Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Bar oil is pumping up out of the bar for about the first 30 seconds of running, but then it just bubbles and stops. I'm thinking something with the oil pickup line? How do I go about checking or replacing that? Thanks!
  • Husqvarna Master
  • 2,239 Answers
Depends on the model we are talking about, however the basics are much the same, start by making sure the chain brake is off, remove the securing nuts and remove the side cover/brake, if it has an inboard clutch, remove the clip and washer from the end of the crank that secures the sprocket, remove the sprocket, remove the clutch, this will be threaded onto the crank left hand thread, it may well have cut a ways to insert a screw driver so as to jar it off,there will now be a bar protection plate held with one or two screws, remove the plate, the pump will now be accesable, once removed ,the oil pick up pipe will be behind, if the machine has an out board clutch, this will have to be removed before you can remove the sprocket.
Posted on Mar 15, 2011
  • bupalos2 Mar 16, 2011
    Thanks I ran through all that. Now it looks like maybe the husky 350 doesn't really have a pickup line. The pump has a kind of square rubber boot at the end which on one side is the oil deliver channel and on the other seals up against a well in the plastic where the oil flows into from the tank. I don't really think there is any line, just a direct penetration from this well to the tank. Anyway, I vaselined the spots that seemingly need to be sealing for suction, and I'll reassemble and try it today. BTW, does the oil tank vent somewhere to prevent it binding up from suction?
  • Andrew White Mar 16, 2011
    OK , the 350 has a composit crankcase/oil tank, if you turn the saw up side down, look between the crankcase and the fuel tank ( front bottom drive side ) you will see a grey plastic bung held with a single cross head screw, if you remove the screw and pull the bung out, this is the oil tank filter, it may well be blocked.
Bought it used, new bar and chain he said it stopped oiling guessing he has it to gather wrong. looking for a diagram
What Make and Model?
*Make sure there is oil in the oil tank
1. remove the bar and chain and run the saw with them off. Oil should be pumped out the oil vein on the side of the saw.
If there is no oil being pumped out then you have 1 of 3 issues.
a) A blocked oil pipe or gauze filter in the tank.
b) A blocked or broken oil pump.
c) A broken or damaged oil worm/drive gear
2. If oil is coming out the oil vein then check that you have the correct bar for the saw and that the oil hole lines up with the oil vein. Also check that the bar groove is clear of dirt and debris allowing oil to travel along the bar.
Feb 18, 2016 | Garden
Oiler mechanism to bar of ryobi 40cc 10532 18 inch
I get asked this question a lot , im gonna have to make a video on this subject someday .
but here:
1st ck your oil viscosity/SAE it should be 30 and say bar/chain oil
next dump out entire oil tank and wash out with kerosene (you'd be surprised what I seen come out)
then remove bar and chain , locate oil outlet it's in body of saw near adjustment screw , use a small can of air to blow in this port softly , use a touch more of kero to clean this all out , refill tank with proper oil !!!! and run saw (no need to put bar/chain back on yet ) might take several minutes but oil should start to flow out hole !! stop saw and reinstall bar/chain then run again .. fixed !! if no oil comes out ever your oil pump is gonna need some fixing
for a low cost oil I use filtered used motor oil cut down with a dab of kerosene
Jul 07, 2014 | Ryobi Factory Reconditioned 18" 40cc...
Chainsaw Bar oiler empties as soon as filled
You should be using bar oil. It clings better to the chain and bar providing better lubrication.
Apr 13, 2014 | Echo Garden
I just got a husqavara 445 referbished saw.on my fist use i noticed the bar is not oilling.it cam with 18 inch bar.is threre something i over looked
There is a number of things that will cause it to stop oiling, first remove the guide bar and clean out the bar rails also clean the oil delivery hole in the bar, behind the sprocket is a worm gear which you need to check, to do this you need to remove the clutch, to remove the clutch insert a screw driver into the slots cut a way in the clutch centre ( designed to do this ) and keep tapping against compression until it spins off ( left hand thread ) if the gear is ok, remove the steel bar plate and check the condition of the oil pump pinion gear, it runs at right angles to the crank, the throw of the pump shaft is determined by the cut a way in the pump shaft which runs on a steel pin pressed in the crankcase, make sure the pin has not fallen out. There is an oil filter which can be removed and cleaned, however it is not easy to get at and remove, if you turn the saw upside down and look between the bottom of the crankcase and the fuel tank spine ( clutch side ), you will see a plastic screw driver headed bung, twist this half a turn and pull it out, clean as required.
