Question about Dell Inspiron N4010 Notebook
My Dell Insipiron N4010 intel core i3 fan running continuously and laptop easily overheated even using external cooling fan. Already clean up dust(as suggested in dell website, update bios and did diagnostic check) but the heat remain unchange pls help.
  • 784 Answers
Wath os you uses? In windows you can set this parameters!
Posted on Mar 15, 2011
    Scholar:
  • 88 Answers
These fan are meant to run constantly at a low power and on high when using a lot of processing power (like playing a game or HD movie).
I would boot into Dell diagnostic and make sure the high and low settings of the fan aqre working properly it may be that the fan is on high all the time when it should be in low mode.
Dell Diag. Press F12 at boot Select Dell Diagnostics Go through the basic diagnostic ~5 minutes After basic diag the advanced diagnostic will start Go through the menu and select the Fan test
Hello..my laptop is dell inspiron n4010..well the problem with my laptop is that the fan doesn't work when the laptop is on..and due to excess overheating the laptop becomes extremely slow.the wor
buy a coolpad .its cheap and have 2 or 3 fans in it some have even 4 fans
and it is very easy to attach with laptop through usb port just like a pendrive.
buy it . coolpad will prevent ur laptop from over heating.
Nov 16, 2012 | Dell Inspiron N4010 Core I3 2.53 Ghz...
I have lenovo z560 (ideapad).it got off automatically,,,
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Oct 05, 2012 | Lenovo IdeaPad Z560(0914-3NU) NoteBook...
Sudden Shutdown due to Overheating
either your power adapter os faulty or the cooling fan inside the laptop had failed forcing the laptop to shut down as safety precaution.
Aug 29, 2012 | Dell Inspiron 14 N4010 Laptop 4g 500gb...
Dell inspiron n 4010 hangs often
I suggest you open the laptop, and clean it out first. THEN go on with the diagnoses.
Dell Support > Inspiron n4010 Notebook PC > Service Manual,
http://support.dell.com/support/edocs/systems/insN4010/en/sm/index.htm
1) FIRST remove all power. Remove the AC adapter (Charger) and Battery.
2) FOLLOW Anti-Static Precautions.
Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components on a computer.
Relieve your body of Static.
You should use an ESD wrist strap, and connect it's alligator clip to a good ground source.
This is an example of an ESD wrist strap,
http://www.radioshack.com/product/index.jsp?productId=2103245
This pictorial guide for disassembly of an Inspiron n5010, should help also.
http://www.insidemylaptop.com/taking-apart-dell-inspiron-n5010-inspiron-15r-laptop/comment-page-1/#comments
The screws, and cables, etc., are in a different place, but disassembly is still the same.
Use a can, or two, of compressed air for computers.
Also you may wish to use Q-tips, and a soft small brush.
(Makeup brush? )
DO NOT use a vacuum!!!!
A vacuum creates Static electricity.
For additional questions please post in a Comment.
Regards,
joecoolvette
May 15, 2012 | Dell Inspiron 14 Laptop Computer (Intel...
Dell d610 shuts down while playing games
Some games require more processor use, some less.
If the games that cause your computer to shut down feature high resolution graphics or fast 3D rendering, then the problem could be insufficient processor cooling. Once the processor gets overheated, it goes into thermal shut down.
If, while you play, the computer runs hot before it shuts down (check the cooling fan outlet), then these are some of the possible reasons:
-cooling fan blades could be obstructed by dust - cooling fan needs to be cleaned or replaced
-heatsink radiator and / or air outlet could be obstructed by dust - also need(s) to be cleaned
-thermally conductive grease on the microprocessor heatsink could be
partially or entirely dried up - old grease needs to be carefully removed and new grease applied (caution - do not use any kind of thermal grease that contains metallic particles like silver or aluminium - you might short out the processor - only use the kinds which are electrically nonconductive)
of course the problem could be elsewhere, but the above mentioned problems turn out to be a common issue with many laptop computers after a few years use, regardless of manufacturer brand and model, also it could be any of or the combination of any or all of the above problems (obstructed air outlet leads to more dust being deposited on the fan blades, more dust on the fan and outlet leads to processor overheating which leads to thermal grease drying which leads to even more overheating and so on...)
hope this helps somewhat
regards
triarcuate
Mar 31, 2012 | Dell Latitude D610 Laptop Computer -...
