Question about Xerox 5665 Copier
I replace the printer drum on my 5665 workcentre and I can barley see the print, I am told it the high voltage for the drum is out, Can you help?.
    President:
  • 2,072 Answers
The problem occured right after you replaced the drum ?
You could have a defective drum module, but I would suspect that when you replaced the module and turned the orange handle the developer housing did not cam in properly.
You can remove the left cover and push the developer housing in toward the drum.
Sounds to me like the housing just did not return to the home position.
Posted on Mar 15, 2011
Workcentre 5024. When I press the green LED button to print, why does the machine just freeze?
may have to do a rest after drum replaced and double check your installation, link below will get you to support.
press the helpful button
http://www.support.xerox.com/support/workcentre-5022-5024/support/enus.html
Jan 26, 2016 | Xerox Office Equipment & Supplies
My workcentre pro 416 is printing all copies as all black.
It sounds to me like the High Voltage Power Supply, Biasing Ground, or Blanking Exposure Lamp may be a fault. You could also have a problem with the Digital Scanner unit. But, there is nothing that you can do yourself: EXCEPT: If the unit takes a Toner Cartridge that includes the drum, I would try replacing that first. Then if no joy, your going to have to call out the big guns. Good Luck!!
Jun 13, 2012 | Xerox WorkCentre Pro 416 All-In-One Laser...
My printer has this error: Drum warning! what should I do? What should I replace? Thank you!
"Drum Warning" error indicates that the drum is running out. I think you can still print or make copies, but it will not last long and will run out very soon, at that time, you have to replace the Drum.
Hope this helps.
Good Luck.
Thanks for using FixYa.
Dec 13, 2010 | Xerox WorkCentre M20i All-In-One Laser...
Xerox WorkCentre XD125F- need manual
You can get the spec sheet and the user's guide as PDFs here:
http://www.support.xerox.com/go/results.asp?prodID=XD125f&Xlang=en_US&Xcntry=USA&Xtype=docs&prodName=WorkCentre%20XD125f%20Digital%20Copier%20-%20Laser%20Printer
The spec sheet has the toner cartridge and drum cartridge part numbers (listed as Supplies)
Toner Cartridge 6R914;
Drum Cartridge 13R551
When copier has printed about 18,000 pages the J2 drum cartridge light will come on. The unit will print about another 1,000 pages before the unit stops working until the drum cartridge is replaced.
I hope this helps.
Apr 14, 2010 | Xerox WorkCentre XD125F All-In-One Laser...
Streaks in prints
What I would do is remove all cartridges, wipe the belt w/clean cloth use an air can to clean the machine, check the drum on each cartridge see if there is something, it could be there was a change in Voltage and it burnt the drums. change 1 more toner cartridge to see if that color goes away, if it does then you will know if the drums are the problems.
I've had a problem w gen toners doing the exact same thing, so I had to OEM and it went away. Good luck>
Feb 02, 2009 | Xerox WorkCentre M-24 Color Copier
Workcentre XD125F
Waste ink reservoir is probably full. Needs to be emptied.
Hope this helps. Bud
Jan 26, 2009 | Xerox WorkCentre XD125F All-In-One Laser...
Blurry Copies on Xerox WorkCentre C2424
There are three typical reasons for fuzzy text
1. Y-axis drum rotation problem.
2. Wrong drum temperature.
3. X-axis movement problem.
Sometimes the y-axis encoder will get oil inside and confuse the sensors, causing fuzzy/blurry print.
Most likely the drum assembly will need replaced.
Dec 03, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox xe80 workcentre prints almost black copies
Hello sir; Just replace drum cartridge, it will take care your problem. GOOD LUCK!
Oct 31, 2008 | Xerox WorkCentre XD125F All-In-One Laser...
Replace Drum
your toner has nothing to do with sending/receiving faxes. If you can print to the xerox...something is wrong with the software..
delete and re-install software..Xerox website is useless
check the black sensor that dangles into the paper tray. wiggle it up and down, ahten resintalled the tray
Aug 13, 2008 | Xerox WorkCentre PE16 All-In-One Laser...
57 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
