I get a high pitched whistle from my r94 rinnai. what causes this?
    Brigadier General:
  • 4,736 Answers
It's generally caused by either low gas pressure to the heater. Or what is called a "Cold Burner". If it is a :Cold Burner" ... Once the whistling starts, turn the heater off, wait 3 to 5 minutes and turn it back on and turn the flames to a middle setting. If there is no whistling, set your flame height/temperature where ever you like. The low gas pressure issue would need to checked by a qualified technician. At the same time, have them to check the air mixture control valve on the burner.
Hope this helps solve your problem. Please let me know.
Posted on Mar 15, 2011
Is a high pitched whistling sound at idle a vacuum leak or what?
hissing vacuum leak at idle, louder with open throttle ...
? 1:43
https://www.youtube.com/watch?v=tFoybr865n4
Jun 27, 2010 - Uploaded by fenixus
hissing vacuum leak at idle, louder with open throttle ... i know that my camera is poor and microphone suppresses high pitch ...Hi, my kia picanto engine also sound hissing/humming duringidling with open throttle. ... Loud whistling noise 2000 jeep wrangler 4.0l - Duration: 4:01. by Nasrac72 16,158 views.Missing: vt750c
A Whistle or metal sound with firing... - Honda Shadow Forums ...
www.hondashadow.net > ... > Technical Discussion
Jul 11, 2008 - ... under load (accelerating), that there is a small whistle or even 'tap on metal' high pitch sound ... Pics of my 2008 Shadow Aero 750 (VT750C ... loose bolt vibrating
Feb 29, 2012
High pitch whine
Jul 21, 2009
More results from www.hondashadow.net
Dec 25, 2015 | Goes Motorcycles
I have a 2003 Jeep Wrangler that has a high pitch SQUEALING sound when I release the accelerator. Any ideas what's causing it or how to fix it?.
I know i have the same problem, and i also noticed than when i open the Hood the whistle just stops, so i figure out it must be some air cycling in or out osmewhere, I found out my air intake connected to throttle body was misplaced a weird gap was left open allowing air to whistle. u might wanna check there
Sep 19, 2012 | 2003 Jeep Wrangler
What would cause whistling noise near pully and belt area noise gets louder with acceleration
The engine serpentine belt may be worn or wet. The belt slips, causing a high pitched squealing or whistle noise. The other possiblility is a bearing beginning to go out on one of your belt driven components
Mar 27, 2012 | 1999 Pontiac Montana
2004 honda odyssey making whistle noise
I know this original question was written quite a few months back but I was wondering if you ever found out what the high pitch sound was. I just purchased a used 2005 Honda Odyssey and it is doing the exact same thing. Any advice?
May 15, 2010 | 2004 Honda Odyssey
High pitched whistling
Try changing refresh frequency, color depth or resolution (wait for the whistle to appear before testing). Admittedly, you might have to give up some image quality - less colors, or less resolution. There is probably a problem in the TV syncing mechanism - if you can, try getting it replaced. "High pitched whistles" in video and TV hardware are usually harbingers of bad news.
Aug 24, 2009 | Samsung SyncMaster 245T 24 inch LCD...
Super high pitch whistle from tv, only powering it off helps.
Shut it off and unplug. You have a serious HIGH VOLTAGE problem that could cause a fire. Professional repair needed.
Mar 07, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Hooking up Tandem Rinnai R94 LSi
you will find a master controler at a electrical lighting and hardware store you have to be specific with the model and voltage/amprage rating. they will give you a schematic with the controler. .............please rate this ........thanks
Aug 30, 2008 | Water Heaters
Heating & Cooling Logo
266 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
