Question about D-Link Dlink DI-514 Air Wireless 2.4 GHz Router (A0177337)
Trying to connect to 192.168.0.1. not able to connect to the setup wizard.
  • 114 Answers
Check the link: http://support.dlink.com/emulators/di524/help_faq.html .
Posted on Mar 15, 2011
The router installs fine on one lap but I still can't connect my other laptop
your first option is to go to http://192.168.0.1 Here Select admin from the drop down menu and leave the password field Blank.
Once the page loads youll see a series of options. this is the routers linux interface section. you will see D-link on the top left.
Select the first option Install router.
the steps would be as follows.
Step 1.
Insert the Router Setup Wizard CD in the CD-ROM drive. follow The step by step instructions. Once you done this And i believe you have already. see step 2
Step 2.
Select the Option
Setup on the Top > Internet is on the left side.
Under the Internet connection Wizard Hit the Setup Wizard button.
Step 3.
Now on the Setup page Same place where the setup Wizaed is. just below their is another option called Wireless Security Setup Wizard.
Press the Launch Wireless Security Setup Wizard Button.
Read the 3 steps then click the next button to continue.
Steps for step 3.
1. Enter a SSid this will be the network name you see when you want to connect to your own network. example.. MyHome
2. Select your security option then click next. (For simplicity chose WEP)
3. click apply.and let the router reboot.
when it comes back online you should see your network you just setup. our example was MyHome.
If you are new to router setup. use the Wep security called Good on your routers security WEP. and just write the key it gives you down. this is the code you need to connect your devices and is considered ok for a simple home network.
Nov 22, 2011 | D-Link DIR-615 Wireless Router
It was working fine until ive reset my linksys wrt54g, and i did my setup again, but i dont get any internet connection, my linksys is using a cable to my pc. please help
When you resetted your linksys router, chances are, the setup for WAN connection was lost. You can try these steps:
1. Connect the internet directly to your pc. If your pc was able to browse the internet, move on to the next step. If not, you'll have to contact your ISP for the settings of your internet connectivity.
2. Connect back the internet to the WAN port of the router, and connect your pc to the router's LAN port.
3. Open the router's page in a browser (the address usually is 192.168.1.1, username is admin and password is admin)
4. If your router has a setup wizard, run the setup wizard, because it usually clones your pc's mac address.
Hope this helps.
Mar 06, 2011 | Linksys Wireless-G WRT54G Router
Connected to d-link network which is unsecured. how to secure?
You need to setup a password for the wireless connection,
1. Connect D-link Router to your computer
Your computer should be connected to the LAN port of using an Ethernet cable.Power on the router after connecting the router to your computer.
2. Log on to D-link Wireless Router
To logon to wireless router type the default IP address of the router on the address bar. The default IP address of the D-Link router is 192.168.0.1
Before log on to the router it will ask you the user name and password. For a default D-link router
User Name : admin
Password :admin(Flip the router over to know the default username and password)
3. Click on Setup Wizard
To configure the router in an easy way click on the button Setup Wizard.
4. Click on Launch Internet Connection Setup Wizard
To configure the internet connection in this D-link router, click on the button Launch Internet Connection Setup Wizard.
holygrass_21.jpg Now the wizard will show you what steps it is going to complete while running the wizard. Click Next to continue.
holygrass_22.jpg 5. Create new Password For your router
holygrass_23.jpg Setup wizard will prompt you to create a new password for your WBR-2310 Wireless Router. After entering the password click on next.
6. Select your Time Zone
Now the setup wizard will prompt you to select your time zone.
holygrass_24.jpgPost .
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
Jan 12, 2011 | D-Link Computers & Internet
My 2wire product seems to need resetting every few minutes. As soon as it's unplugged and plugged back in, it works. However, after a few minutes, it loses connection again. Is this an issue with my ISP,...
  • Re-run the Setup Wizard using one of the following methods if you are unable to browse the Internet:
  • Re-run the HomePortal Setup Wizard from the HomePortal CD.
  • Re-run the HomePortal Setup Wizard by going to http://homeportal/setup (http://172.16.0.1/setup) in your Web browser.
