Question about Texas Instruments TI-83 Plus Calculator
A iron rod was measured in length and the measurements were recorded as follows: (i) 2.26cm (ii)2.28cm (iii)2.26cm what is the error percentage?
    President:
  • 2,080 Answers
Average Length = (2.26+2.28+2.26) / 3 = 2.267
Max Error= 2.28 - 2.267 = 0.013
Max Error % = (0.013 / 2.267) x 100% = 0.59%
Posted on Mar 15, 2011
Will a crank from a 600 grizzly fit in a 660 ?
Do you mean the crankshaft? ......
600 = Bore and stroke =95 mm by 84 mm
660 = Bore and stroke = 100 mm by 84 mm..
The stroke is the biggie..and they are the same!!.....BUT the rod length must to be exactly the same..
The bore doesn't matter..
...rod small end ID must be the same..NOW >> .....if the crank journals are the same size...something that will have to be measured..You need a both crankshafts "in hand" to do some specific measuring.. shaft lengths,shaft o.d.'s.. threads, etc.. if they match..go for it..
Jul 16, 2017 | Yamaha 2005 Grizzly 660 Auto 4x4
How to find the length ot the arc ,a circle has a radius of 45cm.
You can not do it unless you know the measure of the central angle sustending (supporting) the arc. If the angle is known, you use the proportionality relation that follows:
If angle is in degrees
(length of arc) / circumference=(measure of central angle sustending arc)/360.
Here the circumference is 2*PI*radius.
If angle is in radians , the relation is somewhat simpler,
arc length= (radius length)* (angle measure in radians)
It is clear that in the last relation, the unit for the arc length is the same as the unit for the radius.
Jul 15, 2011 | Casio FX-300MS Calculator
I want to know what stove I have?It is a fisher, doulbe door, width is 29`` depth is 26`` , height is 30``.
Double door Fisher is if the Fireplace Series. Pre 1980 stoves had the angle iron welded up the side that became the legs. Grandpa Bear measures 29 1/2 wide and takes up to 24 inch log. Grandma Bear measures 25 1/2 wide, and takes 20 inch log. AFTER 1980 the legs were short and did not extend up the stove corners to top. They were Grandpa Bear III and Grandma Bear III. Very close to the same sizes.
Dec 21, 2009 | Sport & Outdoor - Others
I have a coleman powermate 6250 I need to remove the armature so I can change the oil seal on the crank. How do you remove this
Here is how I did it. First unscrew the bolt holding the armature to the crank. Measure the bolt length and thread sizing(mine was 5/16-24) Go to menard's or any hardware store and buy a piece of un-threaded rod the same diameter. Buy a die so you can thread the end of the rod. cut the rod one inch shorter than the bolt length and make a kerf in the end for a screw driver blade. Now measure the inside diameter of the armeture hole( mine was 3/8) I then took a 7/16 tap and threaded the end of the armeture. Now screw in the rod you made, then screw a bolt into the end of the armeture and this will push the armeture off the crank without damaging it.
Dec 06, 2009 | Coleman Powermate Premium Plus 6250W...
Just bought a Alture can I get a short rod since our ceilings are
Yes, you should be able to find a shorter fan rod at Home Depot or Lowe's or other building supply stores. If not you could possibly shorten the rod that came with the fan by carefully measuring how much needs to be removed, disassembling the fan and using a hacksaw to cut the rod to the length you need.
Aug 20, 2009 | Hampton Bay 52 In. White Redington...
Deck unlevel cutting unevenly
with deck up,, take a ruler and measure mid way each side,,if off you have nut on the deck you can screw up to raise,doen to lower,, but if side to side level,, then you have 2 rods at the front at the front axle, measure the rods and make sure that both the same length if one is off turn to match the other,, but if you turn both make sure you turn both the same turns,, hope this help you,, good luck
Aug 09, 2009 | Garden
What cu. ft. size is my Whirlpool top loading washer model # LSQ9549LWO?
hi there. the best way to determine this is to measure the inside length, height and width and you will get cubic feet. Just be sure to convert each measure to feet. For instance 2 feet 4 inches = 2.33 feet.
Jul 28, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Have akai ap-b110 turntable needs belt. Can you tell me the length/specs
  • If you have the turntable belt:
    • State the type of belt used (Flat, Square, Round).
    • Pinch both ends of the belt.
    • Measure the pinched length.
    • Multiply the pinched length by two (2x).
    • If the turntable uses a Flat belt, measure its width (usually 0.187").
    • If the turntable uses a Round or Square belt, measure its thickness.
    • Please include the make and model of the turntable with the belt's measurements.
  • If you do NOT have the turntable belt or it is shredded:
    • State the type of belt that the turntable uses (Flat, Round or Square).
    • Use a piece of string to tightly follow the belt's path.
    • Measure the length of the string.
    • Measure the width between the rims of the motor pulley that the belt can pass through (usually 0.250 inch).
Jul 08, 2009 | Audio Players & Recorders
Texas Instruments TI-83 Plus Calculator Logo
32 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
