Question about Acer Computers & Internet
Power cord plugged in but the battery is not charging. what setting keeps that from happening?
  • 33 Answers
A couple of questions for you and you can check these things. I want you to check and see if there is a battery in the system to start with not saying there isn't but stranger things have happened to me and check to see if the battery is ok. If the battery is cooked it may not take a charge you may have to go into a computer center to have it checked. There is no setting that stopped it from charging it may be an issue with the system internally. Hope this helps.
Posted on Mar 15, 2011
  • 784 Answers
Is the battary ok? if battary is fully charsed? or empty. Maybe charsing chip faulty.
3 Suggested Answers
  • 181 Answers
SOURCE: Battery will not charge/ keep computer on. laptop
Sounds to me like the transformer circuit that enables the batery to charge. If you have bought your machine within the last 12 months it should still be covered by warranty so go back to the supplier. If not covered I wouod still try as it is not beyond reasonable expecations that the machine will operate perfectly in very way for more than 1 year.
Posted on Feb 13, 2010
  • 75 Answers
SOURCE: no power
Try to remove your battery and plug in your AC adapter
If its working:
You need to replace your battery
If its not working:
Try to check if the LED indicator is lit
If the LED indicator is not lighted. Replace your AC adapter
Thanks. Cheers!
Posted on Apr 21, 2010
Laptop shut down and wont power up
Unplug, remove battery, check for dust in fans and vents, plug in, try to reboot. If it powers up, open Control Panel, Power Options Power , set to High Performance, open Advanced Power settings, set Sleep and Hibernate to Never, Adjust other Advanced settings to your preference. Has it been pulled by the cord? If you have a multimeter check for DC volts at the AC jack plug, that plugs into the laptop. Is the Transformer (brick on the cord) getting warm when plug in? Does the battery charge LED light? Try another cord with the EXACT same power specs.
Jan 23, 2013 | ASUS G73SW3DE Republic of Gamers 173Inch...
My zoostorm laptop wont turn on but charges
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.Maybe your memory is bad or the memory slot is bad.Remove the Power Cord, Remove the Battery, Remove the cover that houses the memory on the bottom of the laptop then remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
May 17, 2012 | Computers & Internet
Plugged in but not charging
Plugged in but not charging? What's not charging, the battery? If so, the battery is dead.
Are you saying the power cord is plugged in but the computer is not powering up?
Remove the Power Cord, Remove the Battery, Remove the cover that houses the memory then remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 22, 2012 | Compaq Computers & Internet
If the computers lights are just yellow what does that mean?
Just Yellow when? Tell us what happens time you put the power cord in and press the power button? Does it try to boot? Do the lights blink? Hear any beeps? Hear any fans? Does anything ever appear on the screen?
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge. Remove the Power Cord, Remove the Battery, Remove the Memory Cover on the bottom of the laptop and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 07, 2012 | Acer Aspire 5500 5570-2609 Laptop
After a system shutdown computer will not restart
Give us more details on what is happening when you press the power button. Is it trying to restart?
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 07, 2012 | Acer Black AX3400G-U4802 Desktop PC with...
Dell inspiron 1501, green battery charge light, will not power up
Remove the Power Cord, turn the laptop over and remove the cover over the memory, then remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 04, 2012 | Dell Computers & Internet
My Asus Eee PC 1001PXD battery won't charge. The charges light is on but nothing happens and now the battery is completely dead and I cannot get my notebook on
Your problem is far more than the battery. Your problem is the power cord. Laptops for the most part will work off the power cord even if the battery is dead or even if the battery is not in the laptop. Your power cord charges your battery and if it is bad it will not charge it. You've been working off your battery even though you might have had the power cord plugged in, but if it's bad and not charging the battery, the battery drains and then you can't get the laptop to power on at all. Go purchase a ac adapter and power cord that is designed for your system. Don't buy one that some of the big box stores sell that has a an interchangeable plug at the end designed to fit just about any laptop. Those will eventually burn *********** board out.
Mar 20, 2012 | ASUS Computers & Internet
There is no power from the battery or the adapter and the laptop does not recognise the adapter is plugged in. there are no lights coming on and the power button is doing nothing
Your battery maybe out of charge. Thats why nothing happens when you press the power button. The battery may not be charging because the power cord might not be working. Try another power cord.
Try removing the battery and plugging the power cord and switching on the computer. If its the problem with the power cord the computer wont start. If it starts, the power cord is working fine.
Nov 18, 2010 | Acer Aspire 5920-6727 Notebook
Powers on immediately powers off
ok well there is somwhere to start i would see if you can get it to take a charge ok and if it does than try to start it without the ac power on and see what it does if it wont take a charge your battery may be bad or your charging circuit may not be connected correctly ok lrt me know best regards mike
Aug 27, 2008 | Dell Inspiron 5160 Notebook
Power supply issues
Have you checked the AC power pin (where the AC cord plugs in)?
Chances are that the pin has come loose from tugging and pulling on it. When this happens the battery charging is intermittent at best. The parts to fix this problem are usually under $10 but the labor if you take it in is gonna run $100-$200. You can repair it yourself if you're comfortable working with electronic components. Not that tough. WHen you get it fixed, invest in a Cable Retention device to keep it from happening again.
Here's a short video that talks about it. . .
Feb 26, 2008 | Dell Inspiron 710m Notebook
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
