error code is gone and the dehumidifier is now working perfectly! Thanks
Jul 14, 2012 | LG LD651EBL Dehumidifier
CH 52 is showing on controller. Unit will not switch on.
CH-52 Communication error between inverter PCB and main outdoor unit PCB. Check wiring fuses and LEDs . If OK either inverter or main PCB defective
Jan 12, 2011 | LG Heating & Cooling
Our LG Art cool Airconditioner displays the error code CH 21. The unit turns on BUT after about 5 minutes the unit turns its self off. Please Help
Inverter compressor run current high. Check compressor windings all equal 1 to 4 OhmsCheck to earth 50 MOhm minimum, check run current. If high, winding is weak. Solution: Replace compressor.
Jan 11, 2011 | LG LSC183VMA Split System Air Conditioner
Hi, I ve got a aircon LSZ244VM4 inverter and fault code is CH 61.Iam out of warranty 1 yr and the unit has already been replaced 1 time when it was in warranty.So what should i do now and what does CH61...
Ch-61.Condenser coil over 65°C. Check coil and filters are clean and free from debris, and airflow is OK. Check system pressures for non-condesables
Clean coil & filter. If non condensable gas, remove gas and flush out the system. Vacuum and recharge.
Jan 01, 2011 | LG Heating & Cooling
System 3 in-door with system 4 out door inverter. all in door unit show error code CH24 pls help
CH 24-Splits and Multi Splits = High or low pressure trip. Low at 1 bar High at 35 bar check pressures. Multi V = High pressure trip.
Nov 17, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Ch 5 error code
ch5 error code, means that there is a
communication error (serial comunication) between the outdoor and the indoor unit.
Only for LG-airconditioners.
Jan 02, 2009 | LG Art Cool LA121HNP Split System Air...
Air Tools & Compressors Logo
165 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
