Question about JVC Televison & Video
What kind of bulb do I need to replace the lamp? And where do I get it from?
    Brigadier General:
  • 8,909 Answers
If you consult your manual it will give you the detail required to order.
Try googling the description, www.espares.co.uk or indeed the manufacturers web site to find an authorised dealer.
Hope this helps.
Posted on Mar 15, 2011
Front left dipped beam defective - 2009 Volkswagen Passat. What kind of bulb does it need and how do I change it?
The most common bulb is a H7 to replace remove the cover on the rear of the lamp. Twist bulb holder anti-clockwise and remove from socket. Replace bulb, (Do Not Touch Glass) refit in reverse order. And be patient they are delicate.
Apr 30, 2017 | Volkswagen Cars & Trucks
Do I need to remove the front bumper on my 1992 Cadillac Deville to chang parking light bulbs?
Kind of a silly question, removing a
bumper for a parking lamp
How about getting under it before you came here
& reach up & turn the lamp socket & pull it out &
check the bulb/lamp
Oct 31, 2014 | Cars & Trucks
Kitchenaid Superba KERC607 oven light bulb is out.
Try tightening it first clockwise just a little then undo it,sometimes you have to get a bit physical with these things! make sure the main switch/isolator is off,take out lamp,note type and replace.
Jan 10, 2014 | KitchenAid KERC607 Electric Kitchen Range
Projector cp-sx635 lamp indicator glows red (RED). intimate trouble shoot pl
sounds like the bulb will not fire up. most likely cause is the bulb needs replacing
Jan 03, 2013 | Hitachi CPSX635 4000 Lumens LCD Projector...
Bulb or Ballast?
If your old lamp is still working fine and the new lamp is not, then you bought a defective lamp. Get your money back or exchange the lamp.
May 17, 2012 | Panasonic PT-52LCX66 Projection Television
What bulb do I use to replace bulb under microwave MH1170XSQ-3
You can use a standard appliance lamp 25 or 40 watt unless this is a special lamp. If it is a special (remove it to determine) you will have to replace it i kind.
Thanks for your question at FixYa.com
Feb 16, 2010 | Kitchen Ranges
Lamp(lite bulb) is dead - need to buy replacement and install it
Click here to find the lamp for your TV. You will still need to use the existing cage assembly, once you remove the old lamp you will be able to see how it's assemble.
For the lamp replacement instructions, you will need to download the owner's manual and go to page 16 to 22 to know how is done.
Good Luck.
Jan 06, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Brake lights
hi from uk not too sure on elantra but will try to help? if car is hatchback ? lift up hatch and look at the water drain channel alongside lamp? if there are 3x screws? unscrew and lift lamp off then unclup bulb/lamp board from lens bulbs are bayonet fitting if saloon then open boot look to rear of lamp in boot for either clip on panel or carpet covering lamp rear remove and look for some kind of nylon head screw bolt/s or 10 mm nuts? that my hold the lamp in place to body? or you may ?find the bulb/lamp board is simply a clip in to the lens assy as 1st example ? in that case just unclip and change bulb/s with no need to remove lens assy with a little patience you will succeed hope this helps
Nov 01, 2008 | 2006 Hyundai Elantra
Do i need a new lamp
i have this kind of tv1.gif model ru-52sz30 and same problem which i fixed by replacing the bulb. there is an access door at the back of tv that you can replace the bulb. if you need more help just post reply again.
Sep 23, 2007 | LG RU-52SZ30 52" Rear Projection...
Televison & Video Logo
140 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
