Question about Roper REX4634KQ Electric Dryer
My red4440vq1 does nothing - Roper REX4634KQ Electric Dryer
  • Roper Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Mar 20, 2011
Roper dryer red4440vq1 not drying after changing internal fuse, internal bias, high limit thermostat and thermal cut off and cleaning vent, element heats up to temp and cycles
If heater is heating and not drying clothes, you have a blockage in ventilation system somewhere either internally in dryer or going out from dryer to outside. Take vent off back of dryer and turn on. Is air flow strong and hot?
Sep 15, 2017 | Roper Dryers
How do I test light blue wire on timer- terminal "B" for voltage. where do I put the test probes ? for Roper elec. dryer RED4440VQ1
Anywhere you can see bare metal on the dryer itself. The dryer chasis should be well grounded and this will show you a difference in potential if its there.
Nov 30, 2014 | Roper Dryers
My roper dryer wont start
Sid you test the thermal limiter fuse in line to the dryer motor.
Oct 06, 2017 | Computers & Internet
Roper RED4440VQ1 how do you know if high limit thermostat is broken?
you have to unplug the dryer,and remove at least one of the wires and read it out with a meter to check it for continuity.you can go here and see the parts you need to check,http://www.searspartsdirect.com/partsdirect/part-model/Roper-Parts/Dryer-Parts/Model-RED4440VQ1/0893/0151200/W0905172/00003?blt=06&prst=0&shdMod=RED4440VQ1
check the element,part number 17 on the diagram and is part 279838,if that's good check the thermostats on the heater box, part 9 and 15 on diagram,if one of them is bad buy part number 279816,it replaces both of them,also check the thermal fuse number 7 on the diagram and it's part 3392519.your lint filter is on top so all your parts are in the back,pull out the dryer,unplug it,remove the vent line and then the back panel,also take out the lint filter and the two phillips screws that are on the top panel and in front of the lint filter,when you're in the back,remove the 4 screws and clean out the metal duct that the filter slides into,if the vent line is a long run you can blow it out with a leaf blower,make sure nothing is blocking the air flow outside,if there's a cage or screen remove it so the lint doesn't build up and block the air flow.hope this helps and good luck.
Dec 19, 2012 | Whirlpool LER4634J Electric Dryer
I have a Roper Dryer mod# Red4440VQ1 ser# my3678178 My prob is the dyer will not start unless it is in no heat mode. I think it's the timer Robert
sounds like the safty is keeping the unit from working check dryer vent for lint from outside to back of unit
Aug 27, 2011 | Roper Dryers
I have a roper dryer model red4440vq1 and it want start
heatman101
Apr 29, 2011 | Roper Dryers
My dyer won't come on it is model # red4440vq1 I have had it 1 year and 30 days Please help
make sure you 220 outlet is getting power by checking the breaker or fuses in your box.
Apr 18, 2011 | Roper Dryers
Roper dryer movel RED4440vq1 drum does not turn. replaced motor, still not workking. belt is good. wiring harness is supplying 120 v on the 2 end red leads. door switch good. push to start button good.
The thermal fuse is likely blown. Disconnect power then remove the rear panel to access the thermal fuse on the blower housing.
Once the panel is off, bypass the thermal fuse by joining the wires together then insulate them properly. Reconnect power and start the dryer. The thermal fuse is indeed blown if the dryer starts. Replace it including the cycling thermostat.
Oct 15, 2010 | Roper Dryers
Have a rope model red4440vq1 electric dryer. it is about 5 months old. the the dryer is heating but not spinning
Aha Broken belt. You would need to get inside the machine to investigate the problema. If you were drying some big old tennis shoes that would knock the belt off. I have a pictorial on this with a manual and a nice video prepared by Repair Clinic HERE
Oct 08, 2010 | Roper REX4634KQ Electric Dryer
Roper REX4634KQ Electric Dryer Logo
333 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
