Question about Dell Inspiron E1505 Notebook
Error code 2000-0141 no drive detected - Dell Inspiron E1505 Notebook
    Problem Solver:
  • 18 Answers
It sounds like a drive failure, hopefully your data is backed-up. You will more than likely need to replace your hard drive. If your PC is still under warranty with Dell they should replace it for free.
Here is a link to some more information:
http://forums.techguy.org/hardware/772809-dell-error-code-0141-no.html
Posted on Mar 15, 2011
    Scholar:
  • 88 Answers
That error code references a bad hard drive. If you still have warranty call Dell support line as that code means Dell will ship you a new hard drive.
Other options are much more complex like booting to a utility (you have to buy this) which will scan your hard drive sector by sector and try to repair bad blocks.
F6 error code whirpool duet
The F6 error code for this model indicates a drive motor tachometer error. The control board is unable to properly detect the motor speed.
Jan 09, 2016 | Washing Machines
Tip
Error Code Canon iR2200 / iR2800 / iR3300 / IR3100
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Обычная таблица"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Error Code iR2200 / iR2800 / iR3300 / IR3100
Error Code
Detail
Code
Error Name/Explanation of Error
E000
0000
The reading of the main thermistor does not reach 30°C 1 sec after the main power switch is turned on. Or, it does not reach 70°C 2 sec thereafter.
E001
0000
The main thermistor detects 250°C or higher.
0001
The main thermistor or the sub thermistor detects overheating (hardware circuit detection).
0002
The sub thermistor detects about 295°C or higher.
E002
0000
The temperature of the fixing film is as follows:
· has exceeded 100°C, but does not reach 115°C within 1 sec thereafter.
· has exceeded 140°C, but does not reach 150°C within 1 sec thereafter.
· has exceeded 160°C, but does not reach 165°C within 1 sec thereafter.
E003
0000
The main thermistor reading is lower than 140°C when paper is moved.
0001
Low fixing temperature detection after standby (by sub thermistor)
E007
0000
An error in the rotation of the fixing film is detected.
The reading of the main thermistor is 100°C or higher and, in addition, the fixing film sensor does not detect the rotation of the film for 6 sec or more while the fixing motor is driven.
E010
0000
After the main motor drive signal is generated, the clock signal does to arrive within 1.3 sec.
E014
000
After the fixing motor drive signal is generated, the clock signal does not arrive within 1.3 sec.
E019
0000
The waste toner case is full of waste toner.
E032
0001
The DA unit connection is disconnected (after connection).
E051
0000
At start-up, home position is not detected when the horizontal registration assembly is moved 100 mm in the direction of home position.
on Mar 14, 2010 | Office Equipment & Supplies
THE MACHINE MODULE WAS NOT DETECTED DURING THE PHYSICAL INVENTORY It just wants to re-boot, we cannot clear the error. M2500 STORAGE
if the M2500 doesn't display online on the front panel, the host will not detect it. If the machine has problem, it will display an error code after it init failed. Then you will dicide what to do according the error code.
Dec 01, 2010 | Quantum ATL M2500 Tape Drive
Dell studio windows failed to start. error code 2000-0146
the Error code was sited below as the (Disk Self Test) DST Log contains previous error(s)
in case of your error DST log contains previous error(s) doing a
chkdsk /r or a repair reinstall of xp might resolve the issue.
to resolve issue...
Error Code Error Message 1000-0141
or
2000-0141 No Drive Detected 1000-0142
or
2000-0142 Drive Self Test Failed Status Byte=XXh 1000-0143
or
2000-0143 Drive Smart Read Command Failed 1000-0144
or
2000-0144 No Support for Drive Self Test Error Code Error Message 1000-0145
or
2000-0145 Timeout waiting for Drive Self Test to complete 1000-0146
or
2000-0146 DST Log contains previous error(s) 1000-0147
or
2000-0147 Unit (x): IDE status failed. Status byte = (x) Control Code = (x) Msg = (s) 1000-0148
or
2000-0148 IDE ERROR: status (x) (s)
Aug 07, 2010 | Dell Studio 17 Laptop
Error 001, error 808
the e001 code is something is going with the fixing assembly. one of the thermistors could be going bad.
E808 is a Zero Cross error. We most commonly see power supplies or bad wall voltage cause this code.
The following information is coppied from the IR2016 Service Manual.
E808-0000 DRIVE CIRCUIT FAILURE
A zero crossing signal cannot be detected.
A fixing drive motor failure has been detected.
E808 0000 Fixing drive circuit failure
  • The heater does not turn on.
  • A fixing drive motor failure was detected.
  • Check the connector of the fixing film unit.
  • Replace the fixing film unit.
  • Replace the fixing drive motor.
  • Replace the DC controller PCB.
  • Replace the power supply PCB.
M201 - Fixing Drive Motor - FK2-1067 - J202 on the DC controller PCB - E007, E808
Power Supply - FK2-1074
Jun 14, 2010 | Canon iR 2016i Black and White Copier
Error 0141 msg:error code 2000-0141
The hard drive has failed. If you're in warranty, contact Dell for a warranty replacement of the drive - it's a customer-replaceable part.
If you're out of warranty, look on ebay for a good deal on a brand new hard drive for your Dell Inspiron 1525
Nov 09, 2009 | Dell Inspiron 1525 Notebook
After windows sp2 update
0141 error is no hard drive detected. So boot to the BIOS F2 at boot and ensure that the BIOS is seeing the hard disk drive. If it is not, then reseat the drive/drive cable connections and try again. If the drive is detected in bios, then try booting to WIndows, if HDD never is detected, reset bios defaults and reboot, and see if it detects, if still not detected, replace the hard disk drive
Nov 01, 2009 | Dell XPS 420 (dxcwqj1_2) Intel Core2 Duo...
Can't start windows: Hard Drive - No drive detected
The laptop cannot see/detect the hard drive. This means the hard drive is faulty or it needs reaeating.
Remove the hard drive and inserting again, then reboot the laptop, if it still cannot detect the hard drive then it is faulty.
You need to purchase a new one and install Windows on the new hard drive.
Mar 14, 2009 | Dell Inspiron B120 Notebook
Dell Latitude D600
It is the Hard drive on the system. Hard Drive is failing. Another Error code for the Hard Drive is Error Code 7. Check BIOS setup if the system still detects the Hard Drive as well. You may want to consider changing the Hard Drive on the system.
Nov 09, 2008 | Dell Latitude D600 Notebook
Dell Inspiron E1505 Notebook Logo
888 people viewed this question
Alun Cox
