Question about Dell Latitude D600 Notebook
My laptop is sying INTERNAL HDD HARD ERROR! STRIKE F1 OR F2 ,BUT DOING THIS ITS JUST SAYING NO HARD DRIVE?/
    Sergeant:
  • 212 Answers
I'd say it's a pretty good sign that your hard drive is dead. (I hope you have backups)
It's pretty easy to replace.
There is a panel with one screw on the side underneath this model laptop. You can remove the screw and pull the drive bracket out with the drive in it. You can remove the drive from the bracket and buy a 2.5" EIDE laptop drive to put in. From there you can reinstall Windows from your system disk.
When removing and replacing drive, keep in mind there may be a plastic pin adapter on the old drive that you will want to put on the new drive....be careful not to bend the pins.
Posted on Mar 15, 2011
Get message internal hard disk drive not
This may mean that your computer is trying to boot from a non-bootable drive. Try hitting f12 when you restart the computer and select which drive would have your OS on it. You want to change the boot sequence to diskette drive as your 1st choice. The order should be Diskette Drive, Internal HDD, USB storage Device, CD/DVD drive.
Apr 08, 2014 | DELL Inspiron 15 3520 Cnfg 2 Lptp 3Yr 2nd...
How do i setup utility on dell laptop d610
If you have a hard drive issue, you need a new hard drive and then download the OS from windows, linux or whomsoever, then the drivers from Dell.
Dec 29, 2013 | Dell Latitude C600 Notebook
I have no picture. all i see is the words internal hdd hard error! it also says strike f1 key to continue or f2 key to run the setup utility. when i press f1 it say s no bootable devices
It would appear that the hard disk has failed and because the BIOS cannot find a drive, it is getting confused and continually resetting.
Fit a new hard drive and install your OS. Don't forget you will need to install all drivers that are not included on your OS disk.
Hope that helps.
Nov 19, 2010 | Dell Latitude D610 Laptop Computer -...
Says my computer has no bootable devices--strike F1 to retry boot. F2 for setup utility. Press F2 and the computer advises no hard drive is present. There is a 100gb hdd installed.
But unfortunately the HDD is not detected in the computer.
Reset BIOS.
Check your hard drive connections.
Change the cables if it is a desktop.
If all these fail to resolve the issue, check the hard drive.
Nov 18, 2010 | Computers & Internet
When i turn on my laptop it is telling me that there is no internal hard disk drive not found. To resolve this issue try to reseat the drive. Then it tells me there are no bootable devices--strike F1 to...
This seems the Hdd is Not getting Detected , First thing you can try is inserting the hdd back in the system and then get into Setup Utility by Pressing F2 and check whether the hdd is listed or not , If the HDD is not listed that means HDD has gone bad .you need to get a new HDD
Aug 29, 2010 | Dell Inspiron 1525 Notebook
Latitude delld610 Boots with the following
press F2 to get into the dell bios and be sure the HDD is listed as first to boot, Then if restart turns the same error, press F10 and run the pre-boot system assesment check. if error 0141 appears, your HDD is failing and needs to be replaced
Aug 24, 2009 | Dell Computers & Internet
Dell Inspiron 8500 started boot error message ?primary hard disk drive 0 failure, no boot device available?strike F1 to retry reboot, F2 for setup. Ran express diagnostics and it shows two errors: Error...
Call Dell if under warranty. Start shopping for a replacement hdd if outside of warranty. You'll need
your OS disks that came with computer (hopefully). If you don't have OS/recovery disks, you can get
them from Dell or even using somebody elses (match version with sticker on your laptop).
Check the hdd connection underneath laptop - make sure cable is not loose, etc.
Probably safe to say your data is gone unless you're willing to spend $$.
Jul 12, 2009 | Dell Inspiron 8500, Latitude D800...
Internal HDD hard error
By your description it is very likely your hard drive finally failed. You probably looking at total data loss unless you have made recently an backup of it. You will have to get a new HD and then you can install your OS and software.
Another more remote possibility is that when you opened some covers, you accidentally disturbed the HD connection causing this problem.
Just for clarification, was there a lot of dust inside ?
Hope this helps.
Jan 12, 2009 | Dell Latitude D510 Notebook
"no boot sector on internal hard drive"
i think you need to re-install your Operating System again since you got a new HDD wich is tottaly empty i assume so try to install your OS on the new HDD
let me know if it helped
greetings
Jan 02, 2009 | Dell Inspiron 6000 Notebook
Dell Latitude D600 Notebook Logo
142 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
