Question about KitchenAid KSSC36QKS Side by Side Refrigerator
KSSC36Q KITCHEN-AID REFRIGERATOR IS MAKING CLICKING NOISE CONTINUOULSLY EVEN WHEN POWER IS OFF. CLICKING SOUND COMES FROM FREEZER AREA
  • 958 Answers
SOURCE: refrigerator makes lot of noise
based from your story. the noise could be coming from the compressor as it starts. compressor usually vibrates a lot when starting. it would last from a few seconds to a few minutes then would normalize as it sucked all the evaporator pressure down to its normal readings. you can check the rubber mountings of the compressor,you may need to replace them. also check for some tubings that may be rubbing or touching as the compressor vibrates. tighten alllso those mounting bolst of the compressor. that should solve your problem. if everything is done and still the same, the noise could be coming inside the compressor which there will be no solution but to replace the compressor. the cleaning that you did helped it a little bit because the vibration decreased a little coz it was able to breathe a little.
Posted on Feb 13, 2008
SOURCE: Kitchen Aid Ice maker Stopped working
I would suggest not buying a KitchenAid. I have the same problem with my ice maker. Have had nothing but problems with every KitchenAid product that I have ever owned. I will never purchase another KitchenAid product.
All of there appliances are second rate. That is "The KitchenAid Difference"
Posted on Feb 18, 2008
  • 300 Answers
SOURCE: kbrc36fts kitchen aid refrigerator
ompressor won't run or it is "clicking' on and off: This normally could be a bad start relay and over load for the compressor, dirty condenser coils need cleaning, condenser fan motor is not running or the compressor itself. To check the compressor properly you should test it with an amp meter, each compressor is rated in running amps  ( see model/serial tag or the sticker on the compressor )...if the compressor is drawing too much current, this may be why it is shutting off. Check the model tag for proper amp rating. Some relays will be easy to notice the broken with them, they may be burnt. Example oneexample twoexample three. Some of these relays can be removed and give them a little shake, and if they rattle around inside the relay is likely bad. Compressors can also seize and click on and off or one of the electrical windings inside the compressor could have opened up. You can use a test cord to help check the compressor and this also will help with the amp test. If the compressor checks ok and you want to install areplacement start relay. You will need to find out which winding is which. You will need an ohm meter to determine the windings. First check to see if you have windings in the compressor. Then check to see if they are grounded. If the compressor has windings and they are not grounded, you can find which winding is which. Check for grounded windings by reading from each terminal to a good ground on the cabinet. Read from the top terminal to the lower left terminal. Read from the top terminal to the lower right terminal. Read from the lower left terminal to the lower right terminal. Write down the resistance of each reading as you go. The highest reading you get will be the run and start winding of the compressor in series with each other. The other terminal left will be the common terminal. Read from the common terminal to each of the other terminals. The terminal with the lower resistance will be the run winding. The higher resistance the start winding. Using the original style relay is always preferred, but using a general replacement can "get you by" if needed. Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Posted on Mar 07, 2009
SOURCE: ksrs25ikss01 kitchen aid fridge portion not
1.check if the fan inside the freezer is running
2. if ref runs none stop, defrost timer is out.
3. or it could be the high limit that paired in series with the defrost heater
good luck!
Posted on Jun 27, 2009
SOURCE: Kitchenaid Refrigerator dripping water
i have a kitchenaid top / bottom refrigerator water drips in top part only not freezer. what is my problem?
Posted on Jan 18, 2010
My kitchen aid refrigerator model kssc42qms02 making humming noises and the the temp lights are flashing
Assuming that both freezer and refrigerator temperatures have risen and the humming sound that you heard was followed by a sudden click more than likely the start device on the compressor has gone bad. This is a common problem with all Whirlpool refrigerators (KitchenAid is Whirlpools top of the line product and suffers the same problem).
Apr 24, 2012 | KitchenAid Refrigerators
Kitchen aid KSRG25FKSS04 freezer is not freezing
Hello, few things to check:
1) Remove dirt / dust that has accumulated on the condenser coil located on the back of the fridge, or underneath. Use a vacuum to clean off with.
2) Remove dirt / dust in / around compressor area. Make sure you turn power off first as there are several areas in this area that can "bite."
3) Look for heavy frost / ice buildup in the freezer compartment. Defrost if necessary.
4) Make sure the fan is blowing in the freezer compartment.
5) Make sure there is air flow from the vent at the top of the refrigerator compartment. This air is driven by the fan in the freezer (most models).
6) Loading a lot of unfrozen food into the freezer compartment will have the appearance of the fridge going out, but is actually functioning normally as it removes heat from the food so it will freeze.
7) Your thermostat is not working correctly. Move it to the coldest setting if not already done so. Listen for the compressor to kick on. If it doesn't, bad t-stat.
Thanks
Jul 12, 2010 | Frigidaire FRS26KF6E Side by Side...
Refrigerator vibrates when compresor comes on
Hi, It sounds as though the compressor has a broken valve or rod making noise internally. The compressor should be quite. You can hear them run but not enough to bother you at all. I have never heard of any of the newer ones having a compressor that supposed to be louder. Sounds as though he didn't want to do anything I don't know. I cant tell you how to check it as you would need to put a set of manifold gauges on it to see if it is working properly. If it continues, I would make another call for free of charge and have them back out! Keep me posted,
Shastalaker7
Jan 30, 2010 | KitchenAid KBFS25EVMS Stainless Steel...
Kitchen Aid side-by-side refrigerator making dishwasher sounds
The freezer door frame should be warm where the door seal is located. This is to keep the rubber seal plyable and to prevent the door seal from freezing. Could it be that the cold seal is not properly mating with the frame and you are hearing the fan noise through the crack ?
Aug 05, 2009 | Refrigerators
Compressor runs continuously, and center bar (heat dissipator) is extremely hot to touch.
Molly, The hot bar is a normal part of the sealed system (compressor) operation. The relay they told you about is on the back of the compressor and I would not recommend you changing that. The refrigerator is a balanced system, the freezer air removes the heat from the refrigerator side. If the compressor runs all the time, look for food close to the edge and not letting the doors close completely. Move items back. Don't over pack the freezer, the air must circulate. The refrigerator of today runs longer and uses less power that the old refrigerator. If you are still having issues with this model call a authorized Kitchen repair person in you area and ask how much they charge to come to your house and give an estimate.
May 01, 2009 | KitchenAid Superba Architect KSCS25INSS...
A creaking noise when the freezer is opened & then closed
In some freezers they build up excessive vacuum which pulls the plastic housing away from the internal polyurethane insulation, hence the creaking sound. You can make a vacuum breaker by attaching a small stick or similar to the bottom of the door gasket, this will break the vacuum without losing temperature.
Mar 12, 2009 | Refrigerators
DRIPPING SOUND MAYBE POPPING ALMOST
This is normal operation, every 8 to 10 hours the heater in your freezer section turns on to defrost ice and frost from evaporator coil, this melting water hitting the heater is what is making popping and hissing noises.
Jan 20, 2009 | KitchenAid KTRS19KMSS Top Freezer...
Kitchen aid side by side 2003 KSC... freezer not freezing
sounds to me like a bad compressor....might want to have that looked at by a pro.
Sep 30, 2008 | KitchenAid KSCS25FKSS Side by Side...
KitchenAid KSSC36QKS Side by Side Refrigerator Logo
56 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
