Question about LG LMU360CE/LMAN090CNS Split System Air Conditioner
Showing the digital thermostat CH02 indoor pipe temperature thermisor error
2 Suggested Answers
  • 45 Answers
SOURCE: mrv system the problem in a caset type it give me
your indoor thermistor has a open cicuit.replace it.
Posted on Oct 04, 2009
Carrier Comfort Zone II Thermostat is blank and the 3 companion thermostats are all showing Error Code C1. What does that mean?
Hi Anonymous,
For all wall mounted and Artcool split system codes
Error code = C1 or CH1
Flashing Light = 1
Fault = Indoor temperature sensor open or closedcircuit.
Display = Indoor.
Indoor Operation = ON
Error code = C2 or CH2
Flashing Light = 2
Fault = Outdoor temperature sensor open orclosed circuit.
Display = Indoor Outdoor.
Feb 14, 2015 | Carrier Heating & Cooling
Lg digital air cond show ch02 display
02 fault according to LG bible means that the indoor pipe sensor has failed. You will need to obtain a new sensor or get a Tech to supply and fit. The indoor unit needs to be accessed (Opened up) to repair this.
Dec 25, 2013 | Heating & Cooling
Indoor pipe thermostat
need model and serial numbers to find any info.
Aug 02, 2013 | LG Heating & Cooling
Hi my LG healthplus inverter system split unit keep giving me a CH02 error code. how can i solve?
Indoor Pipe Sensor or Outdoor Sensor Assy fault, Open or Short. Disconnect from PCB and measure resistance. Air sensor = 10 kOhm at 25C, Pipe sensor = 5
kOhm at 25C. If not replace sensor
Jan 20, 2011 | LG Heating & Cooling
How to fix LG CH02 error
Jan 16, 2011 | LG Heating & Cooling
Get a CH02 error. Can't get service. No response.
i have the lg lp120hed units as well. i had a unit give me ch02 error a while back i replaced the unit with a spare....now the spare is not working either.
looking at the manual, ch02 error means "indoor coil thermistor error"....calling lg for that part now.
good luck.
Apr 01, 2010 | LG LP120HED Wall/Window Air Conditioner
Indoor temp is 5 degrees colder than display reads on digital thermostat
Where are you measuring the indoor temperature?
To compare it to the thermostat temperature you have to measure both temperatures at thermostat.
The thermostat will only control the temperature at the thermostat, not any where else in the room.
The room temperature depending on insulation in walls and ceiling and distance from outside wall and outside temperature, can be as high as 10° difference from outside wall to inside wall of house.
The lower the outside temperature, the greater the room difference in heating. The higher the outside temperature the greater the room difference in cooling.
Feb 13, 2010 | Honeywell Programmable Thermostat Heater
LG LMU360CE/LMAN090CNS Split System Air Conditioner Logo
220 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
