Question about Cycling
What size wrench needed to tighten spokes on huffy santa fe bike
    Brigadier General:
  • 8,546 Answers
Replace the spokes on my huffy 18 speed 27 inch bicycle
building and truing wheels is a specialized skill that takes a lot of practice. Most manufacturers use robots to build the wheels to save on labor costs. To have a human build a wheel can cost more than $50 per wheel for the labor. Spokes retail for about $1-$2 a piece and include a brass nipple. Spokes also come in different gauges. Most bike shops that sell spokes usually only carry a few sizes in stainless steel.
If you are only replacing one or two spokes you can take the broken spoke to a bike shop and they can measure it and hopefully have the right size in stock to sell you a replacement. Use the right size spoke wrench for your spokes to unscrew the nipple from the broken spoke, you will then be able to remove (spokes can be very flexible and will bend a lot to get them out of the hub). Observe the adjacent spokes and the lacing pattern to re-install the spoke in the hub and thread it into the new nipple that came with the replacement spoke. Put the wheel back in the frame and use the brake pads as a reference guide to tighten and true the adjacent spoke nipples until the wheel no longer rubs on the brake pads and you are satisfied.
My personal opinion is that on a Huffy, it is faster, cheaper and easier to buy a replacement wheel from your local bike shop for $35-$45. The spokes, rims and hubs used on Huffy's are of very low quality (most don't even use stainless steel spokes) and a new replacement wheel from your local bike shop (LBS) will be ten times better than trying to fix the old original equipment, IMHO.
Nov 18, 2015 | Huffy Cycling
How do you replace the spokes on the rear wheel of a huffy 18 speed bicycle
you will need several specialized bike tools that will make this cost prohibitive for the DIYer unless you plan on doing more wheels. Most local bike shops can sell you a replacement wheel for between $35 and $50 and remove and reinstall the freewheel, rimstrip, tire and tube and reinflate it for about $8-10. Also the quality of this replacement wheel will be a much higher than the original Huffy wheel.
If you still want to do it yourself, you will need a freewheel removal tool for your specific brand of freewheel or cassette (there are about a dozen different types of tools out there, so make sure you get the right one). You will need a spoke wrench of the right size for the spoke nipples you are using, there are three common sizes and a couple more odd size ones out there. You are looking at about $20-$30 for those tools. You should use a truing stand to true the wheel after the spokes are replaced ($150-$400) but you can "get by" with using the brakes in your bike as a reference. Spokes will run you $1-$2 each. If you don't have a special metric spoke ruler ($10-$15), most LBS's will measure them for free (all bike parts are measured in metric). The details of lacing a wheel and getting the tension right is beyond the scope of this short answer and I recommend that you either try to find a book on the art of wheel building at your local library or buy one off of Amazon ($25-$45), there are several good ones out there and video tutorials also. If you plan on doing more than one wheel then I highly recommend it and take the time to learn the art, there are few of us left out there that can actually build a wheel these days.
Rear wheel wobbely
Not enough info here. Is it the rim or the hub that is wobbly? If the rim is out of true (and not actually bent) the spokes can be tightened to bring it back into true. If the hub is loose then the bearings need to be adjusted. Either adjustment can be done by your local bike shop for $10-20. A broken spoke can also make the wheel go out of true, this will cost a little more to fix.
Sep 09, 2015 | Huffy 26 in. Cranbrook Cruiser Bike
My bikes handlebar is coming out on the left side. I don't really know anything about bikes so I need help. (Its a 26" Huffy Mountain Bike)
On the steering stem were the handle bars go through there will be a clamp. This clamp will have one, two or four bolts tht clamp the handle bar.
Depending on the type of bolt used on your bike you will need a ring, socket or allen wrench. Loosen these bolts of about two turns anti clockwise and center your bars and then tighten the bolts.
May 31, 2015 | Huffy 26201 26-inch Mens Granite Hard Tail...
How to fix the neck on a bike
They tighten with several different size or types of bolts. Easiest is headbolt with 1/2 inch wrench. Some use hex or allen wrench bolts, usually 4. These may be 5 or 7 mm. If these aren't on your bike, try sheltonbrown.com for assistance or take it to local bike shop
Jul 23, 2014 | Huffy Cycling
What size spoke wrench do I need on a 2012 hd flstc?
Hi Anonymous, for more information on your question please visit the websites below and good luck:
Cycles Spoke Wrench 2000100
Apr 16, 2012 | Harley Davidson FLSTC Heritage Softail...
What size socket/wrench is used to remove oil pan plug from 2002 Hyundai Santa Fe V-6?
My 2005 Hyundai Santa Fe is a 17mm. I also made a video showing how to change the oil.
Jan 15, 2012 | 2002 Hyundai Santa Fe
How do I tighten the stem bolt on the handlebar stem?
If you just need to raise the height of the stem, all you need to do is loosen the hex nut at the top of the handlebar stem with a box wrench or adjustable wrench. This is the head of the stem bolt. Once loosened enough the stem should slide up and completely out (if necessary) of the stem casing. There is a tightening mechanism consisting of two soft metal pieces that tighten against each other when the stem bolt is tightened. When this is loose you can raise the stem to various heights. If you find you cannot raise it to your desired height you may need to replace the stem and bolt. However, if the bike has been sized properly to fit your leg length, you should have no problem there. Once the height of the stem is satisfactory just tighten the bolt while keeping the stem straight and you'll be ready to go!
Oct 30, 2010 | Huffy 26 In Ladies Bay Pointe Bike
Removing filler plug from transfer case
On an 02 Santa Fe the Transfer Case Filler plug requites a 10mm allen wrench. A socket type works best.
Apr 06, 2009 | 2004 Hyundai Santa Fe
Cycling Logo
1,622 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
