Question about Ovens
Top oven does not get up to the set temp.,as set on the control knob,could it be the stat or is it something else.Regards Graham Cooker is a Parkin Cowan Ovation 60GLXa
    Problem Solver:
  • 8 Answers
All ovens have 3 basic parts. metal cabinet. element and thermostat. if the element is heating, even if it is only slightly it will be the thermostat. if it doesn't heat at all it most likely will be the element but can also be burnt or bad wiring connections.
Posted on Mar 15, 2011
Touch control not working on aeg d98000 cooker
I'm afraid you have a bad board. I had a neighbor with the same problem and he had to replace just the stove top part. Hopefully, yours is just the temp setting part, but it may not be that if you can control the oven setting.
Feb 24, 2013 | Ovens
Preway oven doesn't come to temperature
I Also have a wall oven by preway in a 1955 spartan trailer, basic same problem, I am told the control assembly that you turn to set temperature needs to be replaced, if it is adjusted to far on some part behind the controll knob it will screw up the new one also, Spencers appliance in Portland Oregon worked on mine years ago and was able to get parts, Good Luck
Feb 04, 2012 | Ovens
Bosh double oven. Temp is 100 degrees cooler on top oven, any ideas? both on bake mode
The fact that top oven is 100degrees less than bottom is no relation between the two; they are controlled by independent stat controls and if the only way you know if the temp is correct, is to set a temp (such as 350 degrees) and put a thermometer in that oven to see if the thermometer is with in 25degrees of the control settting. You need to do this for the bottom oven as well to see if it is aslo within 25degrees of the setting. then you make adjustments for each unit independently. If the controls are mechanical (knob), then the adjustment is within the control (usually by removing knob and serching for a small screw). If the controls are electroonic, then you need to search the circuit board to see if there is adjstments mounted on the board. Goodluck,Macgivor
Jan 31, 2010 | Bosch HBN 455 Stainless Steel Electric...
Hotpoint cooker, grill doesn't work but top oven does
If the elements 'look' okay, they probably are. The 'infinite control switch' is probably the problem. With out the use of a meter, it's guess work. Unless you can see a connection problem.
Sep 03, 2009 | Ovens
OVEN OVER HEATING
Hi, it looks like the main oven stat is faulty (the part behind the temperature control knob with the long capillary inside the oven). If it's overheating, then the stat is not switching off the element, hence the high temp. It needs replacing.
Cheers
Feb 19, 2009 | Ovens
I have an AEG cooker but the marking around the cooker knobs have
Hi.
You need thermostat knob and main oven control knob.
Nov 19, 2008 | Ovens
Electrolux EOG7330 gas cooker - electric timer fails?
Pull off bottom knob of oven shine torch down at 45degrees u will see a red plate turn off power suply and use a small screwdriver to push the plate turn power back on job done.PS Check all vents are clear to stop it over heating good luck.
Jul 18, 2008 | Electrolux EOG7330WN Gas Double Oven
Oven temperature
switch part of the stat mounts behind the front panel in the position of the temperature control knob. there is a capilliary tube coming out of the stat and the bulb at the end of this mounts in the oven.
Jun 24, 2008 | Ovens
Smeg ovens
quite easy. take oven out and remove top plate. you will see stat behind the temp control knob - usually just clipped on(sometimes stat becomes unclipped which will cause your problem as well)
remove stat and undo capilliary from mounts inside oven. reassemble in same way. note where wires go before you remove them!
Feb 26, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Diplomat Oven ADP3650 Instructions
User manuals are hard to find.
The problem I had was setting the clock on a single Diplomat oven, with no clock button. Here's my solution :
DIPLOMAT OVEN OPERATING INSTRUCTIONS
The Diplomat single oven is controlled by two knobs and a set of buttons along the middle of the control panel.
The left knob sets the temperature of the oven, while the right knob selects the function to be performed, e.g. fan oven, grill, etc.
The buttons along the middle set the cooker clock, the start and end times of cooking, and the “+” and “-“ buttons will increase or decrease the time shown on the cooker’s clock.
PLEASE NOTE THAT THE OVEN WILL NOT OPERATE UNTIL THE CLOCK IS SET.
If there is any interruption to the power supply (including manually switching off at the main switch) the oven will not operate until the clock is reset.
Here’s how to set the clock:
First press simultaneously the first two buttons to the left of the control panel. They are marked as a Bell symbol (Alarm) , and a steaming Cooking Pot (Start of Cooking Time). Then immediately press the plus “+” or minus “-“ buttons to increase or decrease the time displayed. When the desired time has been reached, leave it for a few seconds, and it will remain set at this time. Any further changes to the displayed time will require this procedure to be repeated.
Hope this helps!
Oct 10, 2007 | Ovens
Ovens Logo
65 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
