Question about Acer Computers & Internet
I have a v173 lcd monitor by Acer. Suddenly yesterday the screen went dark. The power seems to be working as the blue light for the power button is "on"/lit. When hitting the power button the screen displays my home page for a brief second or 2 then it goes black. Can you please provide me with some assistance i.e., if I can fix it myself or it needs servicing. Note: all cables - connector and power adre in place. THANK YOU
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Acer Master
  • 848 Answers
I have a v173 lcd monitor by Acer. Suddenly yesterday the screen went dark? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
9721AQKM 715G3350 1 3 Acer ADTV9721AQKM Power Supply Backlight Inverter
Posted on Dec 19, 2014
  • 11,361 Answers
You need to check the fuse (round black component next to the small green circuit board as shown on the left of the picture), DC filter caps for domed tops, DC voltages. Tho have to fix will not be worth it. The problem is more likely to be the small circuits board (on the left of the picture).
http://s807.photobucket.com/albums/yy352/budm/Samsung%20173s/?action=view&current=DSC00087.jpg
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Mar 15, 2011
I have an Acer X193W....looking into the blue light on the power button it seems "dark" at the middle of the power switch light.....is this a burnt out light or do I see an internal part that is...
You are right. You are seeing an internal part that is in the middle of the light.
Specifically, the light is an LED (light emitting diode) the part you are seeing is the stand on which the actually silicon chip is mounted.
Jun 22, 2011 | Acer X193W LCD Monitor
Acer V173 with flashing amber led. No picture. cable good. other monitors work at this connection.
I have this same problem. Blinking amber Light and no display. on close examination I am seeing the video image attempt to come up, but with no back lighting. I think there is a power supply problem. I will post again if I learn more.
Feb 24, 2011 | Acer V173 b Monitor
"No signal" on Acer V173 monitor. All connections
You may have problem in the logic board, it uses surface monted components no much chance for DIY repair.
Service manual; http://elektrotanya.com/?q=showresult&megnev=Acer&megnev2=AL2216W&kategoria=monitor&kat2=all
The cases these days are hard to open, they use plastic finger hooks types, they go in easy but real hard to remove without damageing them.
Use thin flat blade to crack open at the bottom edge so the scratches will not be so noticeable, and work your way around, look out for cables attached to the front bezel also.
Failed TV and Monitors:http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps:http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit:http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Oct 27, 2010 | Acer V173 b Monitor
I hav buyed a new acer v173 lcd monitor,and used upto 10 months till now.Lastday when i switch on my lcd,it showed the Acer logo , and suddenly the color of the screen changed,now the lcd works but i could...
Sounds like a problem with the video board of the monitor. I would contact Acer, since it less than 3 yrs old, tell them the problem that you are having get an RMA number and they will fix it for free. You only have to pay for shipping it back. Hope this helps.
Jul 29, 2010 | Acer V173 b Monitor
Monitor problem
The power light is flashing green can indicate start/restart of the power supply due to shorts circuits or failing power supply due to bad caps, look for bad caps with bulging top first, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see insdie so we can guide you furhter.
Feb 20, 2010 | Acer 17" AL1706B LCD Monitor
Monitor suddenly went dark. Switched it to another system but still dark. Power light on. V9s S1901D S/N T34F501728
Disconnected Data cable from the monitor to the back of the CPU. Do a self test on monitor if u get colors on the monitor it is working fine.
check for loose cables. Try to do factory reset on monitor using buttons on monitor.
Aug 17, 2009 | Scanport JTX V9S (Black) 19 in. Flat Panel...
Monitor went dark and does not light up at all. Is it more cost effective to trash it and buy another or is repair feasable?
If you still get the blue power light output but it is dimmed, I've had the same problem - unplug both computer and monitor - hold power button for monitor for 15-30 seconds...then power it back on and then power on the computer. Seems from other sites there is a power issue with the monitor - this worked for me.
Jun 24, 2009 | Gateway FPD2275W LCD Monitor
Hp pavilion f1703 blue monitor power button flashesw/ dark screen
Have you tried connecting this monitor to another computer, even a laptop. This would tell you whether the display is bad or the video card is the culprit. I suspect the monitor's power supply is dying. Taking it to a pro for repair should cost @55.00. Buying a new monitor @ $100 - $125.
Mar 26, 2009 | HP Pavilion F1703 17" LCD Monitor
Monitor is Blank and Power Light Blinks
JH77,
Hi...Ya! It's seems your LCD monitor backlight inverter just run out of lucks... it's burnt out. Need to replaced a new inverter. Have a nice day!
Sep 25, 2008 | Dell E173FP 17" LCD Monitor
Computers & Internet Logo
151 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
