Question about Philips SA5125/37 MP3 Player
Philips gogear mp3 2gb
When I start it says PHILIPS then it says GOGEAR then right after that goes off
  • 1 more comment
  • strburst42 Oct 05, 2008
    it starts up; then it shuts off. and when i plug it in to the USB cable, my computer doesn't reconize whats being plug in.
  • crystlen May 11, 2010
    Well I tried FFlamehead11's solution and unfortunately it did not work for me. Now all my music and vids are gone and the mp3 STILL doesn't work. I even tried pushing a pin into the reset button on the bottom and it didn't work. I left it connected to my pc with the screen showing the battery charging and it even said it was fully charged. But when I turn it on it just goes to the go gear screen and then says BYE. GRRRRR!
  • FFlamehead11 May 11, 2010
    I have the same problem!! so wat did u do?! did u get it fixed?!
Yoo! i thinnk i fixed mine actually! i plugged it to my pc. deleted ALL my songs pics videos
THEn i unplugged it and turned it on and it STAYED ON! and went to menu!! then i turned off, plugged it, put back in all my songs and then unplug. and it works!! lol but i havent used it for a long period of time yet so hopefully it remains in working mode lol
Posted on Aug 20, 2008
The screen is frozen on the PHILIPS icon and when i reset it it did nothing, but when i put it on the charger then reset it, it starts charging, but when i take it off the charger it goes back to the...
Please follow the below steps and check if that resolves the issue:
  1. Press down on and hold the "Power" button on your Philips GoGear MP3 player.
  2. Press down on and hold the "Volume Up" button on your Philips GoGear MP3 player. Continue to hold both of these buttons down for three consecutive seconds. The MP3 player will turn itself off.
  3. Press and hold "Power" until your Philips GoGear MP3 player turns itself back on. Your GoGear will no longer be frozen and you can use it as normal.
If you require further assistance then please revert back.
Regards
Anand Gupta
May 04, 2011 | Philips GoGear ViBE Digital Media Player
I ran the battery on my MP3 player completely down and it shut off. I charged it and now all the songs are gone... is there a way to recover the lost songs?
Try this:
1)Perform a system reset, which won't erase your files, to attempt to correct playback. Locate a thin object, such as pen tip or unfolded paper clip and insert it into the small reset hole on the bottom of your GoGear. Hold the thin object in place until you see the unit shut down completely. Your system has been reset. Power the device back on to see if the corrupted files have been corrected. If the reset failed to correct the issue, perform a file recovery on your GoGear.
2)Initiate a file recovery by first connecting your GoGear to your computer. From your computer's "Start" menu, choose "Programs," "Philips Digital Audio Player," "Area Device Manager" and "Philips Device Manager." The Philips Device Manager software will be activated. Inspect your GoGear to confirm that it is turned off. Plug the small end of the supplied USB cord into the bottom of your GoGear while holding down the "Volume Up." Insert the larger end into a free USB port on your computer. Hold the key as the "Philips Device Manager" reads your GoGear and activates recovery mode. Click "Repair" and follow the onscreen prompts as given by the "Philips Device Manager" to complete the process of memory recovery. Disconnect your GoGear from your computer properly after the process is complete and restart your MP3 player.
3)Reload and replace the files onto your GoGear by first connecting your GoGear to your computer. Plug the supplied USB cord's small end into the bottom of your GoGear and the large end into your comptuer's USB port. Initiate Windows Media Player by clicking on its icon if it doesn't start upon connection with your GoGear. In the left pane of the WMP, click "Philips GoGear Aria." Click the arrow on the top left edge of the WMP window, followed by "Music." Highlight all files, and click "Delete." Click the "Sync" tab on WMP, and drag and drop the music files you would like to replace and reload into the "Sync List" panel. Click "Start Sync." The files will be freshly loaded onto your GoGear.
4)Properly disconnect your GoGear from your computer to avoid memory corruption by first closing all applications in use by the GoGear (WMP). Click the USB device icon in your system's tray (located on the bottom right corner of your screen). Follow the prompts in order to safely remove your GoGear from your computer. When your computer tells you it's safe to remove your GoGear, unplug the USB cord from your GoGear.
Hope this helps!
Apr 08, 2011 | Philips GoGear ViBE Digital Media Player
My 16 gb gogear froze
1 On your computer, select Start >
Programs > Philips Digital Audio Player
> Aria Device Manager > Philips Device
Manager to launch the Philips Device
Manager.
2 Turn off GoGear Aria before you
continue.
3 Press and hold the volume button
while you connect GoGear Aria to your
computer.
4 Keep holding the key until the Philips
Device Manager acknowledges GoGear
Aria and enters the recovery mode.
5 On the computer, click the Repair
button and follow the instructions of the
Philips Device Manager to complete the
recovery process.
6 When the recovery is completed,
disconnect GoGear Aria from your
computer.
7 Restart GoGear Aria.
The full manual is found here: http://www.p4c.philips.com/files/s/sa1ara16k_17/sa1ara16k_17_dfu_aen.pdf
Oct 29, 2009 | Audio Players & Recorders
I turn on my Philips MP3 player GoGear goes and turns itself off!
Install philips device manager that comes in the cd alongwith the player and then use the repair tab to repair the device
Aug 27, 2009 | Philips GoGear Flash MP3 Player
I turn on my Philips MP3 player GoGear and it goes off!
are yaar.....there is a hold or keylock button just unlock that....
Aug 27, 2009 | Philips GoGear SA178 MP3 Player
Vista no longer recognizes my gogear. Seems to have started after upgrading/renewing Norton 360.
Hi
Reinstall philips gogear drivers again and im sure it will work. This is probably due to your gogear drivers corrupted, reinstalling will help to repair the software. Check and let me know if vista recognizes your gogear.
Cheers
Shafie
May 08, 2009 | Philips GoGear SA6185/37 Digital Media...
"Updating player" at start-up
There is not a way around this - Philips is not going to issue another firmware upgrade for this model. It is one of those minor annoyances that you have to live with.
Sep 21, 2008 | Philips GOGEAR SA6045 MP3 Player
Some problems
Try downloading the more recent version of the HDD1830 software at the Philips website - www.usasupport.philips.com
Also, you can try both a Repair and an Update through Philips Device Manager: (Warning - both processes will delete all files form your GoGear)
1) Open up Philips Device Manager (Start --> All Programs --> Philips) - if you don't see it, then re-run the installation CD or grab the "Device/Firmware Manager" from the Philips website
2) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
3) Disconnect the GoGear from the computer and turn the GoGear off (if you haven't done so already) - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Jan 19, 2008 | Philips GoGear HDD1830 MP3 Player
Philips GoGear HDD6330
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Nov 20, 2007 | Philips GoGear HDD6330 MP3 Player
My philips mp3 wont work
-Tha Mp3 Doctor
Jun 02, 2007 | Philips HDD1630 MP3 Player
Philips SA5125/37 MP3 Player Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
