I took apart and used dust sprayer on fan and cleaned it up good, but what is the heat sink I'm reading about? I only did the fan blades and area around it thinking that did it but it still shuts off . Also is the heat sensor that starts the fan included with the fan or is it a seperate part.
    Scholar:
  • 88 Answers
Heat sink is usually connected to the fan by copper tubes or fins, this is what disperses the heat from the CPU to outside the case. Sometimes the fan is directly on top of the heat sink but more often now the heat sink is next to the fan and outside air is drawn through these copper fins to remove the heat from the CPU.
Posted on Mar 15, 2011
Overheating
It is most likely a very dirty cooling fan and cpu heat sink. "Hard fix" take the case apart and use canned air to clean and blow the dust out of the fan blades and heat sink blades. Easy fix open one of the small back panels nearest to the fan out flow grill. and lightly blow the caned air towards the vent. Note always hold the canned air can upright otherwise the liquid will come out the nozzle and is very bad for the components Oh and make sure it is off and unplugged good luck
Sep 29, 2013 | Compaq EVO 600C Notebook
Clean heat sink
Yes you can, remove the cover off the desktop computer to get access to the fan and heat sink over the CPU.
Use a stiff brush to loosen the dust off the fan and heat sink and vacuum the dust off the fan and heat sink. You may need to use a can of compressed air to blow the dust off the fan and heat sink then vacuum the dust out.
Aug 24, 2012 | Gateway GT5220 PC Desktop
My x205-s9349 toshiba laptop is getting hot in the area of #1 hard drive and shuts down. I have vacuumed the case out and still does the same thing. this laptop has run hot ever since it was new.
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this. Use a fan assisted laptop cooling pad for addition cooling.
May 29, 2011 | Toshiba Satellite X205-S9349 Notebook
My dell optiplex gx 620 system fan run so fast and produse a lot of noise when i play games or downloading data from net
Open up the computer and clean the dust out of the fan and processor heat sink. If it is a temperature-controlled variable speed fan, it will probably not have to work so hard to keep the processor cool.
If it is a fixed-speed fan, it may be getting loud because the bearings are wearing out. Gently try to rock the fan blade unit - it should not have any wobble or slop in the bearings, and it should rotate easily.
If necessary, clean as much dust as you can out of the power supply without taking it apart.
Do not use a regular vacuum cleaner to **** dust off the motherboard. The high-velocity airflow may generate electrostatic charges that can damage the board. It's probably OK to vacuum out the heat sink if you hold the fan still to keep the vacuum cleaner from over-speeding it.
Apr 29, 2011 | Dell OptiPlex GX620 PC Desktop
My laptop turns itself of after 8 minutes - every time i turn my laptop on it lasts for about 8 ....
When the CPU overheats then it will shutdown (i.e. thermal overload) and won't boot up again until it has cooled down.If this is the problem is not fixed then the CPU will eventually fail.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Feb 13, 2011 | Computers & Internet
My nv7802 overheats and shuts off,fan is running but the heat sink gets very hot
The fan may be running too slow (faulty bearing) or the fan and heat sink assembly may be clogged with dust.
Check the CPU fan to see if it spinsfreely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Dec 30, 2010 | Gateway NV7802U Notebook
My cpu overheats
clean the cpu cooler slots and replace the thermal compound on the cpu ....make sure you clean off the old thermal compound .....only a thin layer of new thermal C will do all most see through ... hope this helps my friend
Oct 25, 2009 | Gateway 504GR PC Desktop
My Compaq Presario F730US keeps overheating the fan does not run properly what docking station do you recommend me to buy
I would recommend cleaning out the vents and geatsink grills with compressed air. I would then remove the heatsink unnit and replace the thermal grease on the heatsink and processor. Most laptops do not need any additional cooling if thier heatsinks are free of dirt, dust and debris. The compressed air can be bought at office supply chains. Just use short bursts of air and clean all the compartments including the cd tray. Just make sure to power down the laptop first and remove the battery.
Oct 05, 2009 | Compaq Presario F730US Notebook
Overheating problem, with fan stopping randomly
If it's overheating it's possible that either there's a problem with the fan, or the fan/heatsink is clogged with dust. If you know how to open up the laptop you can do that and use a can of compressed air to clean it out which may solve the problem. If not you'll have to replace the fan.
Feb 19, 2008 | Acer Aspire 3000 Notebook
Ecofan only turns slowly
These fans can be rebuilt! Like many others, our fan died after being placed in the center of the stove top. I took the two halves of the fan body apart, and scraped the heat sink compound off either side of the power plate. I then applied CPU heat sink compound that can be found at any computer or electronics store liberally to either side, and put it back together. The fan spins like new, spread the word!
Nov 28, 2007 | Cfm 802 Ecofan Table
Computers & Internet Logo
140 people viewed this question
David Payne
David Payne
