HAVE AUDIO BUT NO PICTURE. - Televison & Video
  • 11,361 Answers
LCD TV?
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Posted on Mar 15, 2011
I hooked up my wii on av1 with a component cable with audio on audio 1 and i have sound but no picture.
If I am reading this right, you are only hooking up one cable for audio. There is another cable needed for video. This jack is normally color coded yellow and labeled video out/in. You can use your audio cable to try this and then you will picture but no audio.
Feb 16, 2014 | Yamaha RXV371
AUDIO NO PICTURE
No picture is your problem? No model number but a suggestion if a LCD set---in a very dark room look at the screen with a flashlight--see a faint image of any sort there?
Nov 07, 2012 | Televison & Video
Powers on but no picture
Does the audio stay working and just the picture goes out, or does everything drop out picture and audio?
Oct 24, 2012 | LG 42LC2D 42 in. LCD HDTV
No speaker audio Magnavox plasma TV
Re check all connections on the boards that you worked on. Make sure they are tight.
Jun 18, 2012 | Televison & Video
We get audio, but no picture. There is no red
If you have audio and no picture it is the scaler chip burning out you need to stop the heat build up.
Either send it in to get it repaired or fix it yourself using a proven guide
Nov 29, 2009 | Microsoft Xbox 360 Console
Hdmi audio not working when conected to tv
Follow these steps to change the audio output settings for the HDMI option.
  1. Follow steps 1 through 8 above.
  2. From the Windows Vista™ default Start menu, click Control Panel.
    View Picture
  3. In Control Panel, using the default Control Panel Home setting, click Hardware and Sound.
    View Picture
  4. In the Hardware and Sound window, under Sound click Manage audio devices.
    View Picture
  5. In the Sound dialog box, click to select Digital Output Devices (HDMI).
    View Picture
  6. Click Set Default, and then click OK
    View Picture
Note: The default audio setting for your notebook is Speakers / Headphones.
You must change the audio output back to the Speakers / Headphones option for the computer to once again be able to use the internal speakers and headphone jack.
Sep 24, 2009 | Gateway T-1620 Notebook
Audio Yes, Picture No
From your description, it could be the back light has 'gone'.
Feb 16, 2009 | Sony BRAVIA KDL-40V3000 Television
Soyo dylto32c
The DVI input on this set is meant for picture only.. ex. to display computer picture.
if you want audio with your picture. you must connect to either inputs YCBCr or YPbPr which both of those inputs has audio inputs.
Mar 19, 2008 | Soyo DYLT032C 32 in. LCD Television
There audio but no picture
I don't know how you connect the unit to the tv.
Let's just start on basic:
composite video/audio(yellow-video, white/red-audio) connect to TV composite video/audio input behind the TV.
If the audio works but no picture,try to use another video input behind the tv.if that still doesn't work,use a different video cable!
Jan 20, 2008 | Toshiba SD-V392 DVD Player/VCR
No Audio on Primary Screen
HELLO . WELL THE DIFFRENCE BETWEEN THEM IS THAT THEY ARE TUNER'S AND THEY ARE SEPRATE FROM EACH OTHER.!!! JUST LIKE THE VHS TUNER'S YOU HAVE .!!! THERE IS THE PRIMARY WITCH .!!! WOULD BE (A) AND THEN THE SECONDARY WITCH WOULD BE (B) IT SOUND'S LIKE YOU NEED TO REPLACE THE AUDIO BOARD. OR THE (IC'S) ON THE BOARD. IT WOULD BE CHEPER TO DO. IF YOU KNOW HOW.? " WELL "GOOD LUCK"
Aug 28, 2006 | Sony KP-61V75 61" Rear Projection...
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
