Question about Kenmore Refrigerators
Refrigerator is not cold enough. Freezer is working fine.The other day I had to flip fuses to check an electrical outlet. Wondering if this caused problem? I tried unplugging it for 20 minutes last night and still no change this morning.
  • Kenmore Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 19, 2011
I have a Kenmore Elite 51374. The refrigerator is not getting cold enough but freezer is too cold. Technician said that it was an electrical problem to call a electrician that I needed a new outlet. I...
That is the dumbest answer I've ever heard from a technician.
The cold control on most boxes controls the freezer temperature. You want the freezer temp to be around zero degrees.
Somewhere (usually in the refrigerator section) there's another control that actually sets a damper, letting some cold air from the freezer into the refrigerator. Higher numbers equal lower temperature. Find that second control knob and turn it up by 1 or 2 numbers, let an hour or so pass and check your refrigerator temp. You want about 40 degrees in the fridge.
Aug 02, 2017 | Kenmore 23.3 cu. ft. Side-by-Side...
Refridgerator is not cold; barely cool.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jul 27, 2010 | Frigidaire FRT15B3A Top Freezer...
My GE Profile (PFS22SISBS) freezer not getting cold enough
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 18, 2010 | GE Energy Star PDS22SIS Stainless Steel...
Freezer works fine but fridge portion is not getting cold enough
by any chance do you hear the fan on at all........reach into the top freezer and feel if any air is blowin out of the vents..........if no air blowin it might just be the fan motor......it might be defective........................more details would be good..................
Jun 06, 2010 | Kenmore 64802 Top Freezer Refrigerator
The freezer seems to be working fine but the refig doesn't seem to be cold enough.Do the freezer setting and the refig setter need to be set on the same number?
Normally what causes the refrigerator not to be cold enough is that the fan that pulls the air from the freezer is not working. Check to make sure it is working, if not then you will have to replace it.
No the freezer and refrigerator settings DO NOT have to be the same
May 25, 2010 | Maytag MTB1891AR Top Freezer Refrigerator
Our refrigerator is not cold enough and our freezer is overfreezing everything
hi there,
over freezing but not cold enough means ice develop on freezer comparment because your fan blower is not functioning,on the back bottom side of refrigerator has a electrical circuit,find a fuse a
look like,small cylindrica tube with fuse wire inside coated by tube plastic,replace this to function your blower fan.have a nice day
Jul 07, 2009 | KitchenAid Refrigerators
Refrigerator does not get cold and the freezer does not freeze.
look on the back of the box for a hole marked defrost control timer turn the timer with a screwdriver if it then gets cold replace the timer
Apr 20, 2009 | Frigidaire FRT15B3A Top Freezer...
Fan running, weak air, fridge not cold enough, freezer working fi
it sound that your fridge is cloged of ice if so defrost it by unpluging it for the day to defrost completlyb with freezer door open then replace defrost timer if to much ice is formed on coil air does not cuculate properly thanks from gille
Feb 15, 2009 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Refrigirator not working
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Jul 10, 2008 | Amana ARB2257C Bottom Freezer Refrigerator
Freezer not cold enough
  • possible causes:
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Jun 29, 2008 | Amana ARB2205C Bottom Freezer Refrigerator
Refrigerators Logo
54 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
