Question about Refrigerators
Freezer keeps freezing up. But the fridge doesn't stay cool.
  • Ahsan P Mar 15, 2011
    What temperature/setting is the fridge on? Are there any deformities in the shell of the fridge? Is it's door open for long periods of time? When was the last time the cooling gas was checked by a technician, and is there any ice covering the cooling fins in the freezer or fridge compartment?
    Guru:
  • 683 Answers
The reason the fridge doesnt stay cool is because the freezer keeps icing up, try defrosting the freezer and try cleaning the condensor coils and this may help.
Posted on Mar 15, 2011
My Frigidaire refrigerator works find; Freezer stays cold but doesn't freeze food or ice
Its defrost assembly parts issue or the compressor is getting waek indication.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
Freezer stays frozen, but refrigerator doesn't stay cold
Its defrost problem.When the freezer section gets cold and reaches its required cooling temperature, after that the frost on freezer section starts defrosting and the cooling fan in the freezer section blows this cool air from freezer to fridge. But if the defrost cycle does not start then over ice will get collected on freezer ventilations and that will block the air passing section from freezer to fridge, so the freezer gets cool but fridge section does not cool.Try manual defrost by unplugging the refrigerator from main power outlet for 24 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
Sep 13, 2011 | Magic Chef Refrigerators
Refrigerator doesn't get colder than 55 degrees.
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
This will help.Thanks.Helpmech/.
Aug 19, 2011 | Kenmore Refrigerators
Freezer coil keeps freezing up,defrost coil not staying on long enough.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 02, 2011 | KitchenAid Refrigerators
I have a fridge freezer and for some time now the fridge keeps freezing and now the freezer seems to be leaking water?
If it is a frost free freezer, is is probably your defrost assembly that is bad. The leaking water might be associated or another problem. Is the refrigerator section staying cool?
Jun 01, 2011 | Refrigerators
My daughter's mini fridge has a freezer compartment. Her issue is, if she turns it up high enough so the freezer freezes, the fridge compartment also freezes everything; if she turns it down so that the...
This is a drawback of most mini-fridges. Start by defrosting everything. Then fill ice cube trays with water and keep lowering the setting until the water freezes. Just go a little lower, no more. Fridge should not freeze food. If the fridge stays closed all the time food will freeze. Also if the freezer element gets ice buildup it must be defrosted. Not automatic like home fridge. Most kids today weren't born when the last fridges that had to be defrosted were in service.
Sep 01, 2009 | Refrigerators
Not cooling or freezing
bimetal switch not working. change it.
Aug 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge side won't regulate temp. however the freezer will freeze to -9 and stay right there! How do you test the thermostat? or is this a common problem. The fridge was built in 01' and nothing has been...
the thermostat is either off or on, and it controls the fridge temperature the freezer is just a by product of the remaining gas from the fridge usually -20/30 degrees lower than the fridge, two problems would cause this leaked gas would reduce the cooling capacity of the freezer but the fridge should stay ok although the compressor would be constantly on trying to keep temperature. the thermostat can fail after time not being able to keep a regular temp and not switching the compressor on enough to cool the system. unless you have a frost free where is usually a relay that controls the compressor witch have a life time rating of so many operations.
Jul 23, 2009 | Electrolux Refrigerators
BOSCH FRIDGE
If you have a two door (fridge freezer) some of the newer fridges these days have the cooling come from the freezer to cool the fridge part. Maybe try altering the freezer temp and see if that makes any difference.
Jul 02, 2008 | Refrigerators
Refrigerators Logo
102 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
