Can't start my 1981 Honda passport C70, have spark, jumpered Red to Black wire on ignition switch. Gassed up & Choke open, switch on handle bar set to run. No battery. Tried push starting but won't stay running. What am I missing here?
Does the battery need to be hooked up and charged to provide voltage to pulser, for spark?Does the battery need to be hooked up and charged to provide voltage to pulser, for spark?
You can't post conmments that contain an email address.
Don't connect both blgack cables. 1 is the ignition cut-off. Probabilly, one of both cables has a yellow or white striping. This is then the ignition cut-off. You won't have ignition if this cable is grounded.
Check also the cable in the area where the handle folds for damages!
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1980 - 1982 Honda Civic
This FixYa Tip is for the purpose of installing an Alarm, Remote Starter, Cruise Control, and / or Car Stereo into the vehicle listed in the subject line.
The wires listed are the ones you will need to successfully complete the task.
Some vehicles require additional relays and / or modules to bypass factory security. If they are required - it will be in the NOTES section below the wiring colors.
The following FixYa TIP is good for all Honda Civics for the following production years:
1980 1981 1982
STEREO WIRING COLOR CHART:
Constant Power: White/Blue Switched Power: Yellow/Red Ground: To Chassis Metal Illumination: N/A Dimmer: N/A Antenna: Drivers Side Pillar
Left Front (+): Red/Green Left Front (-): Brown Right Front (+): Blue/Green Right Front (-): Gray
Left Rear (+): Red/Yellow Left Rear (-): Brown Right Rear (+): Blue/Yellow Right Rear (-): Gray/White
NOTES: - none -
Additional Accessories:
Metra Brand Dash Kit: n/a Metra Brand Wiring Harness: 70-1388 Metra Brand Antenna Adapter: n/a
Constant 12V+: White - Ignition Switch Harness or Use Hot Side of Brake Switched 12V+: Black/Yellow - Ignition Switch Harness Ground: Use Chassis Near Cruise Control Module Hot Side of Brake: n/a - Brake Switch Cold Side of Brake: Green/White - Brake Switch Tach: Blue - Coil VSS Wire : n/a
NOTES: 4000PPM
Vehicles with Manual Transmission require Clutch Switch. Some vehicles may require a speed signal generator and/or other parts/adapters not listed above. Rostra® Cruise Control module switch settings may differ if you use a speed signal generator or magnets and a pick up coil.
Thanks for using FixYa!! Please see my other tips on GPS, Car Audio, Large Appliances, and more.
Possibly a bad ignition coil. Check the connections at the ignition coil,make sure they are clean and tight, If so,..then most likely either A: the ignition coil is bad,or B: the pickup on the stator rotor is bad or the rotor could be rusted on the raised portion where the pickup get its signal.
First- turn on the gas. wait for it to get to the carb. Next switch on- close the choke, give 1/4 throttle, Kick it - if it's a no start after about 4 kicks - open the choke and give 1/2 throttle and close the gas.(your flooded)- 4 more kicks and check the spark plug for wet fuel or dry. If dry- dip the business of the plug in fuel and try again. Still no start- replace the plug.
If all that fails- you can disconnect the ignition switch and that will separate the wiring from the ignition- be careful here because you can not shut it off with the switch it can be killed with the choke or pull off the ignition wire to the spark plug.
Still no start, do a compression test as it needs at least 80# to fire.
You need to check if you have spark and fuel: 1: Remove spark plug and fit it back in the plug cap, crank over to check spark
2:If you have spark check to see if plug is wet or dry (a)If dry, there is a fuel issue and you need to check by the carburettor and tank for fuel and/or any vacuum hoses not connected. (b)If wet you might have a faulty plug or flooded in which case try starting with full throttle and no choke(if Manual choke)
3:If no spark, look for the cutout switch(normally on the right hand side handle bar) to make sure it is on and that there is no water residue on any HT leads etc.
