Question about HP PSC 750 All-In-One InkJet Printer
SCANNER FAILURE, SCANNER WARMS UP AND THEN GOES INTO SCANNER FAILURE MODE
  • HP Master
  • 7,733 Answers
Copy goes through scanner but comes out blank on screen. I know it's being inserted correctly (not backwards).
I'm a 99% sure that you've got some hardware problem with your scanner, probably some internal sensor it has is failing. Just as a test, you should install this scanner on another computer - ask a friend for help - test it and if failure persists you have two options: Live with the failure until it goes worst and stops scanning at all or you take it now to repair.
On the other hand, if it works ok on another computer, try to uninstall it completely and reinstall it.
Dec 22, 2014 | Fujitsu fi-6130z - Document scanner -...
1996 jimmy goes to limp mode after it warms up gives 1886 code
drop the catalytic converter and test drive. It could be clogged
Mar 17, 2014 | Chevrolet 1996 Chevrolet Blazer S10/jimmy...
My car starts without problem but suddenly stops on the way and very difficult to start afterwards
This canbe due to a faulty fuel pump or a failure of the HT circuit when the engine warms up or the circuit warms up.
The fuel pressure can drop when the temperature goes up in the engine so check the fule pressure when the engine stalls.
Secondly check the HT int he spark plugs when the engine stalls to confirm if there is loss of LT or failure of the HT coil or HT wires.
Apr 09, 2011 | 1994 Nissan Pathfinder
Failure in initialization of Scanner. Scanner is offline or , scanner is turned off.
First check if the scanner is working in 'offline' mode by 'counting' a few pages.
Connect to the comp, if SCSI is the interface, you need to start the scanner first, if USB you can connect the scanner even after comp powering on. If the scanner is not recognised, reinstall driver software and scanning software.
S. Mohan, Chennai, India
Dec 21, 2010 | Canon DR-9080C Path-Through Scanner
My printer still prints, but make noise when the scanner lamp warms up. After that, the screen says, "Scanner Error 5". What's the problem?
Hi tatnle,
This is due to a hardware failure, the scanner assembly and the formatter board will need to be replaced.
Try doing a hard or reset or nvram:
1. Turn the printer off
2. Hold down the enter and the * button
3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
if this does not work contact hp 1800-334-5144.
Al
Eliteprintersolutions@gmail.com
Jul 15, 2010 | HP LaserJet 2840 All-In-One Printer
Tv comes on and soon as it warms up picture goes goes black
Most likely this is caused by the failure of the inverter for the high voltage required by the backlight, 2nd most likely is the failure of the fluorescent backlight itself.
Aug 28, 2009 | Insignia IS-LCDTV32 32 in. Television
Scanner Failure
Scanner failure means the scanner is not making enough light to see the home position. It happens when the scanner lamp ages or is covered with dust. Cycle power is just power off and on again, and see if it goes away.
Jul 02, 2009 | HP Photosmart C6180 All-In-One InkJet...
Dell Inspiron 9400 display goes blank after a few minutes
If the issue occurs in the safe mode, then I'm suspecting a failure of the LCD backlight. (It warms up and quits) Also see if video stays on using an external monitor. If it does, then the LCD is most likely failing.
If video goes out on an external monitor as well, then the Video card is failing due to overheating. Make sure all vents are free of dust (Clean with canned compressed air) and the all fans are functional (Run the fan test in diagnostics) If fans check up, then video card is failure point. If fans fail diags, replace affected fan 1st
May 21, 2009 | Dell Inspiron 9400 Notebook
My 2300W warms up but does not print page
This is a regular problem with this printer.
When it goes to sleep mode - it really hibernates for ever. . .
Looks like the only way is to switch on / off.
Feb 24, 2009 | Minolta magicolor 2300W Laser Printer
Scanner Falure Issue
Clean Scaner Unit Properly its not easy to done
other wise all engineer
May 26, 2008 | HP LaserJet 2840 All-In-One Printer
HP PSC 750 All-In-One InkJet Printer Logo
185 people viewed this question
Seeker5211
Seeker5211