MY DELL E 1505 IS OVER HEATING AND GETS HANG
Due to their small size and lack of ventilation, laptops tend to overheat more than desktop computers. A noisy cooling fan that runs continuously is one sign that your laptop is overheating. Laptop overheating can also cause a loss of performance, system crashes, and even permanent damage to components. The goal is to make sure your laptop has proper ventilation and is kept as cool as possible.
1.Always use your laptop on a tray, desktop, or other cool surface. If you use it on your lap, make sure clothes, upholstery or bedding are not blocking the case vents. Blocked vents are the number one cause of laptop overheating.
2.Use an aerosol air duster, or can of compressed air, to blow dust from the air intake vents. Air intake vents are a set of slots on the side or bottom of the case that allow cool air to flow into the laptop.
3.Clean the cooling fan exhaust system. The cooling or CPU fan is located on the side or back of the case. A clogged CPU fan vent keeps hot air trapped inside the case. Use an aerosol air duster to loosen the debris, then use a vacuum cleaner with crevice tool to vacuum out the dust and dirt.
4.Use a commercial laptop cooler. A laptop cooler pad is an external USB powered fan that serves as a base for your laptop. If your laptop generates a lot of heat, even with a clean cooling system, a laptop cooler will extend the life of your laptop.
5.Adjust your BIOS settings. Most laptops have features built into the system BIOS that allow fan speed, CPU temperature alarms, and other settings to be adjusted. Read your owner's manual to learn how to enter the BIOS and change the settings for your particular laptop model.
Sep 26, 2011 | Dell Inspiron E1505 Notebook
I have heat issue in my laptop. Laptop is getting heated so soon and video is getting very slow. I have nVidia graphic card. Kindly help me out of it.
So i suggest you that you can buy a new cooling pad for your laptop as well as check whether the zink paste is available between the processor and the heat transferring metal for more info reply me
Jun 18, 2011 | Computers & Internet
Dell Inspiron N4010 core i3 Error Code 2000-0146
i've looked all over for this error code. Only reference i could find was in this forum
http://en.community.dell.com/support-forums/laptop/f/3518/p/19370875/19845733.aspx#19845733
hope this helps
Apr 06, 2011 | Dell Inspiron N4010 Notebook
My Dell 610D runs for about 15 minutes getting progressively hotter(speed fan) and then just stops working?
It sounds like the DELL is overheating and shutting down and if it cannot start up again straight away until it has cooled down then it is definitely a thermal overload (overheating) problem.
If the fan is OK then the fault is most likely dust clogging the fan and heatsink assembly.
The fix - loosen the dust from the vents, fan and heatsink assembly and vacuum/remove the dust off these components.
Use the laptop on a flat hard surface and/or place small pads to increase the height and ventillation to the laptop.
If the problem persists then there are products such as fan assisted cooling pads that you place the laptop on to provide addition cooling to the laptop,
If you continue to ignore this problem then eventually the CPU chip will fail.
Dec 24, 2009 | Dell Latitude D600 Notebook
Dell Inspiron 1525 keeps overheating and switching off.
Only do this if you feel competent in doing so.
Pulling apart laptops is not for the faint of heart.
If you really must do it there are some
good guides here.
An alternative is to get a can of compressed air used to clean computers. Put the nozzle on and spray it in every hole you can see without putting the nozzle itself inside the laptop.
Do this outside with glasses on.
You may also want to remove the hard drive and ROM drive.
Take a
peek here for more ideas of what is involved.
There are a few are tips for various things in there.
DON'T touch the CPU cooler unless you know what you are doing and have some thermal grease for CPUs to hand.
To make newer laptops last longer between cleaning a good 3 fan cooling pad is suggested.
never use a laptop on soft surfaces as the ventilation can act as a mini vacuum cleaner and encourage dirt build up.
Soft surfaces also block the vents causing fans to run more and burn out sooner.
Hope this gives you the information you need
Nov 21, 2009 | Intel Cpu Core 2 Duo T8100 2.10Ghz...
Dell Inspiron N4010 Notebook Logo
1,212 people viewed this question
Alun Cox
