Question about Sony VAIO VGN-SZ110/B Notebook
In my windows there is on option high light for the stand by
  • 784 Answers
Is that blinking or?
Posted on Mar 15, 2011
Why wont my Sony trinitron tv turn on but stand by light flashes?
That Flashing Standby Light Indicates A Defect In Your Low Voltage Or High Voltage Power Supplies...
May 25, 2014 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Fuse box layout for 2005 honda crv
No. Amps Circuits Protected 1
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38 7.5
15
10
7.5
(15)
(20)
_
10
7.5
7.5
10
10
10
7.5
7.5
10
10
20
15
7.5
20
_
_
(20)
20
20
(20)
15
15
20
(15)
20
20
7.5
7.5
10
7.5
30 Power Window Relay
Fuel Pump
ACG
ABS/VSA
Heated Seats*
Front Fog Lights*
Not used
Rear Wiper
ODS (Occupant Detection System)
Meter
SRS
Right Headlight High Beam
Left Headlight High Beam
Small Light (Interior)
Small Light (Exterior)
Right Headlight Low Beam
Left Headlight Low Beam
Main Headlight High Beam
Small Lights MAIN
TPMS
Headlight Low Beam
Not used
Not used
Moonroof*
Door Lock
Front Left Power Window
HAC Option
Rear Accessory Socket
Accessory
Front Right Power Window
Accessory Power Socket on the Center Table*
Rear Right Power Window
Rear Left power window
ACC Radio
ACC Key lock
HAC
Daytime Running Lights
Front Wiper * If equipped
Dec 06, 2013 | 2005 Honda CR-V
Lc320em2f wil not turn on light blinks twice ,troobleshooter
Two blinks of stand by light indicates a fault to its back-light system. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Flip card, can be selected by the drop-down list, by the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window. Blinking codes to many brand TVs are given.
Nov 03, 2013 | Emerson LC320EM9 32 in. LCD HDTV
Sony trinitron kd-34xs955 standby light is blinking 7 times
Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
As you can see here, seven blinks of standby light is due to some over voltate at the final anode of the picture tube. This is a protection process that going on insde the tV circuits, to prevent more damage to other comnponents on board. The most common cause for this is with the main power regulator out voltage itself. If any way, it ahs exceeded 135VDC, this kind of fault will occur. Check the main power regulator section circuit for any damaged component/s. Replace all the small electrolytic capacitors there. Visit the site named 'Electro-help' for more details. Check this LINK and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy. Some times, the ads attached with each posts might help you to find the availability of spare parts. There are more than 550 posts to different brand TVs. Blinking codes and details are there.
Aug 09, 2012 | Sony FD Trinitron KD-34XS955 34" TV
Motorcycle Question
Check that the kick stand switch is not faulty. this will kill the engine when it says the kick stand is down.
May 22, 2012 | Honda VF 750 C Magna Motorcycles
Translating japanese to english on fuse box
is located under the dashboard on the driver's side. The fuse label is attached under the steering column. If something electrical in your vehicle stops working, check for a blown fuse first. Below table outlines detail fuse number, its ampere and circuits protected. honda-crv-interior-fuse-diagram-thumb.png
No.
Amps
Circuits Protected
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
7.5 15 10 7.5 (15) (20) _ 10 7.5 7.5 10 10 10 7.5 7.5 10 10 20 15 7.5 20 _ _ (20) 20 20 (20) 15 15 20 (15) 20 20 7.5 7.5 10 7.5 30
Power Window Relay Fuel Pump ACG ABS/VSA Heated Seats* Front Fog Lights* Not used Rear Wiper ODS (Occupant Detection System) Meter SRS Right Headlight High Beam Left Headlight High Beam Small Light (Interior) Small Light (Exterior) Right Headlight Low Beam Left Headlight Low Beam Main Headlight High Beam Small Lights MAIN TPMS Headlight Low Beam Not used Not used Moonroof* Door Lock Front Left Power Window HAC Option Rear Accessory Socket Accessory Front Right Power Window Accessory Power Socket on the Center Table* Rear Right Power Window Rear Left power window ACC Radio ACC Key lock HAC Daytime Running Lights Front Wiper
Dec 13, 2010 | 1997 Honda CR-V
"stand by" option not active
It is configuring in "power options" in control panel
Aug 11, 2009 | ASUS A7V8X-MX SE Motherboard
Cannot get tv out of stand by mode..
upon hitting the power button, the red light showing on the front of the tv should flash a couple of times, the screen should come on and the light goes off..the red "stand by " light stays on and we cannot get the screen to come up..needless to say, cannot get to the menu to change any display options...any suggestions?
Apr 10, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
LCD problem
ok just go to Start- Settings -Control Panel - Power options -click on it inside that turn off monitor option Never u say and system stand by u make it as Never apply and say ok it will not go to stand by mode
Jul 30, 2008 | Computers & Internet
Sony VAIO VGN-SZ110/B Notebook Logo
19 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
