Question about Refrigerators
Water is draining into refrigerator, puddling below crisper drawers and on shelves
  • Refrigerators Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 19, 2011
My crisper drawers collect water
adjust your settings for what you keep in there...and you should be able to solve the problem
Oct 19, 2014 | Samsung RF265AA Bottom Freezer French Door...
Where is the drain hole for this model
Good Afternoon Friend,
I understand that you are looking for the drain hole on your Frigidaire refrigerator, model# FFHT1725PS, due to water building up on the shelves inside your refrigerator. There technically is no drain in your refrigerator. There is a drip pan, which collects water from the condenser underneath your appliance. There are some possibilities that are causing the water to build up on the shelves. First, make sure that all containers are covered. Condensation can evaporate from opened containers and create water on the walls and shelves. Secondly, make sure that the drawers that have your fruits and vegetables are completely closed and set to the correct setting. Fruits and vegetables are full of water. Thirdly, check to make sure that your doors are closing and sealing correctly. Moisture can come through an open door or a door that is not sealed correctly. Lastly, if it is hot and humid, make sure that you are not going in your refrigerator many times and holding the door open as well. Hope this is helpful.
-Best regards-
WP
May 31, 2014 | Frigidaire FFHT1725PS 16.5 cu. ft....
Water is collecting under the crisper drawers and on the the shelves
The fridge has a blocked drain...water from defrost cycle not able to get to drain pan. Remove rear panel in freezer and look at bottom....will probably have is built up at drain hole.....use a cup of water to clear until in runs down drain.(may need to check drain pan afterwards to see how full it is)
Jun 08, 2009 | Kenmore Refrigerators
Water draining under crisper bins & onto shelves. Try again
Your drain tube is stopped up. Take the panel off in the freezer section and chip away the ice in the pan below the coil. When you get to the drain hole pour hot water in it until it free flows. You will need a towel in the freezer to catch the excess water. Run some extra hot water through it to assure that you clean the drain out good.
Mar 15, 2009 | Frigidaire FRT21H8 Top Freezer...
Water collects on shelves and below the crisper bins at bottom
Your defrost drain hole is frozen closed.
Remove the back freezer panel and defrost the ice with a hair dryer.
Once the drain is clear poura 1/4 cup bleach in the drain hole.
Mar 11, 2009 | Refrigerators
Water puddles under the drawers
You have a blocked defrost drain look at item 56  in this picture. you need to clear this drain either with hot water or clear ice that may have accumulated in the trough. to me it looks as if there is possibly a cover over this area so you will need to remove drawers and shelves to get to it. message me back here with any comments or questions.. You can fix this yourself!! thanks Peyton 10058779-00002.png
Mar 01, 2009 | Refrigerators
Roper Refrigerator
open the freezer compartment loo for ice build up on floor of frezer especally towards rear behind back panel. sounds like you have a clogged/frozen defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials)
Mar 05, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
Fridge filling with water
There usually is a drain at the back of the fridge it's possible that this is clogged, This drain leads to an evaporation tray usually in the base of the fridge.
Oct 09, 2007 | Kenmore 94499 Refrigerator
Refrigerators Logo
104 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