  • (For Windows only.) Re-run the HomePortal Setup Wizard by clicking Start > Programs > 2Wire Gateway > Run 2Wire Setup Wizard.
If required, make sure that you are using your unique username and password. If the problem persists, contact your ISP to verify your connection type and login information (if necessary). After verifying your connection type, also verify that you are using the correct keycode by referring to your HomePortal documentation or by visiting http://www.2Wire.com/keycode.
Nov 04, 2010 | 2wire (1000-000057-000) Modem
When i try to connect it will not get connection to internet. If i by pass the router it will connect
Hi rarebed, Your router needs to be set up D-link has an automatic setup wizard just connect you router to the computer and type 192.168.1 in the internet's address bar. hit enter and enter again on the next page (you don't need a password) then pick automatic setup and follow the wizard. http://www.fixya.com/support/r4219065-set_up_wireless_router_use_wireless For General manual instructions
Sep 27, 2010 | D-Link AirPlus DI-524 Wireless Router
I have problem setting up my wireless network and redirecting my wireless client to my local webpages before they can access to internet.   see this diagram below :...
you need to replace your modem with a router that is capable of running Network Address Translation. You are trying to route private IP's (192,168.x.x) over the public IP (internet) network.
Jan 31, 2010 | Microsoft Windows 2000 Professional for PC
Setup Wizard says theres a problem connecting to network device
with a new router I would suggest to to start from scratch and do it manually, here's the manual
and I strongly suggest you give netgear a call if the manual setup does not work. feel free to post back although do it after following the manual setup instructions on page 11.
also provide more info like, isp and operating system and we'll try to help out.
Dec 24, 2009 | NetGear WNR2000 Wireless Router
Setup wizard doesn't locate wireless router.
Any old ethernet cable should be fine. The setup disc is generally used only for initial setup to establish communications between router and pc, and to also configure your internet providers settings. You can access your router from your pc by going to http://192.168.1.1 and you can change settings in the router from there instead of using setup disc. If you insist on using the setup wizard disc you usually have to set your computer's ip address to a specific number and possibly reset router to default state (see manual or http://www.linksys.com).
Jan 22, 2009 | Linksys Wireless-G WKUSB54GS Kit
Router cannot connect on internet at setup wizard
Hi pag Smartbro ang gamit mo hindi mo pwede gamiting ang setup wizard. Iba kasi ang paraan ng connection sa SMartBro. Mahirap explain it would be best if you call Linksys Philippine support since there are so many ways to connect Smartbro to a Linksys router. The number is 1-800-1-114-1695 toll free. or kung gusto mo sa Yahoo ID ko nalang mastersaintx message mo ko sa umaga.
Sep 03, 2008 | Linksys Wireless-G WRT54G Router
Need the driver for Linksys WRT300N V1 ... can't find the CD
The LINKSYS WRT300N is a standalone device, there are no software/driver needed on your PC for the router to work. However, there is an easy Setup Wizard that is in the CD that normally comes with the unit.
Unfortunately, Linksys did not make the specific Setup Wizard (Version 1.3) for the WRT300N available online. However, if you care to try the Setup Wizard for a WRT54GC, it may downloaded from the LINKSYS ftp site here. I used to have a WRT54G and I did make use of the Setup Wizard for that model. I upgraded to WRT300N. The setup wizard for the old WRT54G worked likewise on the new WRT300N.
Alternately, the WRT300N can still be configured without the CD or the Setup Wizard by logging into the Configuration Page (192.168.1.1). Remember to use LAN interface when setting the router (as shown in the connection diagram) and set your PC to an IP Address of 192.168.1.2, Subnet Mask of 255.255.255.0; Follow on screen instructions and enter settings/configurations manually.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information. Additionally, if you still prefer to have a copy of the original WRT300N Setup Wizard, pls include your email address that I may send it to you as an attachment.
Good luck and kind regards.
Nov 24, 2007 | Linksys WRT300N Wireless Router
D-Link Dlink DI-514 Air Wireless 2.4 GHz Router (A0177337) Logo
80 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
