Question about Karcher K2.26 Electric Power Washer
My 'k' pressurewasher keeps cutting out - Karcher K2.26 Electric Power Washer
  • 92 Answers
Dear Sir,
The power washer stops when the gun is closed. This happens because pressure is exerted on a control valve (Spill Valve)...which in turn touches a micro switch and cuts electricity. Now most probably your machine is cutting out because the spill valve is getting faulty or stuck down and closing the micro switch. This happens when one stores away the machine with pressure still in it. NEVER store a power washer with pressure in it. The spill valve also gets gammed and faulty because left with soap and machine not rinsed. I rarely service spill valves...I change with a new one.
To locate the spill valve open cover (using a TORX T15screw driver)...and where you see 2 wires coming out...there is the spill valve. If you can manage to do this..you can try if you want to lubricate it by spraying SILICON spray. If you get it out..you use silicon grease.
Sometimes these machines have the spill valve incoporated with the head....in that case the whole head must be renewed. I wish to tell you to try using the machine without the lance. If it works correctly, then you have a faulty nozzel in the top of the lance. IMPORTANT...never run a power washer with water being fed!!!!
Regards,
Fulltech.
Posted on Apr 24, 2011
  • Martin Grech Apr 24, 2011
    Please note that I am not responsible, for any misuse, misinterpretation, damage caused to inexperience work, incompetent workmanship and damage or harm caused by irresponsible use of this advice. This is just advice and cannot be held responsible for work being done when myself I am not present.
    Fullteh.
Craftsman pressurewasher
What is the pressure washer problem?
Aug 17, 2014 | Garden
Spark plug cavities are filling with fluid
fluid? oil or water, if oil bad gasket, if water ,stop pressurewashing engines.
bad valve cover gasket,
the 60k service, replaces that, so that was skipped.
try doing service points.
Sep 26, 2013 | 1991 Honda Civic
Elect. motor dosnt turn off when i release triger
high pressure cut out switch is faulty or not enough pressure to activate switch . more likely the first.
it migh be a simple micro switch . inside a platic housing on the end of the pump inside cover.
Jul 10, 2013 | Campbell Hausfeld Elec pressurewasher...
Builds up pressure won't spray
pressure relief valve is faulty. replace.
Aug 10, 2009 | Garden
Karcher K2.26 Electric Power Washer Logo
443 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