Good luck
Feb 04, 2011 | Husqvarna Garden
Dear Sirs, I don't have a manual to look this
There are two holes in the end of the Bar, the oil comes though them from behind the bar and goes into the channel (oil passages) that goes around the bar, clean the small oil passages in the drive end of the bar that run out to the chain groove on each edge from the large holes.
My chain saw is doing the same thing. I have only used it about 5 hours since owning it, and it worked great last time I used it (year ago). I think maybe my pump is not working. Did you ever get your's working ? I was told to take the bar off and Start the engine and observe whether oil oozes out of the side port. If no oil comes out, then the oil pump, oil line, or oil tank filter may require service.
Nov 22, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I have a rancher 455 chain saw and i dont think my oil pump is oiling my chain is there a way to turn it off and on
Remove the bar and chain, then start the engine. If the pump, lines, and filter are good, oil will ooze out of the engine side port. If it does, clean the oil passages in the drive end of the bar that run from the large holes out to the chain groove on each side of the bar. Clean the entire chain groove and oil the sprocket on the tip. Clean the port area on the engine case. Re-install the bar and chain, then run the engine at speed for a few moments with the bar tip near a piece of cardboard--it should throw off a thin line of oil onto the cardboard. Hope this helps!
May 22, 2010 | Husqvarna Chain Saw 20" Bar
It stopped oiling the chain and putting air bubbles back in to the oil tank . the model 240 homelite UT-10621
The first thing is to clean the bar, oil ports, then the main port in the case, blockage is the main cause. When the bar area is clean,
Take a stright pin and try and clean out the port as much as you can,then if you have a shop vac that has a attachment that goes to a smaller end, such on the port and get any lose dust out.
If this does not work the pump could need to be rebuilt.
Feb 15, 2010 | Homelite Garden
No oil getting to bar and chain on 20in. homelite chain saw
Take the cover off the sprocket for the chain and loosen the adjusting screw so you can remove the bar. Remove the chain from around the bar. In the read of the bar there is usually one or two small holes less than 1/4th inch. This is where the oil injector shoots oil into the bar for oiling the chain. The hole can become plugged with sawdust thus stopping the flow of oil. Clean out this hole as well as the injector nozzle for the oil underneath the bar. Not a bad idea to run something slim all the way around the bar in the grove that the chain runs in. This will remove all the excess sawdust that can keep the oiler from working.
Sep 12, 2009 | Garden
Lubrication
The cap on top with the bulb, screws off. Use bar oil. Give the bulb a pump every 30 seconds of operation or so. This will keep your chain and bar lubricated.
Regards, --WoobieDog--
Jul 10, 2009 | Remington Electric Pole Saw
Bar oiling problem
Just a thought: Is it cold where you are? At this saw mill where it is my job to keep chain saws running, learned years ago that you cannot use "bar oil" in winter. Need thinner oil, like motor oil. ....preferably a "non-detergent" motor oil, plain 30-weight is OK, HD30W will work, but the HD part causes the chain to stretch more so than standard bar oil. The bar oil literally is so thick in cold that it stripped the worm gear out of a Poulan Pro oil pump (plastic gear, anyways, wasn't much to begin with.) But thought you may want to try thinner oil, if it is cold where you are. Oh yea we also have 2-Husqvarna 359's with 20-inch bar, and use thinner oil in winter. Our Husqvarnas have an oil adjuster located on bottom, on clutch side. Straight slot screw adjustment.
Nov 18, 2008 | Husqvarna Chain Saw 20" Bar
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
94 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
