Question about NEC MultiSync LCD1770V - Flat panel display - TFT - 17" - 1280 x 1024 / 75 Hz - 0.264 mm - VGA (... Monitor
When I have the screen set below the max resolution, I keep getting a popup throughout the day to change the setting to max resolution. But I don't like max resolution because the print is too small.
  • 1,381 Answers
Hello karen
You can accept the max resolution .
Now , you just need to alter the DPI , meaning the items dimensions by making a right click on your desktop and selecting :
under Windows 7 : screen resolution \ make text and other items smaller or larger ;
under windows XP : properties \ settinds \ advanced .
Best regards,
fanaudi .
Posted on Mar 15, 2011
  • 11,361 Answers
Here is the manual: http://www.retrevo.com/support/NEC-LCD1770V-Monitors-manual/id/279dj981/t/2/
I believe you can turn off the resolution warning using the on screen setup menu.
I have a compaq monitor that has a popup stating Input signal out of range. Change to 1440X900 60 Hz. How do I do that?
Your monitor does not support the display settings you have set in your operating system.
To change these settings go: (Windows 7)
Control Panel > Display > Screen resolution [Change to 1440x900]
then on the same screen, go to Advanced Settings > Monitor > Screen Refresh Rate [Set to 60 Hertz].
(This usually happened if you switched monitors, or used a TV, or maybe a projector).
You can use the same method to set up any resolution or refresh rate you want.
Sep 23, 2011 | HP Pavilion F1523 15" LCD Monitor
Tip
How to resize your desktop background.
If your desktop is smaller than the dimensions of your monitor then follow the following steps to get a full screen:
Setting the resolution:
1) Right click on an open spot on your desktop and select Properties at the bottom of the popup menu.
2) This will then open up the Display Properties window as shown below.
3) Click on the Settings tab (it's to the top right of the Display Properties window as shown in the image below.
4) At the bottom left of the settings tab there is a Screen resolution heading with a slider bar beneath it.
5) Slide this bar to the left or right until you find the resolution you like.
6) The click Apply when you have found the right resolution.
Sliding the bar to the left = lower resolution, larger desktop icons and less quality.
Sliding the bar to the right = higher resolution, smaller desktop icons and better quality.
NB: If you are using a CRT (older screen) the max resolution will be around 1280x1024. Newer LCD screen (flat and thin monitors) can go way up to 1920x1080 and beyond if HD is supported.
NOTE: If when doing the screen resolution changes your screen goes blank after you click Apply then immediately hold down the Enter key to restore it back to your previous settings
If this doesn't work then it just maybe the case that you need to set the auto screen fit function on the monitor itself using the buttons provided on the monitor.
This tip is useful when you plug in a monitor and the screen displays the No Signal or Signal out of Range massages. Simply change the resolution to something the monitor can handle and there you go.
You can also check out my video tutorial if you want to:
on Nov 10, 2010 | Computers & Internet
After being on a few minutes, the text becomes very blurry I lowered the resolution, which makes the text bigger and helps some. There is an internal adjustment, but I don't know where??
Hi hamptonwhh,
Screen resolution refers to the clarity of the text and images on your screen. At higher resolutions, items appear sharper. They also appear smaller, so more items fit on the screen. At lower resolutions, fewer items fit on the screen, but they are larger and easier to see. At very low resolutions, however, images might have jagged edges. Please follow the steps below on how to adjust your screen resolution.
Windows XP
1. Click Start, click Control Panel, click Appearance and Themes, and then click Display.
2. On the Settings tab, under Screen resolution, drag the slider, and then click Apply.
3. When prompted to apply the settings, click OK. Your screen will turn black for a moment.
4. Once your screen resolution changes, you have 15 seconds to confirm the change. Click Yes to confirm the change; click No or do nothing to revert to your previous setting.
Windows Vista/7
1. Open Display Settings by clicking the Start button, clicking Control Panel, clicking Appearance and Personalization, clicking Personalization, and then clicking Display Settings.
2. Under Resolution, move the slider to the resolution you want, and then click Apply.
Notes : When you change the screen resolution, it affects all users who log on to the computer.
When you set your monitor to a screen resolution that it won't support, the screen will go black for a few seconds while the monitor reverts back to the original resolution.
Hope it helps.
Thank you for using FixYa.
Jul 04, 2011 | MPC Computers Envision EN 775e 17 in.CRT...
My son was on my computer and change my video mode and turn off my computer and now it say that it can not display the video mode optimum resolution 1024x768 60Hz
Please reboot the machine. After it beeps hit F8 repeatedly. You'll get
a menu. One menu item will be "vga mode". Choose that, and use
the control panel to A) set 800x600, boot normally
or B) try setting your normal mode. Hope this helps even a bit.
Apr 16, 2011 | E-Machines eMachines Desktop PC
Having changed the os from xp to xp pro i am unable to alter the screen resolution. Any help appreciated.
Go into control panel, click display, settings on the top right, set the color quality at max and the screen resolution also at max, click okay to save settings and monitor should adjust accordingly, if not set monitor to auto setup.
Mar 31, 2011 | Hanns.G Corporation HW191D 19" LCD Monitor
Hi I've got a Samsung TFT monitor -Syncmaster 710V - that gives an error message.Message reads: Not optimum mode Recommended Mode: 1280 x 1024 60Hz This screen is impossible to get rid of. Anyone know the...
Try to change the desktop display settings, see screenshots below, see if it works
Right click on your destop and go to properties > settings
  1. Set your Screen resolution to 1280X1024
  2. Then click advanced and go to Monitor and set the refresh rate to 60 Hertz.
Dec 06, 2009 | Samsung 710V 17" LCD Monitor
Cannot set screen to max (1920x1200) resolution
When changing the resolution click "apply" and then "OK" in the properties menu. That should help it stick! FIXYA!
Apr 28, 2009 | Computers & Internet
Acer 3690, screen became smaller, like the screen has been resize
Try the following: First, right-click on your desktop, then click on Properties. You should get a popup window titled Display Properties. Click on the Settings tab. Under the Settings tab, look towards the bottom left at Screen Resolution and see if the current resolution setting matches the correct resolution setting for your laptop's screen.
Apr 25, 2009 | Acer Aspire 3690-2196 Notebook
Had a power outage and computer went out. when i turned it back on the icons and everything is now in large font
Go to display settings click on settings and change screen resolution. After changing click on apply or there may be a screen popup that ask if you want to keep it that way and click yes if thats what you want.
God Bless Greg
Nov 21, 2008 | Computers & Internet
Windows multiplied
what your son did is change the video resolution on your video card. right click on a blank area of your desktop, this will bring up a popup menu, left click on the word "properties" in the menu. this will bring up your display settings window. click on the "settings" tab. this is where the video resolution and color parameters are set. under screen resolution, there is a slider. move the slider to the left until the resolution is either 800x600 or 1024x768, then click "apply". this will get you back to a screen resolution that most monitors are happy with. if you had a higher resolution setting before, follow the same process to increase the resolution. also there is an option that allows you to test the resolution setting, and if it doesn't work, returns windows to it's previous setting. i recommend you use that option.
Jun 28, 2006 | CTX Value VL 510 15" CRT Monitor
Computers & Internet Logo
119 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Martin Murray
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
