Question about Nintendo Super NES Console
My SNES console isn't lighting up today no power light at all then.
    President:
  • 894 Answers
Well it might just be the fact that it has died on you then so you
could buy a new ac adapter to see if it makes a difference then.
Posted on Jul 21, 2011
  • 71 Answers
Double check your power cable, both at the console and the wall outlet, try a different wall outlet if necessary.
Sadly there is not much that can be done if the SNES is no longer receiving power, possibly replace the power supply. I would say it is cheaper to buy a used one off ebay though!
Good luck! Hope you get it working, that was a GREAT console.
Posted on Mar 15, 2011
My SNES won't turn on aside from the power light.
Potential mistakes, Coaxle cable not screwed on tightly or wire inside is missing. Tv is on channel 3 i'm assuming, If it's not as simple those open them up, should be some screws on the bottom, and just make sure everything is plugged in look for anything that shouldn't be clean it then plug it in and try it again before taking anything apart, Old consoles are touchy, use isopropyl alcohol to clean anything connected to the motherboard or that will conduct.
Sep 28, 2014 | Nintendo Super NES Console
When I hook up my SNES there is no picture - what do I do?
Well onlhy use the old consoles on CRT tv styles then.
Apr 08, 2012 | Nintendo Super NES Console
Flashing power light not turning on
Well its because the fuse part is blown for your SNES console and will need to be replaeced.
1.5 amp pico fuse
images?q=tbn:and9gctk82izo0z2zsaobhm5lvkhu1n47twurm9gdihge3ky88znt_9c1yedyvi
Dec 13, 2010 | Nintendo Super NES Console
Super NES Console: My super Nintendo gets power (red light turns on) ...
Maybe the one that is not turning on to play game is broken then. Ensure that you have a known-good game cartridge inserted before powering on the SNES console. Most older, cartridge-based game consoles don't boot without a game installed.
Does the power light to the left of the controller ports turn on when you turn on the power switch?
If not, check your power adapter and outlet for functionality and good connection.
Check that the reset switch is not stuck. Wiggle it back and forth through its range of motion a few times. If something sticky gets in there it can get jammed in the reset position, which will prevent any game from booting.
You mentioned that there is no image. Are you getting any sound from your games after waiting a few minutes with everything connected and turned on?
If you hear game sounds or music from the SNES, but see no picture and you've already (really and truly) ruled out the cabling and TV, then you might have a bad main board in the console.
If you don't get any video or sound, then it's not booting your game. You can find other recommendations about how to clean game and console connections, but usually inserting and ejecting a game 10-20 times will knock loose or grind off enough gunk to get a game to boot. Try this, and be sure to use the eject lever instead of ripping the game out to avoid console connector damage. If it's still not working, repeat with another game.
May 18, 2010 | Nintendo Super NES Console
SNES no power (light on for 1/2 second) Fuse good
Well I think that the fuse is blown on the system. 1.5amp pico fuse.
Oct 16, 2009 | Nintendo Super NES Console
Hi i just bought a super nes system it came with RF switch power unit which i have connected to the appropriate connections, i have an LG TV with an golden eye and don't seem to be able to tune the...
Make sure everything's connected in the correct sockets. Turn the SNES on, change to one of the Analogue channels (one of the channels which you control with the TV remote) and start scanning for a signal. The RF cable has to be connected to the analogue port (where a TV aerial would plug in to get analogue channels) and the SNES needs to be switched on.
The alternative is to get a SCART-compatible cable that works with a Gamecube or an N64 and use it with the SNES, as Nintendo had the foresight to add an EXT port which'll let you play the SNES on an AV channel.
Jul 09, 2009 | Nintendo Super NES Console
My SNES wont turn on. PLEASE HELP!!!!!!!!!
go buy a new one that system is to old
May 03, 2009 | Nintendo Super NES Console
Can't work SNES
Is the TV tuned to the same channel as the SNES ?
Both have to be set to channel 3 or both to channel 4.
Jan 18, 2009 | Nintendo Super NES Console
N64 Console
try using the cables instead of RFS's
Apr 01, 2008 | Nintendo 64 Console
Nintendo Super NES Console Logo
134 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
