Question about Texas Instruments TI-30XA Calculator
How do i use the cal for cube problems
For f(x) = 3 cube 2x-1, find f(-13):
  • 43 Answers
You are asking how to enter (3)(cube of 2x)-1, or (3)(cube of (2x-1), with x = -13?
For first:
13
=/- (below 3 key)
X
2nd
x cubed (above 1 key)
X
Answer -52,729
For second:
13
=/- (below 3 key)
X
2nd
X
Answer -59,049
Posted on Jan 01, 2009
Calories in alchol
Beer 5% 375 ml 135 cals 18.8g 0.8g Light beer 2.2% 375 ml 94 cals 8.3g 0.4g Low carb beer 4.8% 375ml 110 cals 18g
White wine sweet 200ml glass 189 cals 18.3g 3.3g White wine dry 200ml glass 135 cals 18.3g 0g Red wine 200ml glass 133 cals 18.3g 1.3g Spirits 1 nip 30ml 60 cals 12g 0g Cider 200ml glass 75 cals 10g Water any 0 cals 0 mins 0g
Jun 06, 2014 | Measuring Tools & Sensors
Swr meter not moving
follow these steps to adjust the
standing wave ratio(SWR).
1. Turn on the CB.
2. Set S/RF/SWR/CAL to CAL.
3. Key the Mic and rotate SWR CAL so the meter points
to CAL.
4. Unkey Mic.
5. Set S/RF/SWR/CAL to SWR.
6. Key Mic again and note the actual measurement on
the SWR scale. Refer to the following table to interpret
the reading.
1:1 - 1.5 Great
1.5 - 2:1 OK
2:1 - 3:1 Not So Good
Higher than 3.1:1 Terrible
Jan 14, 2011 | Cobra 29 LTD CB Radio
Hello, How can we revoke Temporary TS per Device CALS in Windows server 2008? Thanks.
hi there,
When a terminal server is configured to use Per Device licensing mode, and a client computer or device connects to a terminal server for the first time, the client computer or device is issued a temporary license by default. When a client computer or device connects to a terminal server for the second time, if the Terminal Services license server is activated and enough TS Per Device CALs are available, the license server issues the client computer or device a permanent TS Per Device CAL. If the license server is not activated or does not have any TS Per Device CALs available, the device will continue to use the temporary license. The temporary license is valid for 90 days. A permanent TS Per Device CAL issued by a license server is configured to automatically expire after a random period between 52 and 89 days, at which time the TS Per Device CAL will return to the pool of available TS Per Device CALs on the license server.
In some circumstances, you might want or need to return a TS Per Device CAL that has been issued back to the available pool on the license server before the automatic expiration period has been reached. For example, you might want to do this if the client computer or device is no longer a part of your environment.
In Windows Server 2008 you can revoke a TS Per Device CAL by using the TS Licensing Manager tool.
In Windows Server 2008 you can only revoke a TS Per Device CAL. You cannot revoke a TS Per User CAL.
After you have revoked the TS Per Device CAL, that TS Per Device CAL will be immediately available to be issued to another client computer or device. Revocation is not a substitute for ensuring that you have enough TS Per Device CALs to support your environment.
You can only revoke up to twenty percent of the number of TS Per Device CALs of a particular version installed on your license server. For example, if there are 100 Windows Server 2003 TS Per Device CALs installed on the license server, you can only have 20 of those Windows Server 2003 TS Per Device CALs revoked at any given time. If you also have 200 Windows Server 2008 TS Per Device CALs installed on the license server, you can revoke up to 40 of those Windows Server 2008 TS Per Device CALs in addition to the Windows Server 2003 TS Per Device CALs that you have revoked.
Use the following procedure to revoke a TS Per Device CAL by using TS Licensing Manager.
Membership in the Administrators group, or equivalent, is the minimum required to complete this procedure. Review details about using the appropriate accounts and group memberships at http://go.microsoft.com/fwlink/?LinkId=83477.
To revoke a TS Per Device CAL by using TS Licensing Manager
1. Click Start, point to Administrative Tools, point to Terminal Services, and then click TS Licensing Manager.
2. Expand the node that represents the license server that issued the TS Per Device CAL, and then select the node that represents the version of TS Per Device CAL that was issued. For example, click Windows Server 2008 - Installed TS Per Device CALs.
3. From the list of issued TS Per Device CALs, select the TS Per Device CAL that you want to revoke.
4. On the Action menu, click Revoke TS CAL.
5. To confirm that you want to revoke this TS Per Device CAL, click Yes.
6. If the revocation was successful, a message will appear confirming that the TS Per Device CAL was revoked and telling you how many more TS Per Device CALs of that version you can still revoke.
7. Click OK to close this message. The Status column for the TS Per Device CAL will show a status of Revoked when the TS Licensing Manager display is refreshed.
Hope this helps, good luck, God bless
http://www.onlinepcrepair.vox.com
http://www.onlinepcrepair.url-go.com
Dec 04, 2009 | Office Equipment & Supplies
When i am in the middle of a sale it comes up error. i clear it then it will work again . it does this on and off. swintec sw20
It sounds like you have a bad connection..either in your wall socket, or the electrical cord on your cal. is getting old or shorted where it connects to your cal. If it is not these connections, your may have dropped a staple or paper clip in your cal. turn cal off and shake machine to dislodge it. turn cal back on see what happens. if it starts to smoke, etc. etc, this was your problem and you need a Monroe cal. good luck
Oct 31, 2009 | Office Equipment & Supplies
When i key up the mike the tx/rx light and the ant
your swr setting are off wack fix your swr
Oct 02, 2009 | Cobra 29 LTD CB Radio
I need the manual/s for a Cobra CB radio, 29LTD Classic,ser#105129711,manufactured 5/01. Thanks for any help you might have, This radio has a built in SWR meter and I need to know how to tune it or do I...
1) push the button marked S/RF / SWR / CAL to CAL
2) Hold in the button on the mic
3) Turn the SWR CAL knob until the needle is over set to the far right of the meter
4) flick the switch (in step 1) to SWR
Your SWR reading will be displayed. The more to the left the better..
Jun 22, 2009 | Radio Communications
Items dropped in the dispenser
you will need to cal someone to have whatever it is removed.
Feb 13, 2009 | Refrigerators
Platten cal cable
do platen calibration then also same problem change platen sensor
Dec 12, 2008 | Tally 6312 Matrix Printer
Texas Instruments TI-30XA Calculator Logo
242 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
