Question about Nokia 3110 Cellular Phone
When i gonna try to turn on my phone only the logo of Nokia will appear after that it will turn of again
    Guru:
  • 832 Answers
Hello there!
Try to remove the battery and install back the battery. In this case, you are resetting the phone. If still does not working, perhaps the problem is with the battery. Try to recharge your battery properly and so on.
Regards,
fossildude
Posted on Mar 15, 2011
3 Suggested Answers
  • 42 Answers
SOURCE: when i on my phone N7610 only nokia logo appear
How old is your battery? I suspect the battery. Does the same symptom persist when charger is plugged in?
Posted on Jan 08, 2009
nonontech
  • 4737 Answers
SOURCE: 3110 Cellular Phone: when turning on the phone the nokia logo appear th...
As per my experience, you are not alone facing this problem, there're many 3110 users complaining about this, but most of them can't get it repaired since it's a complicated problem, you can try some tricks, 1. check your mobile battery and battery connectors, clean them with eraser (rubber), 2. remove your memory card and start the phone. 3. Also remove your sim card and try. 4. If you can boot without sim card and memory card then go to settings and reset to default using the default code 12345. or you can directly reset using *#7780#. If this doesn't solve, 5. Clean the PCB Circuit with IPA solution, (It's a solution to clean electronic circuits). 6. Still persists, your only option is to flash the handset using flashing software or you can update the firmware using the flashing software. If it doesn't solve with all these tricks and even with flashing, the final option is to give heat to the pcb board using blower.. and as per my experience, there's no more tricks that i can do with this if all these don't work out... Anyway Good luck.. and please rate me..
Posted on May 05, 2010
Nokkia 5130 -screen goes white and nokia logo appears like always, then the screen goes white and after several seconds it turns off...
nokia 5130: when I try to turn on the phone, the screen goes white and nokia logo appears like always, then the screen goes white and after several seconds it turns off
Sep 22, 2011 | Nokia 5130 Cellular Phone
Hi plz plz help me after installing the symantec antivirus to nokia 6630 mobile, phone is not able to initialize,it will display only NOKIA logo..After i t will switch off..Help me its urgent..Thanks in...
Try this method, remove your memory card, then boot it again, if it didnt work you have to format it. Here are the steps. Turn off your phone, then press and hold *3 and the green or call button, while pressing and holding it, press the power button or power it on, wait until the logo of nokia appears before releasing the buttons. Hope this helps...
Apr 25, 2010 | Nokia Cell Phones
See White Screen + Nokia Logo + Failed to Start contact Retailer
Try formatting your phone and see if it works.
First make sure your phone is turned off.Then press the following buttons simultaneously (at the same time:
Power button + * + 3
This will restore and reformat your phone into factory settings. Hopefully your phone will be able to start again as if it were being used the first time from the box.
Let me know if it works,
Hope I have been of assistance to you,
Cheers :)
Sep 03, 2009 | Nokia 3230
When i on my phone N7610 only nokia logo appear and off again,logo appear again then off again
Jan 08, 2009 | Nokia 7610
Nokia 3230 startup failed
TRY THIS MANUAL FORMAT:
JUST PRESS KEYS *,3 ,call ..While pressing, turn on
the power swicth until formating appears on the screen.
Then just follow for further instructions.. Thank you much!
You can send me email for further results at st_nardz@yahoo.com
Kindly rate this soluton!
rg_nardz
Aug 09, 2008 | Nokia 3230
Nokia 6288
Scan your memory card for virus....formatt your phone *#7370#.
Use McAfee anti virus.
Jul 21, 2008 | Nokia 6288 Cellular Phone
Help me..
gudmorning my phone 3660 when im turning it on the logo nokia just appear but it will restart again and again until it turn off what will be the most easiest way to fix my phone??tnx
May 27, 2008 | Nokia 3650
Phone restarts on its own
I tried to switch on my cell with the data cable already attached.It kept on beeping on my pc but cel did not switch on.I detached the cord and switched on my cel.It showed the nokia logo and kept switchin on and off.Later i removed the battery,replaced it back and switched it on.And BANG!!! After 5 minz it switched on!!!!!!!!
Feb 11, 2008 | Nokia 5300 Grey Cellular Phone
Nokia 3110 Cellular Phone Logo
18 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
