Question about Ovens
The grill part works OK but the oven part doesnt , there are no lights on the knobs for the oven yet there are for the grill ??
    Problem Solver:
  • 8 Answers
There is a electrical interlock between grill and oven to prevent both operating at the same time. this may either be as a selector switch or on the grill control itself.
Posted on Mar 15, 2011
3 Suggested Answers
protek480
  • 1714 Answers
SOURCE: Hotpoint cooker, grill doesn't work but top oven does
If the elements 'look' okay, they probably are. The 'infinite control switch' is probably the problem. With out the use of a meter, it's guess work. Unless you can see a connection problem.
Posted on Sep 03, 2009
Testimonial: "very useful thanks"
  • 250 Answers
SOURCE: grill knob doesnt want to turn on without wiggling
The last time I asked, espares could provide a replacement which is what you need to do. If you can't find it listed, there is a section on it where you can ask for a quote.
Posted on Sep 17, 2011
Push knob in on oven sparks & lights release knob flames go out
Often on ovens you have to hold the knob down for a period of time before the flame will stay alight.
Try getting the oven lit then holding the knob down for 30 seconds. That should be more than enough time if that is indeed the problem.
Is it a new oven or has the problem just arisen? It
Jul 23, 2015 | Ovens
Hi I have a 720GRa rotostar double oven and grill when I turn the top oven/grill knob it turns but nothing works eg lights on the front the fan or the ignition but the oven works fine it worked this...
I suggest that if you have more than one knob of the same type, these knobs are usually removable by pulling straight out. Pull the knobs out and compare the inside. I would not be surprised if a metal insert is missing or the inside is stripped. Hope this suggestion is helpful.
Nov 20, 2014 | Ovens
Grill gas comes on but on release of grill knob, the gas goes off.
I would arrange a service call from a registered gas safe engineer.
Apr 13, 2017 | Electrolux Ovens
Smeg oven UK80MFX1 troubleshooting
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Nov 30, 2011 | Smeg Ovens
Grill knob doesnt want to turn on without wiggling then clunks on,top oven(same knob different direction turn)is ok.
Sep 14, 2011 | Stoves 720EF Electric Double Oven
Both lights on the top oven work when using it as an oven but when using it as a grill, they don't! There doesn't appear to be any other fault as the oven and grill still work fine. Any thoughts...
The unit is working as it should. The top oven lights will only come on when the top oven control knob is turned on. The grill control does NOT turn the lights on. If you want to see what you are grilling, then you should turn the top oven control on to its first position. This works even if the grill is operating.
May 10, 2011 | Stoves 720EF Electric Double Oven
Stoves 720 EF Electric Double Oven Model No 059040415 -when you turn the grill knob there is no light and it doesn't do anything at all - the grill is not working. However, the element must be working as...
First things first. The oven element is totally separate to the grill element. The clock has to have a time set for either the top or bottom oven to work, whereas the grill will work without the clock being set.
The control knob for the top oven is the ONLY control that will turn the top oven lights on, the grill does not turn the lights on. ( If you want to watch your toast, you have to turn the top oven switch on to the first setting as well as operating the grill control).
To prevent the grill being operated with the door shut, there is a micro-switch on the door hinge that allows the grill to operate ONLY when the door is down. The grill control also does not illuminate unless the door is down. There are two options on the grill control - right or left. One way is the inner element only and the other is both inner and outer ones.
So if you have done all that and it still doesn't work, then the micro-switch could be faulty.
Best of luck
Nov 23, 2010 | Stoves 720EF Electric Double Oven
My grill doesnt seem to be working,the oven seems to be ok making all the noise and stuff but the grills just not playing ball! nany help would be appreciated!
More than likely the grill element has failed, if the element light comes on, then I would go for the element.
If no light, then probably the grill switch is faulty.
Nov 14, 2010 | Zanussi ZBF360 Electric Single Oven
I have had 3 engineers out to try and fix my stoves 720gra cooker and has changed all the printed circuit boards ,and all other parts but still the top oven and grill doesnt work and has now been classed...
check the voltage on the spark generator,should be 240dc or 110 ac.
or it could be the harness(wires fron spark generator to ignition) to check harness do a continuity test,an electricion will know,or get a electirc tester and do it with the instructions.
Oct 01, 2009 | Stoves Premier 720GRa Gas Double Oven
Grill faulty on my double oven
Creda reflection double oven had the same issue, both ovens work but the grill was either hot or cold, no temp control. I changed the thermostat first, due to being a novice and not fully understanding how things worked. it didn't help so I have changed the grill regulator,( bit that the knob fits onto) and it has solved the issue. I expect this to be the same with most top oven and grill combinations with the oven working but the grill only being hot or off.
Apr 07, 2008 | Ovens
Ovens Logo
106 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
