Question about Sport & Outdoor - Others
Where to get a handbook for a compass illusion 490 1998 caravan
Does my 2015 Dodge Grand Caravan have a compass?
on most cars its an option!
did you read the opertors guide
if there (means was option) you read the page
and it says push, X? and it works. if not its bad, or not opted
why on earth would you car with smart phone and gps app that shows (tomtomo) like screen,
compass are like wooden ship useless.
I look at sun, and bam, going west ,like it.
if still unsure why not as that fat cat that sold you this car.
make him earn his/her pay. yah think, and they have records of that options, for SurE,
Jan 19, 2015 | 2015 Dodge Grand Caravan
How do I tune in my Blaupunkt Valencia MP 36
Have you got it properly earthed via its frame to the vehicle earth. It may not get a good signal if the van is mainly glassfibre. Go online to the Blaupunkt website and down load a handbook.
Sep 05, 2014 | Cars & Trucks
How do i reset the compass on a 2006 dodge grand caravan
Hi Roger, I'm glad to help. Below is the procedure for resetting the compass on your vehicle.
COMPASS VARIATION ADJUSTMENT Compass variance, also known as magnetic declination, is the difference in angle between magnetic north and true geographic north. In some geographic locations, the difference between magnetic and geographic north is great enough to cause the compass to give false readings. If this problem occurs, the compass variance setting may need to be changed.
To set the compass variance:
1. Using the Variance Settings map, find your geographic location and note the zone number Figure 1.
22681.jpg Figure 1 - Variance Settings 2. Turn the ignition switch to the On position. If the compass/thermometer data is not currently being displayed, momentarily depress and release the C/T push button to reach the compass/thermometer display. 3. On Electronic Vehicle Information Center (EVIC) and Compass Mini-Trip Computer (CMTC) equipped vehicles depress the Reset push button and hold the button down until "VAR = XX" appears in the display. This takes about five seconds. On Compass Temperature Module (CT) equipped vehicles depress the C/T push button and US/M push button down until "VAR = XX" appears in the display. This takes about five seconds. 4. Release the push button(s). "VAR =XX " will remain in the display. "XX" equals the current variance zone setting. 5. On Electronic Vehicle Information Center (EVIC) and Compass Mini-Trip Computer (CMTC) equipped vehicles momentarily depress and release the STEP button to step through the zone numbers, until the zone number for your geographic location appears in the display. On Compass Temperature Module (CT) equipped vehicles depress the US/M push button to step through the zone numbers, until the zone number for your geographic location appears in the display. 6. On Electronic Vehicle Information Center (EVIC) and Compass Mini-Trip Computer (CMTC) equipped vehicles momentarily depress and release the RESET push button to enter the displayed zone number into the EVIC/CMTC module memory. On Compass Temperature Module (CT) equipped vehicles depress the C/T push button to enter the displayed zone number into the electronic module memory. 7. Confirm that the correct directions are now indicated by the compass.
May 17, 2014 | 2006 Dodge Caravan
Where can i get a owners handbook for a 1997 Abbey Caprice caravan
http://shop.ebay.ie/sis.html?_nkw=1997+ABBEY+CAPRICE+LTD+EDITION+2+BERTH+TOURING+CARAVAN
http://caravans.autotrader.co.uk/used-caravans/abbey/unspecified/1997/at8a65f6202f48f2e7012f8f43ac7b3c7f/abbey-caprice
please 4like, if it help you
May 30, 2011 | Computers & Internet
Overhead bulb replacement for 2007 Dodge Grand Caravan . How do I remove the console?
You Don't! Take a thin bladed screwdriver along the clear lens and just pop it out (the lens), and voilà! There's the bulb that needs to be replaced. Make sure your screwdriver is not magnetized for your compass will never read correctly when near a magnetic source.
"00 Buck"
Nov 06, 2009 | 2002 Dodge Caravan
1996 dodge caravan turn signals, heater fan, compass dont work
the elec-start module or relays are no good . try unhooking unit to see if problem goes away.
Oct 05, 2009 | 1992 Dodge Caravan
Keeping course
Please check if the pilot is acting the right direction ,press +10 key and check if boat teers STB,
press -10 and check if boat turns PORT ,if it acts reverse, see handbook to reverse action.
Verify if compass course in standby is indicating correct course .
Do the calibration procedure as stated in in the handbook (360 degree turn)
If it still not indicate the correct course ,or is frozen, compass or printed circuit is faulty.
Check the resistance between the wires of the compass unit .(see google internet)
Good luck
Jean
Sep 11, 2008 | Raymarine RL70CRC GPS Receiver
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
