Question about Dishwashers
OE error report on LG LD-2120WH dishwasher - Dishwashers
  • 210 Answers
SOURCE: lg - LDS5811ST Dishwasher OE Error Code
In older units prior to mar 07 LG has had a problem with wires getting stuck in the insulation and breaking. Remove door panel and check for broken wires. (turn off power) Check for continuity splice and put insulation in between. This is most likely the problem.
Sgt 48
Posted on Jun 07, 2008
stradeteox
  • 88 Answers
SOURCE: LG Dishwasher LD-2050WH with HE error code
This is a heater error. The cause is either a bad heating element or bad thermistor (the thermistor is part of the heater assembly). The heater assembly will need to be replaced.
Posted on Jan 18, 2009
SOURCE: LG Dishwasher Model LD-4120M Error 0E
I had the same endless problem and finaly put a cleaning product through with heaps of restarts and now the machine works perfectly. So anyone out there with the OE error should try this inexpensive solution. If it does not work you have not lost much. You may need to restart several times during the process and is a great pain but maybe it will solve your problem .
Posted on Apr 21, 2009
  • 3230 Answers
SOURCE: Error Code OE
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
Posted on May 06, 2009
  • 3230 Answers
hi
Dishwasher LG ld-2120wh have F on the Auto switch, what does this mean
F is displayed when the dish washer is testing the water to see if more dishwashing powder should be used when in Auto mode. To do with saving the environment to use the least amount of detergent
Apr 15, 2014 | Dishwashers
How much salt do you have to place into LG
just use dishwasher tabs.no salt needed or rinse aid,lots greener too...
Sep 19, 2009 | LG Dishwashers
Instead of showinf a time my LG dishwasher (LD-2120w) has code: F on then during a cycle it stops and flashes 0E. I have found OE means to clean the filter which i think i have done, but the priblem is...
With an OE error, the next step is to follow the drain hose from where it connects to the dishwasher through the point where it connects to the drain.
Look for crushed hose, kinked hose. Then look for a plugged drain connection.
Please report back what you find. There are other things that ~could~ cause the problem. OK?
Aug 09, 2009 | LG 24 in. LD-12BW5 Free-standing...
Error OE
thats a drain problem , blocked drain hose , drain pump stuck or burned , last case scenario electronic control
Jun 18, 2009 | LG 24 in. LD-12BW5 Free-standing...
Error Code OE
Good Luck!!!
May 02, 2009 | LG 24 in. LD-12BS6 Stainless Steel...
Ld-1204w1
What did you find the problem to be?
On an LG dishwasher, I am not aware of an E0 error. But there is a "OE" error code (as in output error)
The first thing to check is the lower sump area - remove the filter beneath the spray arm and look everywhere for blockages that have slipped through. If that is not the problem, the drain motor has probably failed.
Good Luck!
Oct 19, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
Error
The ?OE? indicates drainage trouble. It could be a clogged in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. Good luck!
Sep 16, 2007 | LG 24 in. LD-12BS6 Stainless Steel...
LD-14AW1 keeps coming up with OE error code
Good Luck!!!
Oct 28, 2006 | LG 24 in. LD-12BS6 Stainless Steel...
Dishwashers Logo
237 people viewed this question
Top Dishwashers Experts
