Question about Samsung RF266AE (260 cu ft) Refrigerator
Refrigerator is not keeping food cold. Temp is set to 38. Freezer temp is set to -2. Freezer is working fine. Food in the refrigerator is begining to spoil. Problem started a week ago. We cleaned entire outside and underneith to remove any dust. Appliance is year and a half old. Samsung RF 266 Series bottom chest freezer. Model RF266ABBP We've tried the "power freeze" and "power cool" settings as well as turning down the temperatures in both the freezer and refrigerator. Problem still persists. thanks for any help!
    Guru:
  • 683 Answers
Most refrigerators have the evaporator in the freezer and use air flow to cool down the refrigerator compartment. Can you tell if the defrost cycle is working, IS there ice on the evaporator. Can you defrost it. Try taking it off the power freeze cycle and also power cool cycle. When you cleaned underneath did you find a pan that had water in it. sometimes the drain clogs up and the condensate just sits in the freezer and refreezes the water, this acts like a blanket and slows down the cooling in the refrigerator. see if you can look at see if the drain is clogged, this may be your problem. You can get back to me and i will see if i can help you. thank you. and a rating would be helpful. thank you. wally
Posted on Mar 15, 2011
What is the correct fridge temperature this fridge should be on?
If your refrigerator has 2 controls, the start setting is usually at mid point on both dials. That should give you a freezer temp close to 0 and a fresh food temp of 38 to 42 degrees. If only one control---same middle setting should produce about the same inside temps. Fresh food temp is best measures if you can put thermometer in a glass of water to stabilize the temp.
Apr 15, 2015 | Refrigerators
Refrigerator malfunction
samsung units have duel cooling. that means there is a evaporator in the freezer and the fresh food section. it is possible that the temp sensor in the refrigerator section could be bad. and they have been known to have defrost problems there to. the samsung is a complicated unit and its hard to describe how to repair since there is a lot of electronics that control everything. the best thing I could say is to unplug the refrigerator for a few minuets. sometimes this will reset everything and start the unit back to the factory settings. if that does not work I would call for service. hope it helped you some
Aug 04, 2007 | Samsung RS2556 Side by Side Refrigerator
Freezer is cold but food isn't frozen
Deforst freezer and ref. wipe dry. Reset controls to starting point.
Check temp. 0 in fez. 38-40 in ref. keep advancing settings until you reach temp. Also, vaccum behind unit
May 02, 2014 | Amana 22.6 cu. ft. Side-By-Side...
GE monogram refrigerator too cold
There is a balance between the freezer and fridge. Reduce the freezer temp and see what the fridge temp does. By reduce I
mean make the freezer warmer. If it is set too cold the fridge gets colder.
Nov 25, 2013 | GE Monogram ZISS480DRSS Stainless Steel
How to set a temperture
By keep your refrigerator or freezer too cold, it unnecessarily wastes electricity. The recommended temperature is 37 to 40 degrees for the fresh food compartment of the refrigerator. The recommended temperature for the freezer compartment is 5 degrees. If you have a separate freezer for long-term food storage, it should kept at 0 to -5 degrees.
The following steps below is how to set the temperature of your refrigerator.
The first thing you must know is that your refrigerator should be set at 37-38 degrees. Anything at 40 or higher and you are risking food born illness (food poisoning) or spoiling your food.
Step 2
Place your magnetic thermometer in the refrigerator.
Step 3
Set your dial on your refrigerator to the second lowest setting. (If your refrigerator is already equipped with a digital thermostat, simply set it for 37 or 38 degrees and do not move on to the next step)
Step 4
After 2 hours, check your thermometer reading. If your reading is 38 degrees, there is no need to go higher and you are ready to put your groceries in. Be sure not to open and close your refrigerator during these two hours or your temperature reading will be incorrect.
If your reading is higher than 38 degrees, move your dial up to the next coldest setting and repeat the steps every two hours until you reach the correct temperature for your refrigerator.
Step 5
Once you have reached the correct refrigeration temperature for your refrigerator, place the magnetic thermometer in the refrigerator permanently and watch for changes.
Typically, your refrigerator temperature will need to be adjusted with the seasons, a higher setting in the summer and a lower setting in the winter.
Hope this helpout and take care.
Aug 12, 2010 | Refrigerators
I have a Jenn-Air side by side frig. The freezer side cools too cold, the frig side not enough. 2 weeks ago I took all the food out of freezer and noticed ice build up on back. I unplugged unit, let it...
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem.
There is a small duct between the freezer and refrigerator side if this is blocked the frig side won't cool.
Jan 09, 2010 | Jenn-Air JCD2389G Side by Side...
Freezer does not get as cold as the setting made but refrigerator
If the unit is working correctly, it could be that you are trying to adjust the freezer with the wrong knob. The fresh food section is cooled by forced air from the freezer and can get about as cold as the freezer if not adjusted correctly. The thermostat its self controls only the temp in the freezer. Some times telling which is which is confusing. Here is the best way to tell the difference.
The knob that will turn the unit off is the thermostat. The other one controls how much air can be forced into the fresh food section. The thermostat should be adjusted to where the freezer stays around -10 degrees. The other knob should be set so the the fresh food section stays between 35 and 38 degrees. If this does not help or if you find that there is indeed a problem with you unit, please get back with me and I'll be glade to walk you through diagnosing the problem.
Please post a rating if solution is helpful. Thanks
Aug 21, 2009 | GE Profile Arctica Stainless Steel Top...
Ge fridge GSS25LFGww, fridge part freezing food
Hi, Change the controls back to normal settings. Make sure the freezer is getting 0 to 5 above. If the freezer is getting cold enough, try and turn the cold control to 1 and see if the refrigerator shuts off. It sounds like the cold control in not working properly and will need to be replaced. NOTE: The freezer temp has to be right temp or the fresh food side will not work proper.
I hope this helps. Please let me know if I can assist you further.
Vic
May 30, 2009 | GE GSS25JFM Side by Side Refrigerator
Freezer compartment on refrigerator not cold enough
depending on the temp it could
if the ambient temp get below 32
you freezer wont come on and actually begin to get warm (insulation factor)
but the refer will seem cold because of the low ambiant temp is the temp inside
we go in the refer alot more than the freezer
Mar 28, 2009 | Frigidaire FRT21S6A Top Freezer...
Whirlpool sidexside m-gd25dq does not cool properly
Sounds like bad cold control. Replace it. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 15, 2008 | Whirlpool 19.6 cu. ft. Upright Freezer...
Samsung RF266AE (260 cu ft) Refrigerator Logo
210 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
