Question about LG M1910A 19 in. LCD Television
My flatron m1910a lg monitor /tv will not display anything. it seems to lightly flash the screen but then goes black right away. If I power it off with the power button it seems to want to power itself back on without my help. I have tryied to unplug it and plug it back in. It is now currently working for me but it did the same thing yesterday morning as well. can you suggest anything or need more information
  • 191 Answers
SOURCE: LG 32LC2D Power light Blinks but set will not power on.
change your adc(analog to digital converter) board will help out
Posted on Oct 11, 2008
SOURCE: tv guide on our LG tv
It is NOT the main board. You need a V CHIP UPGRADE "epk file" Email me and I can walk you through it, very easy introspectionx2@yahoo.com Put "TV GUIDE" in the subject line
The problem started with TV GUIDE messing with things while they are doing their digital conversion
Posted on May 14, 2009
  • 92 Answers
SOURCE: Vizio GV47L screen went black and is now unresponsive
Change the main board if you have good picture and sound. If you don't have picture and sound, the inverter will also need to be change.
Posted on May 30, 2009
  • 5 Answers
SOURCE: LG 47LC7DF Green Light Blinks 16 Times - No Picture or Sound
The lights indicate what the issue is. Kind of like your check engine light in your car tells you something is wrong with the engine.
Posted on Aug 31, 2009
SOURCE: Hi. I hvae a LG
Press the "Exit" button on the remote control and all will be solved!
Posted on Nov 23, 2010
LG flatron w2230s-pf monitor only displays for 3 seconds, then the screen goes black. power is still on, and you can very faintly see the image. if you turn it off and on again, it will display correctly...
The problem is in the inverter board, the most common problem is bad capacitors, inverter transformers, or back light issues. The power supply and inverter share the same board, attempts can be made to repair or replace the board, if a professional gets involved you are further ahead in buying new.
Apr 21, 2011 | LG 22" FLATRON LCD Monitor
My flatron L1710S flat screen will not come out of power saving mode. When I turn on the monitor the power button/light is green for a few seconds, the screen indicated "power saving mode", then...
I switch on my PC, ensuring that all cables, leads and power supplies are connected properly. The tower powers up no problems at all. I switch the screen on, the green led lights up, the screen is completely black. A blue box appears centrally on the screen with the text 'power saving mode'. The green led light turns amber and then the screen just goes black.
Please don't suggest going to control panel, as I can't get that far.
PLEASE PLEASE CAN ANYONE SUGGEST ANYTHING give me
Mar 08, 2011 | LG Flatron L1710S 17" LCD Monitor
I have a LG Flatron L1718S; the screen display for 2 sec and then turn Black.
If the power light remains on after it goes black, the problem is the inverter board that powers the back light behind the screen, the cause is usually bad capacitors. To fix it, the board must be replaced or attempt made to repair the inverter board.
Feb 10, 2011 | LG Flatron L1718S LCD Monitor
LG Flatron W2234S Monitor Monitor goes black
Ahh the same thing has happened to my monitor! Mine unfortunately is 1 month over warranty. Apparently this is a common problem with this model!
Oct 29, 2009 | Gateway FPD 1730 17" Flat Panel LCD...
My LG Flatron L1717S wen I power up it flashes good for 2 sec
are you getting a check signal cable message? any on screen instructions?
try the cable, if it works on another monitor, then sorry to say but your monitor is fried
Sep 01, 2009 | LG Flatron L1750S 17" LCD Monitor
Lg flatron blank screen
t certainly seems like the monitor is not getting a signal. Did this happen after you changed something, or just on normal boot up?
It could be the video card that has failed.
Also, check the pins on the connector; sometimes they can get pushed in.
If you can, try swapping out the video card or use the monitor on another computer.
Good luck,
May 09, 2009 | LG Flatron L1951S 19" LCD Flat Panel...
Screen flashes only for a split-second (as a second display for an iMac)
The inverter is faulty.If your Monitor is powered by a mains'kettle' type lead,then it MAY be repairable,provided you can find someone to do it.If you have an external power supply,then the chances are you have a separate inverter,and it is doubtful whetther you can find the fault or a replacement circuit board....which is why we have become a throw away nation !!
No picture
you should take it back
Jun 21, 2008 | LG Prada KE850 Cellular Phone
LG Flatron LCD Power Saving Mode
Well thats seems tricky does it not come on at all when you boot the computer. If the screen is working then it should work to display the Start up screen. If it does then keep pressing Delete until the BIOS comes up- then search the pages for power saving and slect to OFF
May 18, 2007 | LG Flatron L1750S 17" LCD Monitor
LG M1910A 19 in. LCD Television Logo
150 people viewed this question
Computer Repairing
Computer Repairing
